GPUs Latest news
NVIDIA RTX 5090: Technical data leaked? 512-bit memory interface, 16 GDDR7 memory modules and new PCB design
According to initial leaks and rumors, the NVIDIA GeForce RTX 5090 seems to exceed all expectations, reports Kopite7kimi on X, these come from Panzerlied. According to a recent mega-leak, we can expect a 512-bit memory monster with 16 GDDR7 memory modules and a completely new PCB design. The RTX 5090 is said to be equipped with a huge 512-bit memory bus, which is twice as wide as the current RTX 4090. This enables a significantly higher memory bandwidth, which is essential for graphics-intensive applications such as 4K gaming and AI calculations.
Source: Monica.im
16 GDDR7 memory modules should ensure rapid data transfer rates. The latest GDDR7 memory technology offers up to twice the speed of GDDR6, enabling even smoother and more responsive graphics performance. In addition to the impressive memory architecture, the RTX 5090 features a completely new PCB design. This is intended to significantly improve the efficiency and cooling of the GPU. Details on the design are still scarce, but experts expect it to integrate new technologies for heat dissipation and power supply.
With these technical refinements, the NVIDIA GeForce RTX 5090 promises an enormous leap in performance compared to the current generation. Initial benchmarks suggest that it could be up to 50% faster than the RTX 4090, which would make it the most powerful graphics card on the market.The official release date for the RTX 5090 is not yet known. However, experts speculate that the market launch could take place sometime in 2024. The price is likely to be on the high end due to its high performance and innovative technology.The NVIDIA GeForce RTX 5090 is shaping up to be a true graphics card giant that redefines the boundaries of what is possible. With groundbreaking memory technologies and an innovative PCB design, it promises unrivaled performance for gamers, creatives and professionals.
Source: Chiphell Forums Kopite7kimi, Panzerlied
m
mkossmann
32 Kommentare 32 Likes
Die RTX4090 hat eine 384 Bit breite Speicheranbindung ( für 12 GDDR6X Speicherchips). Nicht nur 256 Bit
Antwort 7 Likes
p
pootch
45 Kommentare 7 Likes
Kopiert ihr jetzt auch schon Werbetexte ab?
Genauso liest sich der Artikel.
Antwort 6 Likes
Gliedde
23 Kommentare 7 Likes
Erste Benchmarks deuten auf eine 50%ige Steigung hin?
Wo sind die Benchmarks?
GrindaFrey
15 Kommentare 7 Likes
Danke!
128 Gbt Speicher oder noch mehr!
256
512
1000 GBT.. LEISTUNG. HUBRAUM.
DER SPRUNG. DER SPRUNG zu den Speichergrößen. Der ist überfällig.
Das Teil könnte sogar 512 GBT RAM haben.
Geht schu! :)
ich vergass. bei Nvidia ist immer das Mass die 2mm Hoden-säckchen des gierigen Firmen-ceo-s .. small eggs = nvidiaaaa
B
BudSpencer
33 Kommentare 12 Likes
Früher hat Igorslab die Werbetexte von Alphacool übernommen, heute wird der Werbetext von Nvidia diktiert. Ich glaube das ist ein Upgrade, jedenfalls monetär für den Betreiber.
Megaone
1,833 Kommentare 1,726 Likes
Und wenn schon, meinetwegen könnte Igor 10 Millionen im Jahr von Nvidia bekommen. Ich hab nirgendwo mehr gelernt und mehr Unterstützung ( auch Seitens es Betreibers erhalten) als hier. Solange die Tests stimmen, ist mir der Rest egal.
Antwort 4 Likes
Case39
2,550 Kommentare 965 Likes
Da sind wir, denke ich alle mit dir. Nur die Qualität der Artikel wird immer mehr komischer...seh dir mal das Titelbild an😉
s
schtho
14 Kommentare 4 Likes
Ich halte den Text für Blödsinn. 16GB Speicher die 4090 hat 24GB. Selbst wenn er schneller ist, wäre das für AMD ein Geschenk.
Ich halte NVIDA nicht für so blöd.
Steffdeff
777 Kommentare 729 Likes
Ja jetzt wo du es sagst!?!
Ich hab zum Glück noch die alten DVI Kabel! Oder ist das die neue externe Stromversorgung?😉😃
ro///M3o
361 Kommentare 249 Likes
@Samir Bashir Bro, wasn das wieder fürn Artikel? Poppcorn pur 😅
Case39
Ich bezog das eher auf das Formenlogo, aber wo du es erwähnst😂
ipat66
1,422 Kommentare 1,436 Likes
Das macht die KI automatisch...
Ist, glaube ich, immer so.
Wohl aus Copyright Gründen.
Dark2k
40 Kommentare 4 Likes
Erste Benchmarks deuten auf eine 50%ige Steigung hin die durch die verwendung noch schlechterer wärmeleitpaste wieder zunichte gemacht wird. Weiterhin wird der beiliegende Stecker adapter viel früher feuer fangen, benutzer der neuen karten müssen auch sichersetllen das die Lüfter in dei richtige richtung drehen.. das ist ein neues feature um von anderen features abzulenken die so seit einiger zeit gang und gäbe sind..... ich freu mich schon :D
NamaNatranius
25 Kommentare 13 Likes
Das mit den 16gb sind falsch es sind speicher blöcke gemeint mit je 2gb also insgesamt 32GB speicher aber sind ja nur gerüchte aber 512 bit wären mal geil
GPUModder
71 Kommentare 20 Likes
Die 5090 wird sicherlich wieder eine tolle Karte werden. Das bringt ein Topmodell im Bereich von 1-2 Monatsgehältern mit sich. Jaja, man soll nicht von sich auf andere schließen ich weiß ;). Allerdings sollte AMD wirklich nicht im Highend wildern, bin ich mir nicht so sicher ob Nvidia wieder so einen Hammer wie die 4090 auspacken wird. Natürlich sind ein paar Prozente aufgrund Speicher, Takt und Architektur drin, aber 50% halte ich für zu hoch. Die 4090 legt z.B. laut PCGH Index (Overall) 50% auf die 3090ti drauf. Bei der 4090 reden wir von der Überfliegerkarte schlecht hin, welche Gerüchten zufolge nur in der Form kam, weil AMDs Architektur stärker eingeschätzt wurde als sie war. Die Zukunft wirds uns zeigen.
B
Besterino
6,906 Kommentare 3,474 Likes
Was isn eigentlich enormal?
B
BudSpencer
Wie die Fanboys keine Kritik am Artikel ihres Forenbetreibers vertragen können, selbst, wenn diese gerechtfertigt ist...
"ich hab aber voll viel gelernt und die sind alle nett zu mir!'
escosse
22 Kommentare 2 Likes
Und bei mind. 2GB pro Speicherchip (GDDR7) sind 32GB gemeint. Nicht 16GB.
Megaone
Du kannst Igor kritisieren, wie es dir gefällt. Das musst du nur mit dir und Igor ausmachen. Ich hab mit Igor auch schon über diverse Dinge diskutiert, bei denen ich für mich zu einer anderen Einschätzung gekommen bin. Unabhängig davon habe ich deine Kritik nicht kritisiert, du kannst kritisieren, was wann wo du immer es möchtest. Ich habe meine Meinung zu dieser Thematik geäussert. Ich bin weder ein Fanboy, und deine Kritik macht dich für mich auch nicht zum Hater. Wobei deine Reaktion darauf diesbezüglich für mich Bände spricht. Aber was will man erwarten in einer allzeit bereiten hochmoralischen Gesellschaft, die immer hyperventilierend Gewehr bei Fuss steht, um in den Kampf für das Gute zu ziehen und dabei jedes Maß und Ziel vermissen läst und dabei die eigentlichen Probleme aus den Augen zu verliert. Das färbt zuweilen ziemlich auf den Einzelnen ab.
In diesem Sinne.
Allen einen schönen Sonntag
Samir Bashir
