GPUs Graphics Reviews
KFA2 GeForce RTX 3080 Ti SG (One Click OC) 12GB in review – Solid performance and even a bit cheaper in comparison with others
With the KFA2 GeForce RTX 3080 Ti, I’m happy to fulfill the desire to once again test a single card that isn’t at the very top of its already hefty price range within its performance class. At currently less than 1150 Euros, it is already back in rather “normal” regions, because just under a year ago we were already at just under 1800 Euros and the RRP is being approached again everywhere. That alone (and the fact that Ada will probably only be on the shelves in late fall) makes a single test quite interesting. And I know quite a few who are still thumbing their noses at all the mining price victims with their RTX 2080 Ti, myself included.
And what else? This graphics card also has the usual GeForce feature set of the current Ampere generation. The heart of the GeForce RTX 3080 Ti is the GA102-225 graphics processor. It is based on Samsung’s 8 nm process node developed especially for NVIDIA and has a total of 28 billion transistors. We already know him from last year. It measures just under 628 mm², making it the second largest gaming GPU ever produced just below the Turing TU102 GPU.
For the GeForce RTX 3080 Ti, NVIDIA has after all enabled 80 SM units on its flagship, resulting in a total of 10240 CUDA cores. In addition to CUDA cores, NVIDIA’s GeForce RTX 3080 Ti is also equipped with next-generation RT (ray tracing) cores, Tensor cores, and the new SM or streaming multiprocessing units. As for memory, the GeForce RTX 3080 Ti is equipped with 12 GB of GDDR6X memory, which can deliver memory speeds of 19.0 Gbps. Together with a 384-bit interface, this will deliver a cumulative bandwidth of 912.4 Gbps.
And yes, there are even accessories for the card that are a small step ahead of the Founders Edition, at least from the manufacturer’s and its marketing point of view. This includes an RGB-lit graphics card holder, but it requires an old 12V RGB connector with four preci dips, and a rear-mounted pull fan, which is great for cooling in poorly ventilated cases and is co-controlled by the card.
Optics and haptics
The design language is the same as always, so it’s not new. The black plastic cover looks plain, you can really like that because it is rather timeless after all. The KFA2 GeForce RTX 3080 Ti SG 12GB weighs 1375 grams and is thus hardly heavier than the reference card. It is also longer with its full 31.5 cm, a pleasant 10.5 cm high (installation height from PEG) and in addition 5.5 cm thick (2.5 slot design), whereby a backplate and the PCB are added with a total of five more millimeters.
The graphic brick including illumination is supplied via two standard 8-pin sockets, so everything is as known and used when a card has a power limit of 350 watts (optionally up to 380 watts). This has the advantage that you can simply save the third cable, which we know from many other models. Yes, it’s already close, especially at maximum OC, but not above specs. We can also see the vertical alignment of the cooling fins and the board reinforcement in the form of a backplate and a frame in the slot bezel area here. Three 9 cm fans (8.7 cm rotor blade diameter) provide the necessary fresh wind for cooling, but the rather out-of-round openings of the cover don’t make sense aerodynamically, rather the opposite. But we’ll get to that later.
The slot bracket is decoratively perforated, carries 1x HDMI 2.1 and three current DP 1.4 ports. However, the USB Type C port is missing. More about the construction, the cooler and the assembly will follow shortly, because the disassembly in the form of the extensive teardown is virtually mandatory for an objective article.
Technology
While the base clock is specified at 1365 MHz, the boost clock is 1695 MHz (FE at 1665 MHz), which is even reached. The card relies on 12 GB GDDR6X at 19 Gbps, but we’ve already covered that. The rest of the key data can be found in the GPU-Z screenshot…
… and the tabular overview (where the values of NVIDIA’s RTX 3080 Ti FE have been put in brackets).
  GeForce RTX 3070 GeForce RTX 3080 GeForce RTX 3080 Ti
GeForce RTX 3090
GPU GA104-300 GA102-200 GA102-225
GA102-300
Process Node Samsung 8 nm
The Size 395.2 mm2 628.4 mm2
Transistors 17.4 billion 28 billion
CUDA Cores 5888 8704   10496
TMUs/ROPs TBA 272 / 96 320/112
TBA
Tensor/RT 184 / 46 272 / 68 320 / 80 328 / 82
Base clock
1500 MHz 1440 MHz 1365 MHz
1400 MHz
Boost clock
1730 MHz 1710 MHz 1695 (1665) MHz
1700 MHz
Memory 8 GDDR6 10 GB GDDR6X 12 GB GDDR6X 24 GB GDDR6X
Interface 256-bit 320-bit 384-bit 384-bit
Throughput 14 Gbps 19 Gbps 19 Gbps
19.5 Gbps
Bandwidth 448 Gbps 760 Gbps 912.4 Gbps
936 Gbps
TGP 220W 320W 350 W
350W
Launch 15.10.2020 17.09.2020 02.06.2021
24.09.2020
KFA2 GeForce RTX 3080 Ti SG (1-Click OC), 12GB GDDR6X, HDMI, 3x DP (38IOM5MD99DK)
Lagavulin
240 Kommentare 211 Likes
Vielen Dank für den Test dieser „Mittelklasse-Karte“ (Mittelklasse bezogen auf 3080 Ti) und dass im Teardown auch ein Blick auf die Wärmeleitpaste und -pads geworfen wurde. Hätte ich so eine Karte im letzten November für knapp 1.200 € kaufen können, hätte ich fast schon Freudentränen in den Augen gehabt. So bin ich halt noch mit meiner 2080 unterwegs. Falls das Preis-/Leistungsverhältnis der kommenden Generation nicht passt, wäre so eine Karte eine valide Alternative für mich. Deshalb ist der Test von besonderer Relevanz für mich.
M
Mr.Danger
77 Kommentare 43 Likes
Ja super Test, ist ja nicht selbstverständlich, die Karte ist ja schon "Uralt". Ich bin auch noch auf der Suche nach einer 3080 Ti. Bin aber noch in und her gerissen, warten das der Preis noch fällt oder die Kohle nehmen und auf eine 4080 spekulieren, obwohl das mit einer ggf. schlechten Verfügbarkeit zum Launch in die Hose gehen könnte. Wobei mir bei der KFA2 das Power Limit mit 380W zum rumspielen eigentlich zu niedrig ist, da schiele ich lieber auf eine EVGA FTW3 Ultra mit 450W PT.
@Igor Wallossek oder @all kann mir jemand erklären, was es mit der RTX 2080 Ti und dem Mining Story auf sich hat?
S
Silbersturm
36 Kommentare 6 Likes
Sehr schöner und informativer Test, vor allen Dingen für mich, der seit der Nvidia 900 Generation KFA2-Fan ist :).
Immer gute Qualität zu (normalerweise) erschwinglichen Preisen :D.
Die Karte wäre ein schönes Upgrade zum meiner aktuellen KFA2 RTX 3060 TiEx;
allerdings ist mir der Preis noch etwas zu hoch.
Mich irritiert allerdings die Angabe des NT etwas.
500 Watt sollen bzw. können ausreichen :unsure:?
Habe aktuell gutes 550 Watt NT drin (System: Ryzen 5800x, div. HDD, SDD, NVME, RTX s.o.)
Das wäre ja schön, wenn ich zumindest um ein neues NT drumherum käme :giggle:
Grimmidereine
12 Kommentare 0 Likes
Danke für Deine gewohnt grosse und informative Arbeit
S
Supie
161 Kommentare 37 Likes
Also die 5-6 FPS weniger als bei der 3090 sind ja eigentlich ein Witz, dafür das diese noch ein ganzes Stück teurer war, und 12 GB mehr Ram hat......
Ich besitze so eine Karte, und es war ein guter Kauf.
Follow Igor:
