Audio Audio/Peripherals Microphone Reviews
MXL AC-404 Review – How a flat surface microphone frees the desktop and not only makes streaming easier
The MXL AC-404 USB microphone tested by me today is a high-quality condenser boundary microphone, which is equipped with three capsules and offers a recording range of 180 °. I bought the good piece for 77 euros in a well-stocked specialty store, because with certain things I trust, for example, Thomann and the reviews left there by professionals more than Amazon with the most bought praise. Trigger of the whole thing is my acoustically really disastrous, because very reverberant office area, where recently also the criticism of the audio quality at various meetings accumulated. The boundary (or surface) microphone is a special microphone that is placed on a surface and picks up sound waves directly from that surface. It is often used in theaters, conference rooms, and other environments where unobtrusive miking is required. So now it’s also used in mine.
Yes, my webcam (Logitech C930) has an integrated microphone, but the distance between camera in me is about 80 cm. Even a large-diaphragm condenser microphone lying on the table and a streaming microphone didn’t really help, especially since the product for streamers still blocks my view of my OLED. We see on the picture below once the situation on my desktop, especially since I find spatially no other solution. We will of course hear the audio test comparing all four solutions in the course of the article. Which sounds best? Let’s be surprised!
But why a so-called conference microphone? I sometimes sit with it in my large meeting room and can then connect the part to the mini PC of the TV set, if once several people want to participate in an online meeting. So that’s why a boundary microphone like this makes sense. With a frequency response that ranges from 40 to 16000 Hz and a sampling rate between 44.1 kHz and 48 kHz, this microphone also guarantees decent audio quality (at least on paper). The integrated 16-bit Delta Sigma A/D converter with a THD N of – 0.01% also ensures clear and precise sound reproduction, and yes, there’s almost no noise either.
The scope of delivery includes a USB mini-B connection cable (for the microphone) and a USB A cable (for the PC) as well as a practical microfiber cleaning cloth. That’s all you get and all you need. Yes, it would work for half as well, however, it was important to me to solve a problem and not create another one. I wanted something really useful that would fit into my desk landscape and subordinate it visually.
The microphone is, of course, USB compatible and supports both USB 1.1 and 2.0, which means that it can be easily connected to both Windows and Mac computers without any additional driver installation. This makes it an ideal choice for various streaming and conferencing systems here at home (but not limited to), including, but not limited to, platforms like Zoom, OBS, Skype, WhatsApp, Telegram, and Facebook Messenger.
Another feature of the MXL AC-404 is its 3.5mm jack headphone output (in case you need it). The microphone is conveniently powered via USB from the computer, which eliminates the need for external power sources. In terms of design, the microphone is a sturdy combination of metal and plastic and presents in a sleek black finish. It measures 78 x 25 x 109 mm and weighs just 190 g. Many professional users appreciate the MXL AC-404 USB microphone for its outstanding audio quality and straightforward plug-and-play functionality. However, it is not only great for conferencing and streaming, but also for simple audio recording. One particular use case comes from a customer who installed the microphone on the ceiling of his rehearsal room and found that it delivered amazingly clear and usable sound (according to thomann.de).
Yes, all this makes of course curious and exactly why I bought the part then. Incidentally, there is the part also with LED headlights, but that was too much for me. In the end, it’s more of a work item that is supposed to be particularly conspicuous in that it’s not conspicuous at all. It just has to work.
47172-AC404Datasheet
1,694 Kommentare 1,030 Likes
Danke, interessanter Test! Das Flachmikrofon werde ich mir auch mal ansehen. Preis ginge sogar in Ordnung. Manchmal will man eben nicht das Mikrofon vorm Gesicht haben, oder (KH mit Boom) auch nicht wie ein Fluglotse oder ein Telemarketer erscheinen.
RedF
4,882 Kommentare 2,711 Likes
404 etwas unglücklich einen Fehlercode zu nehmen 😅
10,477 Kommentare 19,621 Likes
Gestern im Biergarten:
Antwort 7 Likes
SamSerious
21 Kommentare 7 Likes
Vielen Dank für den interessanten Erfahrungsbericht! Mit meinem MXL V67G bin ich auch sehr zufrieden, es wirkt nicht nur voll retro, sondern auch sonst absolut in Ordnung.
Wie verhält es sich denn bei solchen Grenzflächenmikrofonen mit mechanischen Tastaturgeräuschen? Wenn das Mikrofon auf dem Tisch liegt, dürften diese vermutlich mit eingefangen werden?
Andy197
196 Kommentare 96 Likes
Gegen das Rauschen gibt es ja lösungen von Nvidia 😉
Wie sieht es eigentlich aus mit dem getippse von mechanischen Tastaturen?
Habe mir auch das SC450 von Thomann gekauft, und es steht direkt vor mir. Die Nierencharakteristik ermöglicht eine klick freie Aufnahme meines paarungsrufes.
FfFCMAD
689 Kommentare 187 Likes
Habe vorhin rein gehoert, also fuer 70€ ist das mehr als Okay. Es sieht billig aus, es ist billig verarbeitet. Aber das Ergebnis stimmt.
Das Ergebnis zählt, solche Teile gibts auch für 250 Euro... Sind auch nicht viel besser
Opa-Chris
87 Kommentare 122 Likes
Das würde mich auch sehr interessieren!
Wie verhält es sich mit einer zweiten Person im Raum (ca. 1,0-1,5m rechts von einem entfernt)? Würde diese Person als Nebengeräusch gefiltert? Oder ist das Abhängig von der Soundkarte und deren Einstellungen/Kompetenzen?
Entschuldigt bitte diese Fragen, ich bin bei Audiofragen echt kein Experte 😅
Termy
40 Kommentare 18 Likes
Das klingt auf jeden Fall deutlich besser, als ich es erwartet hätte.
Neben der Frage bzgl mechanischer Tastatur würde mich noch interessieren, wie sehr das Ding die anderen Gesprächspartner auffängt? Klar gibt es heutzutage überall Echo-Unterdrückung, aber von perfekt ist die ja oft doch noch n Stück weg ;)
Wenn man während eines Gesprächs Protokoll führen oder einfach weiter arbeiten will, führt meiner Erfahrung nach an Kopfhörern (mit Boom Mikrofon) und richtig gutem ANC kein Weg vorbei. V.a. wenn man das Smartphone auf dem Tisch liegen hat hören die Gesprächspartner beim Tippen mit. Gerade mechanische Keyboards (hab selber eines) machen sich da bemerkbar, und ohne aktives Rausfiltern hören die Gesprächspartner mit. Mit Headset und richtig gutem ANC hören sie davon nichts (laut Freunden, die ich als Versuchskaninchen gefragt habe). Außer, man will den akustischen Eindruck geben, daß man fleißig mitschreibt 😁.
Videokonferenzen mit Headset sind uncool :D
Sitzt man auf 404 vor oder nach mehreren Halben 😁?
Ich muss es manchmal machen, wenn ich Schulungen und Arbeitsgruppen leite und da viel mit Maus und Keyboard machen muss oder soll, oder der Umgebungslärm schon stören könnte. Aber ja, schön geht anders. Wobei ich mich bei manchen VKs schon wie ein Fluglotse fühle, alle wollen sie zuerst landen, und bei jedem drängts.
Ghoster52
1,456 Kommentare 1,121 Likes
404 im Biergarten ist ok, auf dem Lokus kommt das nicht so gut... :ROFLMAO:
A
Aragornius
86 Kommentare 22 Likes
Sehr interessant! Gegen den Hall im Raum: Wie wäre es mit Schallabsorbern?
*andi*
5 Kommentare 5 Likes
Das kam mir beim lesen auch in den Sinn...
Auf anderen Kanälen hab ich gesehen das sie mit "Elgato Wave Panels" gute Ergebnisse erreicht haben - sogar in einer Lagerhalle... Nur sind die Dinger alles andere an günstig....
Follow Igor:
