The suffering curve often points steeply down quickly enough, just because you have once again killed a cable. Let's just do it, when it's over and not rolling by. It was stupid, but you have enough of it. At least if you change the technique and/or what breaks. In the end, you have only two solutions left…
Either you finally clean up (just the thought, nene), or you make sure that the cable is harder to take than office chair, rolls and editor's life weight together. There is even such a thing and we even had it on the shelf for a long time without taking any further notice. Every day gadgets and tinneff reach us and so there is a kind of corner of good deeds for all these things. Once, when there is a gap, it is sniffed through and also discarded.
But what the hell do you do with a supposedly unbreakable USB cable? You use things like the Nonda ZUS Super Duty Adapter Cable for a while and then you find out in amazement: Number 5 is alive! And so we dutifully work out for a short time what the information requirement has given us along the way. Sweet cat videos are even available later, so something similar, but what else you can do, shows us the Youtube community right away. And that's a lot.
But back to the cable. At 1.2 m, it is a bit short, but it is still enough to charge the smartphone on the desk at the floor socket arrangement. Interesting now is the surrounding and inside. Because something has to come from a certain stability compared to the cheap rubberized Dongguan standard cable.
An idea? We don't need a highly complicated submarine cable, but in the end you have more strength than the free IKEA package tape from the roll can ever offer. The Kevlar sheathing with an intricately insulated interior also provide the nice rolling resistance together. 10 years warranty sound good at first, hardly any office chair can do that.
This also ends the voluntarily inserted advertising block and we are looking forward to the following videos completely relaxed. Incidentally, anyone can create such a clip and send it to the manufacturer. Or just watch some people pretend to… Let's start with the direct connection to the roll chair and then simply increase ourselves side by side.
And now: please turn around!
