PSUs, PC Cases and Modding
A decent ATX 3.1 power supply for under 50 euros? Why the Deepcool PL550D 550 Watts (almost) manages it!
The Deepcool PL550D currently costs around 49 euros, making it the cheapest (almost) ATX v3.1 power supply on the market, even if it is advertised as ATX 3.0. This price would still be very low even for ATX power supplies of the previous generation. However, although the maximum output is limited to 550W, this device can withstand power peaks of [...]
NZXT at Computex: Airflow cases, new fans, brand new power supplies and a tour of the trade fair with many products
First of all, I would of course like to recommend the valuable trade fair video from me, because the tour and a nice explanation naturally provide a real live impression that no film in the world can replace. If you want to see two people really sweating (me because of the heat and NZXT because of the amount of explanations), I can only warmly [...]
Double test in a two-chamber case – Corsair 6500 Series Mid-Tower and the XH405i RGB Hard-Tube Custom-Loop Kit
After a long delay, today we are taking a look at the new dual-chamber case from Corsair, which generates powerful Carbide Air 540 vibes. As I also installed the XH405i RGB Hard-Tube Watercooling Kit as part of the test, you can expect plenty of pictures. So better get a large coffee to read the article today. To be precise, it was the Corsair [...]
Should you buy an ATX v3.1 power supply now or is ATX v3.0 enough? Here is the surprising answer!
The big question that many people are asking themselves: Is it still worth buying an ATX v3.0 power supply now? Recently, everyone has been asking me why they should still buy an ATX v3.0 power supply when the ATX v3.1 specification has long been on the market. However, this is also because very few people even understand that the main difference [...]
Cooler Master MasterCase EG200 and Sapphire Radeon RX 7600XT Pulse Review – What is a current eGPU good for on a notebook?
It’s clear to everyone that, for the most part, a laptop doesn’t come close to a desktop PC. This is particularly noticeable when you want to play games or use more powerful applications. Here you can clearly see that performance and quality are already limited. A gaming laptop can help, but even here there are severe limitations in [...]
Modder breathes new life into the RTX 2080: 16GB VRAM for more performance
Modders have once again set about modifying the older generation GeForce RTX 2080 graphics card from NVIDIA. This graphics card was originally released with 8GB of VRAM, but the modders have successfully upgraded it to 16GB. I have also linked a video at the end. The GeForce RTX 2080 was originally introduced by NVIDIA in 2018 based on the Turing [...]
Ground on the wrong track: Why only certain power connector pins melt and we should rethink PCs | Part 1 of 2
Some things are accidental discoveries and are actually so trivial that nobody even bothers to question the current flows in the PC and, above all, to measure them. We only ever measure the 12-volt rails and are happy. But with connectors such as the 12VHPWR or 12V2x6 over 6+2 pin, the 8-pin EPS and the 24-pin mainboard connection, does exactly [...]
DIY Modding: White Edition for small money – We paint a graphics card
During the review of the BeQuiet Shadow Base 800 FX, I simply felt the need to install a white graphics card. Since no adequate model could be found in the short term and I had a rough idea of what the whole story should look like, we did it ourselves without further ado. And even if this is not the holy grail of knowledge today, we can all [...]
Real case modding: sandblasting and coating with Cerakote
There are many hobbies (or ways to waste money and especially time) and one of them is case modding. And it is not meant in today’s article the assembly of purchased RGB-lit components, but still real manual work and customization. And so today we will write about our experience with sandblasting and coating with Cerakote. We, that is [...]
SHARKOON TK5m RGB Review – Compact budget case for ATX motherboards
As a constant in the budget segment, Sharkoon always knows how to surprise with unexpectedly good quality and excellent value for money. In this test, we want to find out whether the compact TK5m can do the same. Can you expect anything at all at a price of around 65€ despite four pre-installed ARGB fans? The market for inexpensive cases is [...]
HYTE Revolt 3 PC Case Revire – Cute cheese grater with a big potential
You could almost think that today there would be another review of the NZXT H1, which recently got a revised version, but no, this is about the Revolt 3 case from HYTE, a brand of the system dealer iBUYPOWER, which looks similar at first glance. According to their own statement, they want to “show their commitment to the DIY market.” [...]
Cybenetics ATX v3.0 Spec Power Excursions Calculator – Freeware tool for power supply calculation according to Intel’s specifications for load peaks | Download
We have already discussed the topic of load peaks with the upcoming graphics cards including PCIe 5.0 as well as the new ATX 3.0 standard and Intel’s statements on this topic in detail several times. But since in the end no one really knows what to do with all these standards and theory in their own practice, my friend Aris (Dr. Aristeidis [...]
Insights into ATX v3.0, ATX12VO v2.0 and PCIe 5.0 – When resource waste becomes the new standard | Investigative
The race for ever faster CPUs and above all GPUs is now producing such blossoms that even existing standards have to be softened or modified for the new energy waste offensive that soon every end consumer will have to save up for a portable nuclear power plant if they don’t want to be in debt with the energy supplier well into old age. To [...]
On bang and drop – power failure as a power supply killer
Who doesn’t know it, that moment of unbridled hatred when the power generally goes out. So when not only the fuse does its work, but the whole place suddenly goes dark? Storm or no storm, it doesn’t even have to be a direct lightning strike, which then gives the domestic electronics the final neck break. This is exactly what happened [...]
Corsair 7000D Airflow Review – elegance and function on a grand scale
With the generously dimensioned 7000 series, Corsair brings two full-tower cases with high-end requirements to the market. In this article, I want to put the feature-oriented Airflow version through its paces and find out if the 20kg Behemoth lives up to its claims. An all-in-one compact water cooling system can be installed by anyone, there is [...]
View behind the factory backdrops: This is how a power supply from Be Quiet is created! at the contract manufacturer (OEM) | Documentary
Since I’d like to go to the factories of the contract manufacturers and always try to take a look behind the scene, but just the cute little Corona virus lurks grinning behind every Far Eastern corner and i’m hämisch with a hearty “You can’t pass”, it must direct an older collection of images. The production is [...]
