Allgemein GPUs Latest news Notebooks
AMD Radeon 780M – integrated RDNA3 graphics tested in 3DMark (LEAK)
The final driver for the integrated RDNA3 graphics is probably still a few weeks away. Nevertheless, some preliminary results on the Bilibili platform with the AMD Ryzen 9 7940HS processor, codenamed Phoenix, have now been published.
Source: AMD
This processor type features the latest AMD architectures like the Zen4 CPU with 8 cores and RDNA3 for graphics. Apparently, the focus is currently on the graphics, since no CPU benchmarks have been released at this time (with the exception of TimeSpy’s integrated CPU score). The leaker Bilibili provided two results, both on the same platform with DDR5-5600 memory. In the first case, the power was throttled to 54 W, in the other case to 25 W. As can be seen below, the power did not drop that much despite the halving of the power consumption:
Source: Bilibili
The AMD RDNA3 GPU called Radeon 780M has 12 compute units that are clocked with up to 3.0 GHz. According to the screenshots, it looks like the GPU is clocked with up to 2.8 GHz. Such a configuration delivered 2486 graphics points at 25W and 2791 points at 54W in 3DMark TimeSpy. Compared to the Radeon 680M (RDNA2 iGPU) available in the Rembrandt APUs, the processor is between 8 and 22% faster than the Radeon 680M depending on the configuration. There are of course different implementations of the 680M in the 6000U or 6000HX series, but the tested Phoenix APU also belongs to the HS series. More detailed results about the 680M can be found in the NotebookCheck database.
Source: Bilibili
Source: Bilibili
AMD has not yet confirmed when exactly the Ryzen 7000 APUs will hit the market, but the company has promised that the first “Phoenix” laptops should hit the market in March this year.
Source: Bilibili
Gamer
148 Kommentare 37 Likes
Wieder ein absolut konkurrenzloses Produkt von AMD. :love:
Casi030
11,923 Kommentare 2,339 Likes
Wenn man überlegt das der 5700G mit iGPU OC an die 1800P kommt,ist das schon ein ordentlicher Sprung ohne Ram und iGPU OC,da sollten 3000P locker möglich sein.
AuTomaton_20
46 Kommentare 18 Likes
Wen es interessiert, dieser timespy score entspricht in etwa dem einer GTX 680 von 2012 und ~200W TDP.
1,757 Kommentare 1,080 Likes
Wobei die iGPU in Phoenix den Score von knapp 2500 innerhalb einer TdP für die gesamte APU von 25 W hinbekommt. Und in einer derartigen APU gehen wahrscheinlich auch in Timespy doch 30 - 50 % der Leistungsaufnahme auf das Konto der CPU Kerne. Und dann ist der Vergleich der iGPU mit der GTX 680 eben doch ziemlich beeindruckend; um die 10 Mal die Perf/W innerhalb von 10 Jahren kann sich sehen lassen. Eigentlich ist der Faktor ja noch größer, denn die GTX 680 konnte das ja nicht alleine; da mußte schon noch eine (für damals) leistungsstarke (und hungrige) CPU mit im System dabei sein.
S
Sternengucker80
227 Kommentare 64 Likes
Das ganze jetzt noch als AM5 und den passenden Deskmini ( bitte mit CD Rom) dazu 😍😍😍😍
Noch mit FB ( Imon) und es wäre die Eierlegende Wollmichsau. 😜
( ich komme aus ner Zeit, aus Siemes Multitainer/ Activy, CM Media 300 und wie sie alle hießen)
Samir Bashir
