Cooling Reviews Watercooling
NZXT Kraken Z73 All-in-One CPU Compact Water Cooler Review – Powerful Meme Machine
In early 2020, NZXT unveiled the Z series, the latest generation of its popular Kraken all-in-one water cooling systems, and its integrated display not only sparked a new trend among other manufacturers, but also a whole wave of funny pictures on social media. Whether the most expensive compact water cooler on the market can also keep up in terms of cooling performance, you can find out in the following article:
The almost half a meter wide box is mostly kept simple and corresponds to the typical NZXT design. Front and back are white and show the included Kraken Z73 in disassembled and assembled state. In addition, there is a multilingual list of the features, on the purple pages they go into more detail and print a table with the technical specifications.
After opening the packaging towards the top, the well-known transport protection made of a cardboard casing awaits us inside. The radiator has been shoved into thin cardboard again, the rest is wrapped in plastic.  The fans, manual and accessories are each individually packaged, some disposable plastic could have been saved here.
The bag with the accessories is limited to the most necessary, besides backplate and mounting material there is only an internal USB cable and the pump connector with integrated PWM splitter. Despite the premium price, there is no extra tube of thermal paste!
When switched off, the Z73, which is shown very colorfully in the pictures, is surprisingly plain and completely black from the fan to the mounting frame.
The radiator is in near perfect condition, with only a few places where there are minimal imperfections on the fins.
In addition to the sparingly applied circular thermal paste, there is also the Micro-USB and proprietary power connector to be spied on the pump block. I would have preferred a USB-C port here, but more on that in a moment.
Assembly and installation
Mounting on the AM4 socket could hardly be easier, as four spacers are simply screwed into the existing backplate, the pump block is placed on top and fixed in place with thumbscrews. So there’s no need for a third hand this time.
Depending on the socket, only the appropriate mounting frame must be pressed onto the block beforehand, the Intel frame is on it ex works. The fans are mounted as usual with screws, the corners and screw holes in the Aer P120 fans are rubberized from the inside and thus decoupled.
The power is supplied via SATA connector, the connection to the CPU fan connector is only relevant for reading the RPM. Control runs via software over the mentioned Micro-USB cable, which cannot be installed according to the own system due to the connection and angle of the cable. A Type-C connector or at least a cable without an angle would have been better in my opinion. There seems to be a lot of air in mine, because for a few minutes after it was first turned on, it bubbled properly. After a short time at maximum speed, however, the whole thing calmed down and did not become noticeable later.
Specifications
Here a summarized overview of the technical data, all further details then as usual on the manufacturer’s page.
Compatible Socket
Intel Socket LGA 1200, 1151, 1150, 1155, 1156, 1366, 2011, 2011-3, 2066
AMD Socket AM4, sTRX4*, TR4*(*Threadripper bracket not included)
Warranty
6 Years
Fans
Speed: 500-2,000 + 300 RPM
Air Flow: 1 8 . 2 8 – 7 3 .1 1 C F M
Air pressure: 0 .1 8 – 2 . 9 3 m m – H₂O
Noise: 21-36dBA
Bearing: Fluid Dynamic Bearing
Power Consumption: 12V DC, 0.32A, 3.84W
Connector: 4-pin PWM
Life: 60,000 hours / 6 Years
Cap
Display Orientation: Software adjustable Default and -90° orientation
Display Panel Active Area: 2.36″ (60mm) diameter
Display Color: 24-bit true color LCD
Display Resolution: 320 x 320 px
Display Brightness: 650 cd/m²
Tube
Length: 400mm
Material: Ultra-low Evaporation Rubber with Nylon Braided Sleeve
Radiator
Dimensions: 121 x 394 x 27mm
Material: Aluminum
Pump
Motor Speed & Power: 800 – 2,800 + 300 RPM, 12V DC, 0.3A
NZXT Kraken Z73 (RL-KRZ73-01)
FritzHunter01
1,256 Kommentare 1,705 Likes
Danke Tim,
gutes Review! Mir gefällt die Möglichkeit, dass man Display der Pumpe selbst gestalten kann. Die Leistung der 360er steht außer Frage!
Der Preis is aktuell völlig irrsinnig! 275,- € is wahnsinn!!!
MfG
Fritz
f
funkdas
633 Kommentare 259 Likes
Man kann es auch so sehen: Endlich mal ein Hersteller, der die Kohle selber einsacken will, und die übertriebenen Preise nicht dem Handel überlässt.... (Wer Ironie findet, darf sie behalten)
Tim Kutzner
888 Kommentare 730 Likes
Die Kommentare unter einem Review zu einer 190 Euro AiO: "Da kann man ja eine Custom Loop für bauen !!11"
NZXT: Hold my beer :D
Der Fairness halber muss man aber auch sagen, dass der derzeitige Preis wohl einfach enorm hoch ist ..
UVP sind zwar 279 Euro, der tatsächliche Straßenpreis war Ende letzten Jahres aber schon bei ~ 220 Euro
grimm
3,230 Kommentare 2,168 Likes
Eines Tages bastel ich mir auch ne WaKü rein. Muss nur mal einen Grund finden.
Tim Kutzner
Ich habe hier etwas für dich gefunden ---> Link
Buildlog dann bitte nächste Woche posten :P
grimm
Nene. Ich muss höchstens die 2080S besser kühlen, die treibe ich mit meinen Einstellungen (zu) hoch. Spiele aber mit Headset, insofern wurscht. Der 1600X bleibt kühl und leise. Ich bin mir auch echt nicht sicher, ob 7 bzw. 5nm sooo toll sind. Wie kühlt man denn solche Strukturen effektiv? Die 5000er Serie und auch die flotten Intels der 9000er und 10000er Reihe glühen kräftig rum. Manchmal zu kräftig, wenn ich gar nicht so wenigen Berichten glauben darf.
Aber in meinem Rechner ist eher die GraKa Temp-Champ.
Corro Dedd
1,845 Kommentare 702 Likes
Das passt aber nicht in das Display ;)
Ich hatte ja den Cuplex Kryos Next Vision auf dem i7-3930K. Ist ein nettes Spielzeug, aber wirklich drauf geguckt habe ich nicht, schließlich steht die Kiste ja unter dem Tisch, nicht darauf.
Wie jetzt?
67 Kommentare 53 Likes
Nettes review, aber um eine 360er AiO zu fordern müsste so langsam mal eine andere Wärmequelle herhalten - wie wäre es mit einem 5800X? Der Preis ist einfach nur crank, dafür bekäme man fast 3 360er Arctic Liquid Freezer - wenn die denn lieferbar wären.
Tim Kutzner
Ich kaufe mir die Test-Hardware selbst, wird also bis auf Weiteres nicht passieren.
Zumal ich dann das Problem habe, dass ich Budget-Kühler nicht mehr testen kann.
Optimal ist es nicht, aber immerhin kann man mit dem R5 3600 testen, wie gut die Kühler mit einem assynmetrischen Anordnung der DIEs zurechtkommen.
Wie jetzt?
Sorry, war mir nicht klar.
Dann wäre die Arctic Freezer in jedem Fall einen Test wert, die Rev.3 kann in einer normalen und in einer versetzten (offset) Position montiert werden. Da könnte man auch den Effekt der Positionierung vergleichen.
Tim Kutzner
Habe ich auch schon gesehen, interessante Idee
Bei Gelegenheit schaue ich mir das mal an :)
RaptorTP
337 Kommentare 169 Likes
Hallo zusammen,
Test ist kurz und bündig.
Schön ist der Test der Kombination aus Drehzahlen und Pumpen-Geschwindigkeiten.
Mir fehlt hier der Hinweis das die Lüfter ans Board müssen. Bei 3 Lüftern ist das dann nicht mehr soo lustig. Wenn man keinen Adapter dazu packt.
Anbei mal mein Test zur X63 Kraken:
Tim Kutzner
Die Lüfter müssen aber nicht ans Board.
Seite 1, Lieferumfang: " [...] Pumpenanschluss mit integriertem PWM-Splitter."
Zu sehen im Bild des Zubehörs, rechts oben
RaptorTP
Ooops ! ... echt übersehen.
Dachte das sei nur das Kabel zur Drehzahlübertragung.
Cool, cool, cool ! Dann nehm ich das natürlich zurück. Top !
M
MGFirewater
147 Kommentare 49 Likes
interessant sind die hinweise und tipps zum cam.
mich nerven auch die zu hohe idle-last. haben eine x63 (ohne Display) und auch alles abgeschaltet habe was man nicht braucht.
ich nutze seit Ersteinrichtung ausschließlich den gastzugang und der zickt bei mir garnicht rum.
einzig & allein die usb-verbindung wird von cam nicht immer erkannt, aber hier liegt das problem eher im bekannten usb-controller-bug der b550 boards in verbindung mit ryzen 5000.
es soll ja eine alternative zu cam geben, welche wäre das und muss mit welchen Nachteilen müsste man dann leben?
Tim Kutzner
ApolloX
1,687 Kommentare 957 Likes
Accountzwang - es kann doch nicht sein, dass ich nen Online Account irgendwo brauche, um einen CPU Kühler anzuschalten.
Corro Dedd
Wenn es dir unter den Fingernägeln brennt, Gamers Nexus hat den schon getestet:
@ApolloX
Der Kühler wird wohl schon laufen, aber dann kriegst du halt nichts auf dem Display angezeigt. Vielleicht fallen sie ja noch damit auf die Schnauze, Razer hat es ja mit ihrer Software auch schon versucht und musste zurück rudern.
Tim Kutzner
Genau lesen, das ist NICHT mehr der Fall ;)
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
