NVIDIA is on the verge of launching its new GeForce RTX SUPER mobile GPUs, which improve specifications and improve performance compared to existing GeForce RTX mobile GPUs. It looks like PCGamesN has got an internal slide in hand that shows up to 50% better performance of each SUPER variant compared to the older non-SUPER siblings. The Turing Refresh or GeForce RTX SUPER Mobility GPU series is expected to be launched soon, with several variants appearing repeatedly in leaked benchmarks. We've seen some rumors about specifications for different GPUs, but the closer we get the launch, the more information we're likely to get, whether through official or unofficial channels.
The film in question, which PCGamesN got its hands on, appears to come from an internal press deck that shows two SUPER variants with their respective performance. GPUs include the GeForce RTX 2080 SUPER and the GeForce RTX 2070 SUPER. Performance is measured with DLSS On and DLSS Off. Surprisingly, the slide does not mention the other SUPER cards that we know will be available for laptops in the next quarter, such as the RTX 2060 SUPER, the GTX 1650 SUPER series, and also does not mention the RTX 2080 Mobility, the current flagship series.
![](https://www.igorslab.de/wp-content/uploads/2020/03/NV-Super-02-1024x576.jpg)
NotebookCheck's colleagues had reported earlier on which cards might reappear in Nvidia's mobility portfolio. In summary, this would look like this:
Graphics Card Name | NVIDIA GeForce GTX 1650 SUPER | NVIDIA GeForce GTX 1650 Ti Notebook | NVIDIA GeForce RTX 2060 SUPER | NVIDIA GeForce RTX 2070 SUPER | NVIDIA GeForce RTX 2080 SUPER |
Codenamed | N18P-G61 | N18P-G62 | N18E-G1R | N18E-G2R | N18E-G3R |
Architecture | Turing TU117 | Turing TU116? | Turing TU106 | Turing TU104 | Turing TU104 |
Process Node | 12nm FinFET NVIDIA | 12nm FinFET NVIDIA | 12nm FinFET NVIDIA | 12nm FinFET NVIDIA | 12nm FinFET NVIDIA |
Sms | 14 | 16 | 34 | 40th | 48 |
CUDA Cores | 896 | 1024 | 2176 | 2560 | 3072 |
Vram | 4GB GDDR6 | 4GB GDDR6 | 8 GB GDDR6 | 8 GB GDDR6 | 8 GB GDDR6 |
Memory Bus | 128-bit | 128-bit | 256-bit | 256-bit | 256-bit |
Memory Clock | 12 Gbps | 12 Gbps | 14 Gbps | 14 Gbps | 14 Gbps? |
Memory Bandwdith | 192 GB/s | 192 GB/s | 448 GB/s | 448 GB/s | 448 GB/s? |
TGP (Total Graphics Power) | 35W (default) 50W (Max-Q) |
115W (default) 80 (Max-Q) |
150W+ (standard) 80 (Max-Q) |
Source: PCGamesN
