Allgemein GPUs Latest news
NVIDIA focuses on power: RTX 5090 with 600W, RTX 5080 at 400W
NVIDIA is planning to launch the next generation of GeForce graphics cards, codenamed “Blackwell”, which are expected to consume more power than the current RTX 40 series. According to the leaker Kopite7kimi, the upcoming series, which includes models such as the RTX 5090 and RTX 5080, will have higher thermal design power (TDPs) than their predecessors. This information is particularly relevant for users who also need to consider energy consumption when purchasing graphics cards.
The TDP is a measure of how much power a GPU needs to work effectively and provides information about the demands placed on the cooling system and power supply. According to the latest reports, the RTX 5090 will have a TDP of 600 watts, which corresponds to an increase of 33 percent compared to the RTX 4090, which is rated at 450 watts. The RTX 5080 could have a TDP of 400 watts, which represents an increase of 25 percent compared to the RTX 4080. The RTX 5070 model is expected to be in the 250 to 275 watt range, which represents an increase of around 13 to 15 percent compared to the RTX 4070.
These increased TDP values could have an impact on the choice of power supply. Users thinking about purchasing one of these new graphics cards may need to upgrade their power supplies to handle the higher power consumption. This is especially important for those running systems with a high number of other power-hungry components.
A table showing the possible TDP values of the upcoming RTX 50 series compared to the current models can help to illustrate the differences more clearly:
TDP (RTX 40 series) TDP (RTX 50 series) Increase in percent
450 W 600 W 33%
320 W 400 W 25%
200-220 W 250-275 W 13-15%
However, actual power consumption in real-world applications may vary. Experience to date with the RTX 40 series shows that the cards often consume less energy in typical gaming scenarios than the specified TDP values. Only in particularly demanding applications, such as ray tracing or intensive GPU benchmarks, do the cards approach the specified TDPs.
Some power supply manufacturers such as Seasonic and Cooler Master have already included higher TDP values for the new NVIDIA GeForce RTX 50 “Blackwell” GPUs in their lists. This could be a further indication that the higher performance requirements are realistic.
At the moment, there is limited information on the technical specifications and exact configuration of the upcoming GeForce RTX 50 series. However, NVIDIA is expected to unveil the new generation at CES 2025. Until then, it remains to be seen what the actual specifications of the final products will look like. In the meantime, users should consider whether their current system is up to the demands of this new GPU generation or whether an upgrade is necessary.
Source: Kopite7kimi via X
Case39
2,573 Kommentare 983 Likes
Irgendwie habe ich den Eindruck, das Blackwell Gaming nicht so der Hit wird....
s
samhayne
117 Kommentare 87 Likes
Denk auch… ein neues Effizienzwunder gibt’s vermutlich erst wieder mit wirklich neuem Fertigungsprozess.
Sowohl TSMCs 4N Prozess für die 4000er als auch der vermutete 4NP Prozess für die 5000er sind halt beide nur Derivative des 5nm Nodes.
Erst mit 3nm wird sich der Verbrauch angeblich wieder um 25-30% senken.
Deutlich mehr Performance wird das Ding aber trotzdem liefern… wenn die Gerüchte um 50% mehr CUDA-Cores und der Wechsel zu GDDR7 VRAM nicht völlig verkehrt sind.
A
AkShen
33 Kommentare 5 Likes
Ich hoffe auf die 8000er von AMD...
Ich denke Nvidia muss verstehen, dass Stromverbrauch nicht mit Nachhaltigkeit zusammenpasst. Jede Generation ein neues/Leistungsfähigeres Netzteil auch nicht. Dafür soll ich dann auch noch horrende Preise zahlen, damit Nvidia utopische Gewinnmargen einfährt.
Ich hoffe auf eine AMD Karte Max. 300W mit Leistung 4090 ggf. einen hauch mehr. Den Raytracing und AI Bums können sie einfach weg lassen, dafür den Chip kleiner machen und max. 700 EUR ansetzen von mir aus eine 4K Version mit mehr als 16GB Vram.
Ruckzuck relevante Marktanteile und Nvidia kann weiter Massen an Karten an andere Unternehmen verkaufen.
Fühl mich auch verarscht, erst zahle ich drauf wegen der Kryptoheinis, jetzt wegen der KI heinis..
Würde mich nicht wundern, wenn die Basis des Erfolgs die Berechnungen und KI Ansätze aus Games/Gameengines sind. Fühlt sich aber so an, als würden Gamer nur noch notgedrungen mit Karten versorgt...
grimm
3,227 Kommentare 2,165 Likes
Naja, das war zu erwarten. Nachdem die Adas effizienter waren, als erwartet, konnte man sich entscheiden: aufwändig an der Architektur schrauben oder einfach mehr Sprit durchjagen.
Immer dran denken: schon die 4090 war theoretisch für 600 Watt ausgelegt.
b
bitracer
148 Kommentare 74 Likes
Nur weil der Connector das "kann" (wie wir wissen nur standfest unter Laborbedingungen und mit steck-mich-ganz-tief-rein-Roboter nit Sprinkleranlage) heißt das noch garnichts.
Und AMD hält sich bedeckt (spielt aber in den Augen der allermeisten kaum eine Rolle)
LEIDER passen die Spieleentwickler ihren Hardwaredurst immer noch an die inzwischen 1,6k€-Speerspitze mit 400W+ an und sagen zu den Normalos: "Friß oder Stirb!"
Sehr nachhaltig, indeed!
LurkingInShadows
1,397 Kommentare 592 Likes
@Samir Bashir : TDP = Volllastverbrauchsgrenze ; dass ist nicht unbedingt mit "effektiv arbeiten" gleichsetzbar; mit effizient wäre es das auf keinen Fall.
Y
Yumiko
688 Kommentare 337 Likes
Die weitaus meisten Spieler spielen die aktuellen Spiele auf AMDs RDNA Hardware - und das wohl ganz ohne Probleme.
Spiele mit RTX Logo scheinen auf dem PC nur besonders langsam zu sein, als wollten die dass man eine 2000€ Nvidia Karte kauft :p
Beim Connector sind wir uns hoffentlich alle einig: WTF
Das stimmt doch gar nicht. Gerade die Multiplattformtitel laufen auf den AMD Konsolen mit deutlich weniger Watt und 4k (gleiche Codebasis).
Auch die PC-Handhelds mit AMD drinnen lassen die Spiele mobil ohne großen Wattverbrauch laufen (zumindest unter Linux).
T
TheSmart
445 Kommentare 224 Likes
Ich denke...das Problem ist das die PC-Version bon Multiplattformspielen meist einfach nur schlecht portierte Konsolengames sind.
Und ein schlecht programmiertes Game braucht deutlich mehr Power durch die GPU als ordentlich programmierte Sachen,
Und zum allgemeinen Stromverbrauch der neuen Karten.. Naja wer sich eine Graka für 2000 Euro holt..dem wird der Stromverbrauch völlig egal sein.
Der dürfte eher in der Mittelklasse dann wieder interessant werden für die Spieler.
s
samhayne
Das Pferd springt hier nur so hoch wie es muss.
Das ist das alte Problem in der Spieleentwicklung - die Entwickler haben halt selbst oft dicke Grafikkarten und orientieren sich an denen.
Hab das selbst mal bei einem Spiel gemerkt, an dem ich gearbeitet hab - hab mir ‘nen uralten Laptop mit nach Hause und damit gearbeitet.
Auf einmal hab ich jedes Frame und jede Sekunde Ladezeit gespürt, die ich bei der Entwicklung verloren hab und dadurch viel effizienteren Code geschrieben. :)
Kommt drauf an… wenn man damit nicht nur zockt, sondern auch die KI gerne mal stundenlang über ein paar Videos rennen lässt, läppert sich das schon.
m
mattiii
40 Kommentare 22 Likes
da ich eh nur mit WQHD 100fps zock, dürfte mir meine 4070 Super noch ne Weile treue Dienste leisten.
Das mit nur maximal 220W. :)
Dr4x
97 Kommentare 66 Likes
Ich hoffe auf eine passable 5070, um meine 2080 Super austauschen zu können. Aber immer mehr Verbrauch bei den Karten finde ich nicht gut. Mal schauen, wie die Specs letztendlich aussehen und was AMD mit den 8000ern noch bringt.
A
Amco1982
9 Kommentare 3 Likes
Ich bleibe einfach bei meiner 4080 non Super. Spiele eh nur in 1440p. Das sollte die nächsten 2-3 Jahre ausreichend funktionieren.
GPUModder
86 Kommentare 34 Likes
Wenn die Entwicklung so weiter geht, na dann Prost Mahlzeit. Karten werden immer teurer. Spiele immer leistungshungriger. Von Raytracing voll nutzen zu können im höheren FPS Bereich sind wir auch aus meiner Sicht weit entfernt. Ohne Upsampling Helferlein, sind manche Titel mit Midrange Karten nur bedingt spielbar. Microtransaktionen in den Games. Häufig unfertige Games. Und und und..... Irgendwie habe ich das Gefühl mir ein neues Hobby suchen zu müssen. Naja, mal schauen was die Zukunft bringt.
Was ich allerdings doch immer sehr amüsant finde sind die Monitorhersteller mit ihren (Achtung Übertreibung) 1200 hz 4K Panelen. Faktisch gibt es keine Hardware die diese Bilder überhaupt zaubern kann. Weckt bei mir irgendwie die Erinnerung an den Mega Pixel Wahn der Digicams. Kleiner Sensor aber viele Mega Pixel. Qualität der Bilder sogar eher schlechter. Aber Hauptsache man kanns aufs Marketingpapier schreiben. ;)
m
mattiii
damit geht sogar 4K locker, wenn man die Regler bedienen kann.
LurkingInShadows
Immer eine Frage der Games, der Auflösung und der Sucht nach Details.
Bin bei 1080p und im Jänner von 4770k & HD 7970 auf 7800X3D und GRE umgestiegen....
Schon krass die Unterschiede zwischen der Version "alle Regler nach links" und der "alle Regler nach rechts"; wirkt meist wie komplett andere Games.
Und ja der Build fadisiert sich immer noch, während der Alte zum großen Föhn angeblasen hat.
m
mattiii
deswegen bin ich ja auch wieder zurück zu WQHD. Wo geht, nun auch alle Regler nach rechts. xD
Wobei das gar nicht sein muss, weil auf hoch oder sehr hoch siehts fast genauso gut aus, quält aber die Hw nicht so und man hat noch mal bissl mehr Fps.
chippi
24 Kommentare 38 Likes
Die 8800xt wird wohl auf knapp unter der 7900xt Leitung und 4080 in Raytracing landen mit 16 GB RAM. Dafür aber wesentlich günstiger werden und hoffentlich auch energiesparender. Die 7900xt mit 20 GB und die 7900xtx mit 24 GB werden erhalten bleiben für alle die mehr RAM haben wollen.
Von AMD wird die kommende Generation keine High End auf Niveau der 4090 kommen!
Hintergrund wird wohl hauptsächlich die Embargos von HighEnd Chips nach China sein. Die US Regierung erlaubt ja hier nichts was auf 4090 Niveau kommt zu verkaufen. AMD spart sich hier die Entwicklungskosten und wird sich eher auf die PS5 Pro und sonstige Konsolen konzentrieren. Neben AI natürlich ;-)
S
SpotNic
1,115 Kommentare 482 Likes
Also ich sehe das irgendwie etwas entspannt. 1. ist mein Hauptzeitvertreib nicht Zeit mit Games zu vertrödeln, als dass 3, 4 oder 500 Watt für die paar Stunden eine Rolle spielen würden, zweitens sind das alles nur Mutmaßungen und die letzte Version (4xxx) hat gezeigt, dass es doch nicht so heiß gegessen wie gekocht wurde.
Was Daueranwender mit KI oder sonstwas angeht ebenfalls, ich kann mir nicht einen Ferrari kaufen, den zum Alltagsauto machen und mich dann darüber beschweren, dass die Spritrechnung höher ist als bei einem potenten Diesel der zwar weniger Spaß macht und schlechter aussieht, dafür aber etwas effizienter ist.
Ich denke, der ein oder andere sollte in der Debatte vielleicht auch einmal die Kirche im Dorf lassen. Wir wissen noch garnicht wie das Leistungsaufnahmeprofil der neuen Karten aussehen wird. Am Ende entscheidet der Nutzer ob es einem in Sachen Anschaffung und Betriebskosten wert ist oder nicht, aber wir reden hier immer noch von Karten die in den meisten Fällen für den Zeitvertreib genutzt werden und hier liegt die ökologische Entscheidung zu aller erstmal beim Nutzer und nicht beim Anbieter... Wenn euch der Planet so wichtig ist und ihr der Meinung seid, ihr rettet die Welt mit 50 Watt weniger bei der GPU dann spielt in Summe weniger oder schraubt die Werte runter. Stellvertreterkriege und Forderungen, die "anderen" (Hersteller, Nutzer, Spieleentwickler) sollen Dinge lösen die Euch wichtig sind bringen nicht sonderlich viel, so funktioniert die Welt leider nicht.
Im Gegenzug könnte man auch 2 x die Woche mit dem Radfahren, die RGB Beleuchtung im Gamingzimmer für die Zeit des Spielens auslassen, das Aquarium 2 stunden weniger Beleuchten oder die Außenbeleuchtung der eigenen Hütte weniger nutzen - wenn es einem denn wirklich wichtig wäre.
Da spielt eine Grafikkarte in der Klasse nun wirklich eine untergeordnete Rolle.
grimm
Wenn der Strom aus regenerativen Energien stammt, ist es eh bums. Dann bleibt nur noch die Kostendiskussion ;)
Samir Bashir
