Audio/Peripherals Headphones Headsets Microphone Reviews
Meze Audio 99 Classics and Meze Boom Mic as a Hi-Fi gaming headset with a real fun factor including burl wood and stainless steel
If you can pair excellent headphones with a good microphone without creating a fixed headset, thus remaining flexible in use and still easily outperforming most gaming headsets in terms of sound even without software ballast, then the manufacturer has done everything right. Meze Audio pairs the popular Meze 99 Classics from 2015 with a really good boom microphone and offers fun hi-fi for gamers too. Or to put it in a nutshell: extremely high-resolution and stable drivers with a lowered boom meet a suitable microphone with almost podcast quality.
I had already tested the Meze 99 Neo almost 7 years ago as a loaner and thought the iteration at the time was pretty decent, but had never managed to take a closer look at the “original”. Of course, this can be made up for if you suddenly find such headphones in combination with a boom microphone. This is exactly what we are looking at today, because I can already spoil the fact that you can easily compete with all the so-called gaming headsets, which usually offer less for a lot of money and then usually rely on software botox for the sound. The combination tested today doesn’t need these crutches at all, but can be operated honestly and resource-savingly even on the onboard sound of a mainboard. If you then want to use it as a smart remover for your earwax, you can create a real inferno with the help of powerful amplifiers. But that will come in a moment…
Despite all the spoilers, let’s take a quick look back, because that’s always part of the process when you’re testing a classic like this. The Meze 99 Classics headphones were launched back in 2015 by Meze Audio, a Romanian company, at a time when nobody claimed to want to own such a crossover project. The company was founded in 2009 by Antonio Meze, a passionate designer and musician. His aim was to develop headphones that are not only technically high-quality, but also impress with their timeless design and exceptional materials. The company places particular emphasis on the combination of precision craftsmanship and sonic excellence. Each pair of headphones is manufactured with a housing made of real wood, which gives each model an individual look and a warm, natural sound. And then as a headset by adding a matching microphone to the box? Yes!
The Meze 99 Classics headphones have a 40 mm driver unit, cover a frequency range of 15 Hz to 25 kHz and have an impedance of 32 ohms, which makes them easy to use on a wide range of devices, even mobile devices. With a very high sensitivity of 103 dB at 1 mW and 1 kHz, they offer high volume at low power, even onboard sound. A sensitivity as high as that of the Meze 99 Classics means that the headphones can still deliver an impressive volume.
This also makes them particularly suitable for use with mobile devices such as smartphones, which do not deliver as much power as dedicated amplifiers. The high sensitivity ensures efficient use of the available power without distortion or compromising sound quality. This offers a perfect balance of fidelity and ease of use, especially for mobile use or longer listening sessions. According to the manufacturer and Igor.
Scope of delivery and unboxing
Times are changing and Meze naturally has to tap into new groups of buyers. The Meze 99 Classics headphones with Boom Mic therefore offer a comprehensive package designed for music lovers, gamers and professionals alike. The headphones are supplied in a robust EVA carrying case that ensures safe transportation or can be disposed of immediately, depending on the user and application profile.
Two detachable cables are included: a shorter cable with a simple microphone and remote control for mobile use (that’s all the simple part is good for) and a longer one for home use, but without a microphone. A 6.3 mm adapter and an airplane adapter are also included, which underlines the versatility of the headphones. I would also have liked a balanced cable with a matching 4.4 mm plug, but thankfully I have enough of these in my cable collection. Just a tip for Meze.
I’ll include the technical data briefly at this point, as it saves too much fiddling with tables later:
The package also includes the Boom Mic, an omnidirectional microphone that ensures clear voice transmissions during meetings or gaming sessions. A Y-adapter allows connection to PCs or consoles with separate audio and microphone inputs. A small leather bag is used to store the cables and rounds off the high-quality accessories. This scope of delivery ensures flexibility in various application scenarios, whether at work, at play or simply when enjoying music
Yes, the fun doesn’t come cheap, but with a little searching you can find the combination for around 350 euros. Of course, that’s a lot of wood for the wood, but a Beyerdynamic MMX 300 (the name is also a program) for 300 euros isn’t really any cheaper. Woodworm versus plastic bomber? Exactly that! The look and feel are simply an included factor in this price range, as the Meze combination is also excellent in terms of performance.
And as far as performance is concerned, I naturally also measured the microphone quality and not just the headphone part. So there will be comprehensive measurement results and not just the usual gaming or hi-fi gobbledygook. Once again, here are the technical specifications of the Boom Mic:
C
Charger93
10 Kommentare 11 Likes
Sehr interessante Kopfhörer, die Markt kannte ich noch nicht.
Kurze Verständnisfrage: sind die 99 Neo die gleichen Kopfhörer "nur" ohne das Walnuss-Holz?
Ghoster52
1,525 Kommentare 1,191 Likes
Danke für den Test(y), den Meze hab ich oft gesehen aber nie so richtig auf dem Schirm gehabt.
Vielleicht läuft mir doch mal einer über den Weg, als Ersatz hab ich aber den Denon AH-D2000 mit Holzmuscheln.
Das wunderschöne Holz mit Klarlack überzogen ist ein Traum, gesehen haben ihn schon einige! 🥰
@ Igor
Ich hätte trotzdem ein Bitte, messen bitte den Durchmesser der Earpads, am besten innen & außen.
KH mit d=90mm Pads kaufe ich nicht mehr, das ist mir zu pupsig... 100-110 ist optimal(er)
Ich mag diese unscheinbaren "Bassbomber", es gibt ausreichend Musik wo der Tiefbass ab 30 Hz richtig gut kommt.
Da hörste bei einem AKG K702 oder Senni HD-800 einfach nüscht, obwohl Bass schon da ist.
echolot
1,177 Kommentare 919 Likes
"Der röhrende Hirsch" ist das Sahnehäubchen... :D
Materialauswahl ist schon sehr attraktiv. Damit könnte man alt werden.
10,840 Kommentare 20,534 Likes
@Ghoster52
Original-Ersatzteile (mit exakten Innenmaßen):
Zubehör aus Schaffell (eBay):
Der Hauptunterschied zwischen den Meze 99 Classics und den 99 Neo liegt in den verwendeten Materialien und dem daraus resultierenden Klangcharakter. Die 99 Classics haben Ohrmuscheln aus Holz, was ihnen nicht nur ein hochwertigeres und edleres Design verleiht, sondern auch den Klang wärmer und natürlicher erscheinen lässt. Im Gegensatz dazu bestehen die Ohrmuscheln der 99 Neo aus Kunststoff, was sie robuster und etwas leichter macht, aber den Klang minimal heller und weniger resonant wirken lässt. Beide Modelle teilen jedoch den gleichen Treiber und liefern daher insgesamt einen ähnlichen Klang, mit leichten Nuancen aufgrund der unterschiedlichen Gehäusematerialien.
C
Charger93
Besten Dank dir für die Klarstellung :)
Da ich derzeit mit dem MMX 300 Pro geliebäugelt habe ist das 99 Classic oder Neo eine interessante Alternative.
Mal schauen, was es wird.
1,830 Kommentare 1,142 Likes
Hört bzw ließt sich schon recht gut, und mir gefallen die Muscheln aus Wurzelholz auch - das Auge hört ja auch mit 😀.
Zu dem PU Kunstleder der Polster die Frage: wie sehr schwitzt man denn da, wo die aufliegen? Gerade im Sommer nicht ganz unwichtig für einen Hitzkopf wie mich.
Und, wenn Meze alternativ zu dem omnidirektionalen Mikrofon eins mit Nierencharakteristik anbieten würde, wär das für meine Zwecke noch besser. Aber allgemein schön, daß hier was Gutes aus kleinerer, europäischen Fertigung kommt. Kann man sich dann doch überlegen!
Ich habe hier auch bei 30 Grad nicht geschwitzt, aber es gibt mittlerweile auch genügend Austauschpolster am Markt, die man durchaus testen kann. Damit ändert man ggf. sogar die Sigantur deutlich, aber das ist halt wie immer das "Was passiert dann"-Prinzip :D
Niere habe ich nicht vermisst, weil: Das, was die ganzen Hersteller der Gaming-Headsets als Niere verkaufen, ist gar keine. Es ist wie hier, also omnidirektional, aber so ins Gehäuse gekapselt, dass nur die seitliche, partielle Öffnung den Schall durchlässt. Damit hat man auch eine Art Nierencharakteristik. Meze schreibt halt ehrlich, was es eigentlich ist, die andern, was es hätte sein sollen :D
_
_roman_
122 Kommentare 33 Likes
Die Kurve ist eine Frechheit vom Hersteller.
für ein 3€ Headset wäre so eine Curve akzeptabel.
ssj3rd
237 Kommentare 163 Likes
350€ (inkl. gutem MIC) empfinde ich bei guten Kopfhörern gar nicht mal als sooo teuer…
Ob die jetzt besser als meine Audeze Maxwell abschneiden vermag ich nun aber nicht zu sagen.
Saschman73
572 Kommentare 352 Likes
Danke für den ausfühlichen Test! 🙏
Ist das Absicht vom Hersteller das die Schlitze am Mikro vom Mund weg ausgerichtet sind?
Wenn ich versuche die Kapsel so zu verdrehen das die Schlitze Richting Pappalatur zeigen, geht das nicht weil durch die Vorspannung sich die Kapsel wieder in die Ausganslage zurückdreht.
Seit dem Reinfall mit dem Arctis Nova Pro bin ich extrem empfindlich was Mikrophonie angeht, aber damit hat das Meze Kabel überhaupt kein Problem!
Lediglich das es permanent dazu tendiert wieder in seine gekringelte Verpackungslage sich zu verdrehen stört am Tisch etwas.
Ich hoffe das legt sich mit der Zeit etwas.
Jetzt habe ich endlich einen angenehmen und guten Kopfhörer den ich auch zum Zocken verwenden kann!
Fehlt nur noch ein DAC/AMP mit Mikrofoneingang.
Alter.Zocker
116 Kommentare 79 Likes
Danke @Igor Wallossek für den abgelieferten Testbericht ;) Der Bestellfinger juckt zwar gewaltig, aber ich werde mich wohl dennoch vorerst zurückhalten: Erstens brauche ich privat doch eher weniger ein HEadset, da ich prinzipiell seit Jahren nicht mehr MMO-/ sonstigen Multiplayer-Kram spiele, wo neben dem Sound aus dem Game noch "verbale Kommunikation" mit Anderen nötig wäre. Zweitens besitze ich erst seit kurzem mit dem "Ananda-Nano" bereits einen für mein Empfinden im Bereich unter 1k Euro nur noch schwer zu toppenden Kopfhörer, was sowohl Wiedergabequalität als auch Tragekomfort angeht. Vielleicht wenn mein beruflich genutztes Wireless-HEadset "Plantronics Voyager 8200" irgendwann final den Geist aufgibt, steige ich wieder auf ein kabelgebundenes um zu Gunsten des besseren Sounds gegenüber BT-Wireless und mit mehr NAchhaltigkeit im Sinn (keine Akkus mit definitiv limitierender Lebenserwartung). Dann kommt diese Kombi aus Meze Classics 99 und Mic sicher zu mir, wenn es sie dann noch gibt und nicht durch was "Besseres" bereits selbst obsolet geworden ist...
D
Der Do
91 Kommentare 46 Likes
Generell fände ich Tests von Lavalier- oder Nachrüstmics sehr interessant, liebäugle grade mit dem SM-1 von Sharkoon um die DT-880 zum "Headset" zu machen...
Gute Idee. Ich frag mal rum... 😎👍
Ghoster52
Wie viel Messungen hast Du schon gesehen und KH angehört ???
Eine Messung vom DT770 sieht nicht besser aus und der hat seine Fangemeinde.
So eine kleine "Berg und Talbahn" hört man oft gar nicht und es gibt schlimmere KH, wenn man nur ins Diagramm blickt.
Solange es nicht so endet wie im Video, ist es schon mal gut... 😂:ROFLMAO:😂
Wie viele Kurven hast Du schon gesehen, also echte? Nicht das, was die Hersteller meist aufdrucken? Im Vergleich zur Harman-Kurve sieht das doch richtig gut aus. Man sollte aber mal den Sinn eines Sliders hinterfragen :D
Meze 99 Classics:
Sehr guter Planar-Kopfhörer:
s
scotch
163 Kommentare 112 Likes
Ich hab noch zwei ModMics von AntLion liegen. Einmal die USB Variante und einmal die Kabellose. Falls die hier noch nicht getestet wurden könnte ich die zur Verfügung stellen. Oder falls Sie jemand haben möchte dann gerne anschreiben.
Gabs schon mal vor langer Zeit, aber noch ohne Messungen:
Saschman73
Anfang 2025 soll angeblich die Nachfolgerversion raus kommen.
Dann vielleicht mit Messungen. 🤷‍♂️
Follow Igor:
