GPUs Latest news
NVIDIA’s GeForce RTX 4060 Ti and RTX 4060 should be on the market as early as around May – Economical and efficient
Our colleagues from WCCFTECH had already reported that the GeForce RTX 4060 Ti AD106-350 and RTX 4060 AD107-400 GPUs with a power consumption of up to 115W are to be released in May. It is expected that these cards will hit the market after the release of the RTX 4070, which is scheduled for release on April 13 this year.  It is reported that the PCBs (Printed Circuit Boards) of the two cards will have some additional details. The NVIDIA GeForce RTX 4060 Ti is powered by an improved version of the Ada GPU architecture, which promises higher performance and efficiency. It is also rumored that the card will come with 8GB of GDDR6 memory, making it a potentially powerful choice for gamers and content creators in the lower mid-range.
The Ti variant is also expected to come with an improved cooling system to ensure that the card stays cool even during intensive use. This is an important factor to ensure that the card can also deliver high performance permanently and under load (Boost Steps). Another feature expected on the NVIDIA GeForce RTX 4060 Ti is support for ray tracing and AI-based technologies like DLSS (Deep Learning Super Sampling). These technologies significantly improve the graphics quality of games and other applications, making them more realistic overall.
Possible NVIDIA GeForce RTX 4060 Ti specifications (rumor)
The CUDA cores are one of the most important components of the graphics card and enable the GPU to process data and execute tasks. With 4352 CUDA cores, the NVIDIA GeForce RTX 4060 Ti will be able to perform powerful calculations and deliver high-end gaming and VR experiences. The graphics card will also have an 8 GB GDDR6 memory, which will be driven via a 128-bit bus interface at 18 Gbit/s. This means that the card will offer an impressive 288 GB/s bandwidth, which is essential for fast and efficient loading of textures and graphics in games.
The GDDR6 memory is also faster and more energy-efficient than its GDDR5 predecessor. In addition, the NVIDIA GeForce RTX 4060 Ti comes with 32 MB of L2 cache on board the GPU, which is an 8x increase over the GeForce RTX 3060 Ti. The L2 cache is a fast memory area that will help the graphics card store and access frequently used data quickly to further improve performance.
Source: WCCFTECH
The graphics card is expected to use the PG190 SKU 361 PCB. Leaked PCB photos revealed that the Founders Edition uses the standard 16-pin 12VHPWR connector, while custom models are once again free to use both standard 8-pin connectors and the newer 16-pin connectors. It is rumored that in the end it is still much cheaper to use only 8-pin connectors. As for TBP, the card will probably be between 150-160W, which is about 25% less than its predecessor, the RTX 3060 Ti.
For the GeForce RTX 4060, NVIDIA is expected to use the AD107-400-A1 GPU, which is the fully functional AD107 Ada Die. Interestingly, the same configuration is also used by the GeForce RTX 4060 laptop GPU. The chip is expected to have 3072 CUDA cores and 8 GB of GDDR6 memory running at 18 Gbps over a 128-bit bus interface. This gives the card a bandwidth of 288 GB/s and all this with a reference TDP of 110 – 115 W. What also speaks for the notebook genes is the electrical connection of the PCIe port, which only uses 8 lanes instead of the 16.
Furthermore, the GPU is supposed to have 24 MB of cache (L2). The price of the NVIDIA GeForce RTX 4060 should be 35% lower than that of its predecessor, the RTX 3060 12 GB. While previous rumors suggested that the card would use a PG190 PCB, our information and that of WCCFTECH suggests that it will use the PG173 SKU 371 PCB design instead. Probably the PG190 variant is used by the FE and the PG173 by the reference AIC boards.
Like the RTX 4060 Ti, the non-Ti variant will also make use of the standard 8-pin connectors for the most part, and we can certainly expect to see some nice mini-ITX variants of the card as well, which will make for some really efficient micro-sized gaming PCs. Using the rumored “reference” boost frequency of up to 2535 MHz, the NVIDIA GeForce RTX 4060 Ti should offer a computational performance of around 22 TFLOPs, with the AIB models reaching a performance of almost 24 TFLOPs.
Source: KittyYYuko
The 3070 Ti was priced at $599, so the 4060 Ti would have to be $399 to be a worthy successor to the 3060 Ti, which had the same MSRP. The biggest problem is that while the card performs well at 1080p, it becomes a liability at higher resolutions due to the weak 128-bit bus interface and the use of the slower G6 memory instead of the G6X memory. The card would represent an extremely efficient design in the 150W TDP range, but the rest remains to be seen until the the the card is launched and the reviews appear.
NVIDIA GeForce RTX 40 graphics card lineup (via WCCFTECH)
GRAPHICS CARD GPU PCB VARIANT SM UNITS / CORES MEMORY / BUS MEMORY CLOCK / BANDWIDTH TBP POWER CONNECTORS LAUNCH
NVIDIA Titan RTX ADA AD102-400? TBD 144 / 18176? 48 GB / 384-bit 24 Gbps / 1.15 TB/s ~800W 2x 16-pin TBD
NVIDIA GeForce RTX 4090 Ti AD102-400? TBD 144 / 18176? 24 GB / 384-bit 24 Gbps / 1.15 TB/s ~600W 1x 16-pin TBD
NVIDIA GeForce RTX 4090 AD102-300 PG136 128 / 16384 24 GB / 384-bit 21 Gbps / 1.00 TB/s 450W 1x 16-pin Q4 2022
NVIDIA GeForce RTX 4080 AD103-301/300 PG139 SKU 360 76 / 9728 16 GB / 256-bit 23 Gbps / 716.8 GB/s 320W 1x 16-pin Q4 2022
NVIDIA GeForce RTX 4070 Ti AD104-400 PG141 SKU 331 60 / 7680 12 GB / 192-bit 21 Gbps / 504.0 GB/s 285W 1x 16-pin Q1 2023
NVIDIA GeForce RTX 4070 AD104-251/250 PG141-SKU 345/344/343 46 / 5888 12 GB / 192-bit 21 Gbps / 504.0 GB/s 200W 1x 16-pin / 8-pin Q2 2023
NVIDIA GeForce RTX 4060 Ti AD106-350 PG190 SKU 361 34 / 4352 8 GB / 128-bit 18 Gbps / 288.0 GB/s 160-150W 1x 16-pin / 8-pin Q2 2023
NVIDIA GeForce RTX 4060 AD107-400 PG173 SKU 371 24 / 3072 8 GB / 128-bit 18 Gbps / 288.0 GB/s 115-110W 1x 16-pin / 8-pin Q2 2023
NVIDIA GeForce RTX 4050 AD107? TBD TBD 6 GB / 96-bit? TBD 100W 1x 16-pin / 8-pin Q3 2023?
Source: WccfTech Twitter
Brxn
257 Kommentare 71 Likes
Kann mir einer erklären warum bei der 40er Generation das Speicherinterface so dermaßen kastriert wird? Ne 4060 mit 128bit ... rly? Ne 4070ti mit 192bit??? Wtf! Sind das lediglich "Sparmaßnahmen", um Gewinnmaximierung zu erreichen? Hat das was mit Strömen zu tun, die anders nicht beherrschbar wären? Oder wären die mid-range Karten dann einfach zu gut, so dass die überteuerten Spitzenmodelle sich nicht mehr verkaufen würden?
Ich finds ne Frechheit... ohne natürlich den Grund dafür zu kennen. Vielleicht gibt's ja auch nachvollziehbare Gründe für die Kastration
Grüße 🖖
AB5TAUB3R
213 Kommentare 85 Likes
das würde mich auch brennend interessieren :unsure:
DrDre
248 Kommentare 98 Likes
Gibt 2 Szenarien:
1. Karten wären zu gut und würden zu lange 'halten', bevor was neues und schnelleres her muss.
2. 8GB Speicher ist eigentlich ein NoGo, dient auch nur der Nutzungsdauer. Spiele und Anwendungen brauchen immer mehr, daher muss eher was neues gekauft werden.
Die ARC 770 limited werden immer interessanter 😀
Brxn
Auf jeden Fall. Team Blau hatte nicht den besten Start. Aber als QuasiNeueinsteiger in das GrafikkartenBusiness ist das zu verzeihen. Was VRAM und Speicherinterface angeht sieht die A770LE eigentlich ganz ok aus aus. PCIe 4x 8 is n bisschen merkwürdig...aber der Preis is echt nett. Ok, die Performance is ausbaufähig, vielleicht holen TreiberUpdates noch was raus. Bin echt gespannt was die mit Battlemage an den Start bringen. Evtl führt es echt dazu, dass Team Green sich nicht mehr so nen Sc***ß erlauben kann.
Grüße 🖖
Derfnam
7,517 Kommentare 2,032 Likes
Arc hoher Verbrauch.
Brxn
Joar, da bin ich von AMD ehrlich gesagt aber auch n bisschen enttäuscht. Ich meine wenn man die RasterLeistung nimmt, da ist AMD ja eigentlich immer vorne, und das über die WattZahl der RasterLeistung von NVIDIA gegen rechnet, dann war das für meine Beobachtung zumindest fast gleich. Bei raytracing und idle aber voll schlecht.
Grüße 🖖
Derfnam
Ist dir das Wortspiel entgangen?
Brxn
Ähm nein?!! Hätte ich es besonders würdigen sollen? Sorry dafür. Der arc hohe Stromverbrauch scheint n Treiber Problem zu sein, genau wie bei AMD.
Also relativiert sich das noch im Laufe der Zeit
Grüße 🖖
AB5TAUB3R
hrcn
21 Kommentare 21 Likes
Solche Formulierungen habe ich ja eher von Nvidias Pressematerial erwartet und nicht von euch. 8GB sind für alles, was irgendwie Anspruch hat "Mittelklasse" zu sein am Ende. Das sieht man Bei Spielen wie Hogwarts Legacy oder TLOU gerade sehr deutlich.
Ich finde Nvidias Geiz bei der Speicherausstattung ehrlich gesagt komplett zum kotzen, vor allem wenn gleichzeitig auch noch das Interface stark beschnitten ist. Wenn man dann auch noch den Preis, den Nvidia vermutlich aufrufen wird berücksichtigt, ist das am Ende ein ziemlich schlechtes Paket.
A
ArcticWolf
52 Kommentare 24 Likes
Ich fand den kompletten Text ziemlich schwach und komisch geschrieben. Bin aber nicht am Rechner um da jetzt mehr Beispiele einzufügen.
Zur GPU. Ich habe da mittlerweile die Hoffnung bei nvidia nahezu aufgegeben. Ein gutes PLV gibt's nicht mehr. Ironischerweise ist die 4090 aufgrund ihrer Leistung und dem Pluspunkt der schnellsten GPU im Verbraucherbereich die einzige deren (hohen) Preis ich nicht bemeckere.
Brxn
Seh ich ähnlich, zwar ist der Preis der 4090 auch nicht wirklich gerechtfertigt, aber der der das schnellste Pferd im Stall hat, kann nun mal den preis bestimmen.
Kann nur hoffen, daß ein signifikanter Teil der Käufer seine Stimme gegen nvidia und ihre Preis- & TechnikPolitik erhebt, indem er entweder AMD kauft (Raytracing ist nicht alles) oder diese Runde mal aussetzt und nicht aufrüstet .
Im Kapitalismus ist eben deine Kaufentscheidung das Zünglein an der Waage.
Grüße 🖖
Samir Bashir
