Even though winter is slowly being consigned to the past and summer temperatures are on their way, Sapphire is keeping things frosty for the time being. The company has unveiled its new Sapphire Radeon RX 7700 XT Frostpunk 2 graphics card.
![](https://www.igorslab.de/wp-content/uploads/2024/05/Bild_2024-05-16_184149583.png)
Sapphire announced that together with the studio 11 bit, known for games such as This War of Mine or Frostpoint, they have presented a new graphics card with the title of one of their games. It’s the Sapphire Radeon RX 7700 XT Frostpunk 2 and as if that wasn’t enough, they’ve added some interesting extras, but let’s get to the technical specifications first.
The graphics card comes with AMD’s RDNA 3 architecture. It has a memory of 12 GB GDDR6 and a 192 bus interface. For this reason, it has a bandwidth speed of 18 Gbps. The Sapphire Radeon RX 7700 XT Frostpunk 2 graphics card also has 3456 stream processors, 54 ray accelerators and 54 CUs. The AMD Infinity Cache is 48 MB. 2x HDMI 2.1 and 2x DisplayPort 2.1 UHBR 13.5 are included as connections. The game boost is 2226 MHz, while the boost clock is higher at 2584 MHz. Further details can be found in the list below.
Model |
SAPPHIRE PURE AMD Radeon™ RX 7700 XT Frostpunk 2 Edition, 12 GB |
GPU Architecture |
AMD RDNA™ 3 |
Stream Processors |
3456 |
Core clocks |
Boost Clock up to 2584 MHz Game Clock up to 2226 MHz |
Ray Accelerators |
54 |
AMD Infinity Cache™ |
48 MB |
Compute Units |
54 CUs |
Memory Size/Bus/Clock |
12 GB / 192 bit GDDR6 / 18 Gbps |
Displays |
Maximum 4 displays, each with resolution up to 7680 x 4320 px |
Interface |
PCI-Express 4.0 x16 |
Video output
2x HDMI 2.1a 2x DisplayPort 2.1 UHBR 13.5 |
BIOS support |
UEFI |
Frostpunk 2 Features |
Metal Backplate with Frostpunk 2 Graphics 3 Keyboard Keycaps 3 Enamel Pins Frostpunk 2 Deluxe Edition Game Code Product package with Frostpunk 2 theme ARGB SAPPHIRE Logo (set to Orange default color) |
PURE Features |
White Fans and Fan Shrousd Premium Digital Power Design Ultra High Performance Conductive Polymer Aluminum Capacitors Fuse Protection High TG Copper PCB Optimized Composite Heatpipe Intelligent Fan Control Precision Fan Control Angular Velocity Fan Blades TriXX Supported TriXX Boost White Graphics Card Supporter |
AMD Features |
DirectX 12 Ultimate Support DisplayPort™ 2.1 Support AMD Radiance Display™ Engine AMD FidelityFX™ Super Resolution technology* DirectX® 12 Ultimate Support Microsoft® DirectStorage Support Vulkan® Optimized AMD Smart Technologies AMD Software: Adrenalin Edition™ AMD Noise Suppression AMD Privacy View AMD Radeon™ Super Resolution technology AMD FreeSync™ Technology* |
Cooling |
Tri-X Cooling Two-Ball Bearing fans |
Size |
2.5 slot, ATX 320 x 128.75 x 52.57 mm |
Power Consumption |
240 W Total Board Power |
OS |
Linux®, Windows 10 or 11 64-bit operating system required |
System Requirements |
700 Watt Power Supply 2x 8-pin PCI Express® Power Connector PCI Express® x16 lane graphics slot Minimum 8 GB RAM, 16 GB recommended |
Maybe some of you have seen or read it from the list or the picture, if not, then there are a few extras with your order. This means you also get 3 keyboard keycaps and 3 enamel pins. You will also receive a Frostpunk 2 Deluxe Edition game code. The release is scheduled for July 2024.
![](https://www.igorslab.de/wp-content/uploads/2024/05/Bild_2024-05-16_184308085.png)
If you want to see the whole thing in video format, you can do so here:
Source: Sapphire
20 Antworten
