Latest news Monitors
MSI QD-OLED gaming monitors: Firmware update brings DSC and other optimizations for an even better gaming experience
MSI releases a comprehensive firmware update for its QD-OLED gaming monitors MPG 271QRX QD-OLED and MPG 321URX QD-OLED, which brings numerous new features, bug fixes and optimizations.
Improved user-friendliness and flexibility:
One of the most important new features is the implementation of a DSC switch in the OSD menu. This allows users to enable or disable Display Stream Compression (DSC) to customize picture quality and bandwidth usage. Furthermore, an HDMI PC/Console switch has been added to the OSD for the MPG 271QRX QD-OLED, allowing users to select their preferred resolution regardless of the source device. In addition, the MPG 321URX QD-OLED now offers the option to choose between 24.5″ and 27″ screen sizes in the OSD to customize the size of the virtual screen to personal preference.
Optimized picture quality and HDR experience
MSI has also optimized the color reproduction in HDR mode to ensure a more accurate and uniform display of colors. In addition, a problem with color space clamping that could occur when HDR was enabled has been fixed. HDR modes now also save separate presentation mode settings to preserve individual customizations.
Other improvements and bug fixes:
The firmware update also fixes various language issues and image flickering when VRR is enabled. Users can now switch off the power LED in the OSD and the input delay and latency have been optimized. Furthermore, a problem with white lines at 2560×1440@360Hz (MPG 271QRX QD-OLED only) and a display error (dark screen) after switching VRR have been fixed. Finally, the behavior of the panel protection has been optimized.
2024.May.6th MPG 271QRX QD-OLED/MPG 321URX QD-OLED firmware updated
FW.010 Firmware update information
    • DSC switch added to the OSD to enable DLDSR and DSR modes.
    • MPG 271QRX QD-OLED: Added HDMI PC/Console switch in the OSD. (MPG 271QRX QD-OLED default setting is “PC” mode.)
    • (Update : 2024.May.6th 20:00 PM, update default setting from “Console” mode to “PC” mode.)
  • Support for a variety of aspect ratios, MPG 321URX QD-OLED allows selection between a 24.5″ and 27″ option, MPG 271QRX QD-OLED allows 24.5″.
  • Fixed Color Gamut clamping while HDR is enabled. HDR mode will now store separate present mode settings.
  • Optimized multiple language issues.
  • Fixed image flicker issue when VRR is enabled.
  • Added “Power LED” switch in the OSD to allows users to turn it off.
  • Input lag and latency optimization.
  • Fixed problem with white line during 2560×1440@360Hz. (MPG 271QRX QD-OLED only).
  • Fixed displayed abnormal (dark screen) after VRR switched.
  • Optimize a behavior of panel protect while protect completed that depends as executing power states.
Source: MSI
HowTo: MSI
The new firmware update for MSI QD-OLED gaming monitors offers a number of improvements that significantly enhance the image quality, usability and flexibility of the devices. Owners of an MSI MPG 271QRX QD-OLED or MPG 321URX QD-OLED monitor should therefore definitely install the update in order to utilize the full performance of their monitors.
Source: MSI
S
Savage_Sinusoid
20 Kommentare 6 Likes
Was es mit DSC, DSR und DLDSR auf sich hat, bedarf einer kurzen Erklärung.
DSR (Dynamic Super Resolution) ist eine NVIDIA-Technologie, bei der das Bild zuerst in einer höheren Auflösung (z. B. UHD) gerendert und dann herunterskaliert wird (z. B. auf Full-HD). Das kostet massiv Leistung, sorgt aber für eine bessere Bildqualität und lohnt sich damit vor allem bei älteren Spielen.
DLDSR (Deep-Learning Dynamic Super-Resolution) tut vom Prinzip her dasselbe wie DSR, aber rendert im ersten Schritt auf eine nicht ganz so hohe Auflösung (z. B. auf 1620p) und kompensiert die fehlenden Bildinformationen mit Hilfe eines neuronalen Netzes, ähnlich wie das weithin bekannte DLSS. Das sorgt immer noch für eine bessere Bildqualität als Rendering in nativer Auflösung, kostet aber deutlich weniger Performanz.
DSC (Display-Stream Compression) ist ein optionales Feature von DisplayPort 1.4, das "visuell verlustfreie" Kompression der Bilddaten ermöglicht. Dank DSC müssen für dieselbe Anzahl von Pixeln pro Sekunde deutlich weniger Bits pro Sekunde durchs Monitorkabel flutschen. Damit bekommt man sehr hohe Auflösungen bei sehr hoher Bildwiederholfrequenz hin.
Warum hat MSI nun in seine Monitor-Firmware einen Menüpunkt eingebaut, mit dem man DSC abschalten kann? Der Hintergrund ist, dass man DSR oder DLDSR nicht nutzen kann, wenn DSC aktiviert ist. Bislang war am Monitor DSC nicht abschaltbar, weswegen man einfach keine Chance hatte (DL)DSR einzuschalten. Mit dem neuen Menüpunkt kann man nun immerhin selber wählen, ob man das eine nutzen will oder das andere.
D
Das_B
9 Kommentare 1 Likes
Was mich brennend interessiert ist, wie gut ist eigentlich die Bildqualität wenn in 24,5 bzw. 27 Zoll-Modus umgeschaltet wird?
1080p Pixelgenau gehen ja rechnerisch nicht ausgehend von 32 bzw. 27 Zoll.
Samir Bashir
