Artificial Intelligence CPU Latest news
New speed king? Ryzen 9 9950X allegedly reaches 5.85 GHz
According to reports, the AMD Ryzen 9 9950X will be the first CPU of the Zen 5 architecture and will be able to boast a maximum clock frequency (FMAX) of up to 5.85 GHz. This would give it the same FMAX value as its predecessor, the Ryzen 9 7950X.
Source: Leonardo.ai
Technical data
  • Cores/threads: 16 cores / 32 threads
  • L3 cache: 64 MB
  • Base clock: 4.5 GHz
  • Boost clock: 5.7 GHz
  • Maximum clock (FMAX): 5.85 GHz
  • TDP: 170 watts (up to 200 watts with PBO)
  • Socket: AM5
  • Graphics: Integrated AMD Radeon graphics
Performance
Initial benchmarks of the Ryzen 9 9950X show that it can achieve the performance of the Core i9-12900K at just 60 watts. This is an impressive result and indicates that the Zen 5 architecture offers a significant performance gain over the Zen 4 architecture.
Comparison with Zen 4
CPU FMAX Boost clock
Ryzen 9 9950X 5.85 GHz 5.7 GHz
Ryzen 9 7950X 5.85 GHz 5.7 GHz
Ryzen 9 7900X 5.70 GHz 5.6 GHz
Ryzen 7 7700X 5.50 GHz 5.4 GHz
Ryzen 5 7600X 5.45 GHz 5.3 GHz
Ryzen 9 5950X 5.05 GHz 4.9 GHz
The AMD Ryzen 9 9950X is set to be launched on July 31, 2024. The price is not yet known, but is likely to be well over 600 euros. The AMD Ryzen 9 9950X is a promising processor that should offer high performance and efficiency. The Zen 5 architecture appears to be a significant step forward and could once again challenge Intel in the battle for the CPU crown. The above information is based on preliminary data and leaks. It is possible that the actual values may differ from those stated here. The Ryzen 9 9950X is a high-end processor and therefore not suitable for every user.
Feature Value
Cores/threads 16 / 32
L3 cache 64 MB
Base clock 4.5 GHz
Boost clock 5.7 GHz
FMAX 5.85 GHz
TDP 170 watts
Socket AM5
Graphics Integrated AMD Radeon graphics
Source: Anandtech
DMHas
72 Kommentare 35 Likes
Ich warte schon sehnsüchtig auf die Zen 5 Generation und deren Tests! Mein Notkauf (7600X) benötigt einen Nachfolger mit mehr Kernen.
Tronado
4,263 Kommentare 2,311 Likes
" Erste Benchmarks des Ryzen 9 9950X zeigen, dass er bei nur 60 Watt die Leistung des Core i9-12900K erreicht"
Das wäre gar kein soo beeindruckendes Ergebnis. Hast du da nicht etwas verwechselt? Auf anderen Seiten wird z.B. ein Geekbench-Ergebnis eines 9900X gezeigt, der dann im MC deutlich über einem 12900K liegt.
a
anton_
164 Kommentare 71 Likes
"Original" hat der 9950 ja 170W TDP, Wenn er bei drosselung auf 60W den 12900K schlägt, würds ja so passen wie es geschrieben ist. der 9900x hat doch auch 120W regulär
Samir Bashir
