Since we have been focusing almost exclusively on OLED monitors recently, a change is just what we needed. The KTC H27P22S is a classic LCD monitor – with a UHD panel – that boasts a resolution of 3840 x 2160p and a refresh rate of 160 Hz. The Fast IPS panel (from AU-Optronics) comes without any dimming, which makes HDR a real problem. Nevertheless, it offers a color depth of up to 10 bits (8-bit FRC), an RGB subpixel layout and plenty of connections.
The monitor arrives at your home adequately packaged and quite inconspicuous. Styrofoam is used inside the cardboard box. There is not much more to say at this point. I have summarized the technical data for you. If you want to take a look at the KTC website: Click here!
Technical data
H27P22S dataSource: Geizhals
Let’s start with the ergonomics and work our way through to HDR. Let’s go!
- 1 - Introduction, Features and Specs
- 2 - Workmanship and Details
- 3 - How we measure: Equipment and Methods
- 4 - Pixel Response Times
- 5 - Display Latencies
- 6 - Color-Performance @ Default Settings
- 7 - Direct Comparison and Power Consumption
- 8 - Color-Performance calibrated
- 9 - HDR-Performance
- 10 - Summary and Conclusion
39 Antworten
