Just under 28 euros is not cheap, but still significantly cheaper than an ARGB fan from Corsair. Blacknoise advertises the Noiseblocker BP12x-PS-BL PWM ARGB as a particularly quiet running bionic fan, which relies on the proven rotor blade design and a magnetic barometric bearing. The whole rotor is not white, but transparent and is illuminated from inside the hub. The ARGB control is compatible to all motherboards with 5V ARGB header, no matter what the manufacturer calls it now.
On the next page you will see how and what we test and why. Understanding the details is extremely important in order to be able to objectively classify the results later. The differences between many models are more in the details and THE best fan for all situations can hardly exist. There is a certain optimum in every situation and of course there are also good all-rounders. But they usually have their price.
The BL in the name stands for Black Edition and therefore there is also a black frame with excellent decoupling. 140,000 hours MTBF is also a certain security and self-confident statement. These fans are in the range of 25 to 30 euros per piece street price of course in the upper class. Whether money also aerates and deaerates well, we’ll see today. After the test you are always smarter anyway and we can also already spoil that this specimen runs much better than the defective test sample from the first comparison. Of course, we are still testing this fan.
Form factor | 120 mm |
Starch | 25 mm |
PWM | Yes |
RGB | ARGB |
Decoupled | Yes |
Color Frame | Black |
Accent color | none |
Color rotor | Transparent |
Weight in g | 120 |
min. speed | 0 |
max. speed | 1500 |
Volume flow m3/h | n/a |
Flow rate CFM | 58.1 |
static pressure mmH2O | 1.8 |
Sound pressure dBA | 21.1 |
Life Time hrs | 140000 |
Noiseblocker NB-eLoop X B12-PS ARGB Black Edition, 120mm (ITR-B12X-PS-BL)
Lagernd im Versandlager - Lieferzeit 2-5 Werktage | 19,89 €*Stand: 05.10.24 23:47 | |
Lagernd | 19,90 €*Stand: 06.10.24 00:47 | |
Lieferzeit 7-10 Werktage | 22,89 €*Stand: 06.10.24 01:01 |
28 Antworten
