Aircooling Case Computex Fans Latest news PSU
NZXT at Computex: Airflow cases, new fans, brand new power supplies and a tour of the trade fair with many products
First of all, I would of course like to recommend the valuable trade fair video from me, because the tour and a nice explanation naturally provide a real live impression that no film in the world can replace. If you want to see two people really sweating (me because of the heat and NZXT because of the amount of explanations), I can only warmly recommend this clip (long live the good old pun box):
H7 Flow and H7 Flow RGB
A lot of wind around and in a case: the NZXT H7 Flow and Flow RGB are two mid-towers designed for airflow, for which I have of course also prepared all the data sheets and detailed views as a special service:
Case H7 Flow & H7 Flow RGB(2024)_Salestool_EN_V3_240423
New fans with extra airflow or extra static pressure
Here, too, I can of course provide details and start with the presentation of the airflow fan:
Fans Cooling Fans_Quiet Airflow Fan V2_Salestool_EN_240227_V1
If, on the other hand, you need more pressure, you’d probably prefer this one after all:
Fans Cooling Fans_Static Pressure Fan V2_Salestool_DE_240306_V1
And if you want to put several fans next to each other but are too lazy to plug them in, you can look forward to the single frames:
Fans Cooling Fans_F RGB CORE_Salestool_EN_240301_V1
New power plants in platinum and gold standard
You already know the C1200, but of course I’ve included its big brother for the sake of completeness:
PSU Power_PSU_C1500 Platinum_Salestool_EN_240423_V3
And there are not only the really big power plants, but also a normal electrical drinking behavior. NZXT also has something golden for this in smaller energy filling units:
PSU PSU_ Gold(C1200 C1000 C850)_Salestool_240409_V1
NZXT C1200 Gold power supply in test – Gold sometimes beats platinum, and not just on price
DMHas
59 Kommentare 18 Likes
Das NZXT H7 Flow sieht sehr interessant für mich aus! Ich bin schon mal gespannt auf die Tests ....
DigitalBlizzard
2,586 Kommentare 1,376 Likes
Das neue H7 Flow gefällt mir auch sehr gut, habe das bisherige H7 Flow, das man den Netzteiltunnel reduziert hat und das hinten vertikal reinsetzt ist eine coole Lösung, das schafft Platz für Bodenlüfter.
Wirklich sehr schön, könnte die Performance des jetzigen H7 Flow nochmal steigern, obwohl das schon sehr gut ist.
Richtig tolles Case, gefällt mir ausnehmend gut
Steffdeff
777 Kommentare 729 Likes
@Alexander Brose bitte teste dieses Gehäuse wenn sich die Chance dazu ergibt! 🙏
Das ist ein sehr heißer, ähm hoffentlich kühler Kandidat für mein System.
Am besten gleich im Vergleich zum Light Base 600.😃
Vielleicht kann Igor gleich beide im Handgepäck mitbringen.🤭🤣
DigitalBlizzard
Jap, und mir bitte das H7 Flow 2024 und das HAVN, ich Zahl auch das Übergepäck 😜
Steffdeff
Ja das HAVN ist auch sehr, sehr chic!
Könnt ich mir wahrscheinlich auch leisten, hab ja noch beide Nieren! :ROFLMAO:
DigitalBlizzard
Was die haste noch!? Du Glücklicher, fürchte aber die reichen nicht, wirst noch auf einen Teil Leber verzichten müssen, oder 800g Knochenmark 😜
Steffdeff
Ich fürchte die Leber ist schon gut gebraucht und nicht so wertvoll, dann besser das Knochenmark.;)
In der Spenderkartei bin ich allerdings schon gelistet.:D
DigitalBlizzard
Ja, habe davon gehört das Lebern mitunter qualitativ schwierig sein können.
Im Ernst, auf den ersten Blick ist das HAVN schon echt ne scharfe Nummer, aber das neue H7 ist auch sehr sehr sehr fein.
Steffdeff
Ja das HAVN ist wirklich ein Hingucker.
Momentan hab ich ein EvolveX aber der Tunnel vom Netzteil stört mich einfach.
Obwohl das Phanteks ein hochwertiges Gehäuse ist würde ich sofort tauschen.
Da meine Komponenten (5800x und 6900 xt) noch ganz gut laufen steht ein vernünftiger Monitor und ein luftiges Gehäuse ganz oben auf der Einkaufsliste.
Alexander Brose
836 Kommentare 598 Likes
Das neue H7 steht schon hier 😁, aber ihr müsst euch noch etwas gedulden. Dafür wird es ein umfangreicher build - die volle Dröhnung NZXT (y)
Das Light Base 600 (oder wahrscheinlich im Test wohl eher 900) dauert noch eine Weile. Hab diesbezüglich vorhin schon eine Nachricht von BeQuiet! erhalten. Kommt also auch sobald es verfügbar ist :).
Grüße!
DigitalBlizzard
Hallelujah, gepriesen seist Du, lieber @Alexander Brose .
Ich werde fast neidisch.
DigitalBlizzard
Es wird Zeit das AlphaCool endlich bei Gehäusen einsteigt, mit integrierten und/ oder vorbereiteten WaKü Komponenten, würde ich feiern. Was richtig cooles und hübsches was schon mit Distro Plate und der integrierten neuen DDCzero Pumpe kommt, 2 vormontierten 360/45er Radis , vornfektionierten Schläuchen und Fittings, Apex Stealth Lüftern, Steuerung, und für nen 1000er zu haben wäre und man und integriertes Temperatur und Durchfluss Display, nur noch seinen individuellen CPU und GPU Block bräuchte, und nur noch NT, MB, RAM und Massenspeicher rein, fertig.
Das ganze in Hübsch .
Das würde Custom WaKü nen fetten Schub verpassen.
Ich träume wieder.
Tronado
3,950 Kommentare 2,084 Likes
Am besten mit 6x vorinstallierten Apex Stealth Lüftern. Dann kostet das Gehäuse 270€, wiegt 24 kg und hat trotzdem nur
einen mäßigen Airflow. :D
DigitalBlizzard
Mäßiger Airflow, warum? Ich habe die 2000er und 3000er Stealth und der Airflow ist alles andere als mäßig, der ist sogar extrem gut, genau wie das Geräusch.
Druck, Durchsatz und Akustik top.
Tronado
Leise sind sie, der Luftdurchsatz ist aber eher mäßig. Selber schon einige verbaut, auf ausdrücklichen Wunsch und entgegen meinem Rat. :)
Beim Verhältnis Lautheit zu Kühlleistung kommen sie lange nicht an die preiswerten Arctic P12 V3 heran. In einem Chart "Preis - Lautstärke - Kühlleistung" würden sie recht weit unten rangieren.
DigitalBlizzard
Ich kann mich bei meinen Modellen nicht beschweren, die 3000er auf den 45er und 60er Radis arbeiten hervorragend, die 2000er in den Cases laufen tatsächlich bei maximal 800-1000, habe eine Lautstärkeverbesserung im Vergleich zu den vorher genutzen LianLi und davor BeQuiet, dabei trotzdem bessere Temps und deutlich besseren Luftstrom.
DMHas
(y):love: Ich freue mich schon auf die Tests!
Follow Igor:
