CPU Latest news System
Intel Meteor Lake U, P and H – Exclusive block diagram and specs of the mobile 14. Generation | Leak
Intel’s Meteor Lake processors of the 14th generation are scheduled for launch in the second half of 2023, starting with the mobile product line. They will compete against AMD’s Ryzen 7000 family, namely Phoenix and Dragon Range in the notebook and Raphael in the desktop segment. Meteor Lake is already quite far, because there are already pictures of a compute tile (see below) and block diagrams.  Intel will most likely continue to produce the CPU tile monolithically, but then add the GPU tile via Foveros packaging on top.
Image: PC.Watch
Intel combines a CPU and GPU tile, which, according to the rumors, will be manufactured by TSMC in 3 nm. Keyword yield rate: a defective graphics unit (iGP) is thus ruled out in the future and you are much more flexible in the combination of CPU and GPU. However, all this is not new, but the following block diagram is. It also reveals further interesting details about the U, P and H models, which can thus probably be regarded as confirmed.
We can see the renewed division with P, E and LP E-cores on the diagram, whereby Intel writes of a 7 nm CPU here. However, this probably refers to the Intel 4 EUV process, while Intel’s Xe LPG graphics should be manufactured in TSMC’s 3 nm. Previously, the talk was mostly of Xe HPE, now the slide calls for LPG. It is also interesting that Intel only writes about PCIe Gen 5 port for the dedicated graphics in the H models, while the U and P models probably rely on Gen 4 at most. Up to 14 cores will be possible in the P and H versions (6x P and 8x E cores), whereas the frugal U version will have a maximum of 12 cores. It is also worth noting that Intel divides the E-cores into E- and LP (low power) cores, which internally amounts to a three-way split.
The iGP can have up to 128 Execution Units (EU), which is quite a lot, but probably needed to keep up with the Ryzen 7000 family. The memory configuration, which has to do without DDR4/LPDDR4(X) completely, turns out quite lush with up to 96 GB DDR5 5600 or up to 64 GB LPDDR5(X) 7467.
As already written, the chart refers to the mobile variants, while the slides for Meteor Lake S as the desktop variant have not been distributed yet. We’ll have to be patient here, if we use Alder Lake as a yardstick. So, as always, it remains exciting, because in theory it all reads quite tasty. Let’s just hope that Intel is closer to schedule this time and doesn’t delay much more.
Source: own
N
NilsHG
89 Kommentare 53 Likes
Hinweis - Der folgende Beitrag tangiert den Artikel lediglich.
Am Wochenende kam mir der Gedanke, dass ich mich mittlerweile deutlich weniger über die Ankündigung neuer Produkte freuen kann, als dies noch vorletztes Jahr der Fall gewesen ist.
Viele Medien, die man als technikaffiner Mensch konsumiert, überschlagen sich mit der Ankündigung von Leistungszuwachs und Effizienssteigerung, so dass ich ins Überlegen kommen, wann ich welche Hardware ersetzen möchte. Wird es tatsächlich Geräte mit den im Artikel genannten APUs im Jahr 2023 zu kaufen geben?
Die Ernüchterung ist bei mir schnell groß, wenn die "Markteinführung", wie zuletzt so häufig, erneut nur auf dem Papier erfolgt. Geräte mit der aktuellen Technikgeneration (looking at you Ryzen 6000 U) sind bisher kaum verfügbar.
Ich kann nicht umhin, Hardwarenews so wie die Beiträge über "die nächste besten Batterie" aufzunehmen, die all unsere Energiesorgen lösen wird. Irgendwann.
Mittlerweile freue ich mich mehr über die Verfügbarkeit eines Produkts im Handel, als über die Ankündigung einer neuen Technologiestufe.
Wie geht es euch dabei?
Lagavulin
240 Kommentare 211 Likes
Vielen Dank für den interessanten Einblick! Ist schon bekannt, ob Intel beim Nachfolger des Sockel LGA-1700 eine Änderung vornehmen wird, um die Probleme mit dem Verbiegen von CPU und Mainboard zu beseitigen?
10,477 Kommentare 19,622 Likes
Der mechanische Teils des Sockels bleibt gleich, da hat Intel ja angeblich kein Problem feststellen können.
Wie es aussieht, wird MTL aber 0,1 mm höher, was aber auch am Stacking liegen kann.
Lagavulin
Dann bleibt wohl nur zu hoffen, dass Intel das Problem mit dem Sockel „stillschweigend“ löst, auch wenn sie nicht offen zugeben, dass ein Problem besteht. Soweit ich gelesen habe behauptet Intel lapidar, dass sich die Temperaturen „innerhalb der Spezifikation“ befinden. Das Problem ist hinreichend bekannt und belegt (auch dank der ausführlichen Analyse hier auf IgorsLab) und es gibt ja sogar schon Hersteller, die Mods anbieten. Bei sowas bekomme ich immer Blutdruck. Erinnert mich irgendwie an den Fahrzeughersteller dessen Modelle ich seit langem fahre und wenn ein Problem auftaucht, das in den Foren zig Seiten füllt, dann heißt es seitens Hersteller immer nur, es sei halt „Stand der Technik“.
Göran
155 Kommentare 63 Likes
Mich würde interessieren ob Intel an einem Nachfolger zur Denverton-Plattform arbeitet, vielleicht mit den E-Cores.
R
Rooter
56 Kommentare 10 Likes
Wie alt sind denn die slides? Die erwähnen dort Intel 7nm, obwohl Intel das zu Intel 4 umbenannt hat.
Lesen. Da steht 7nm CPU und nicht der Prozess. Man kann ja schlecht Intel 4 CPU reinschreiben. 😝
Ich habe auch keine Folien, wo Intel 10 draufgestanden hätte…
R
Rooter
Warum sollte man das nicht können? Bei 10SF oder 10ESF ist es noch einfacher. Geleakte Folien ohne ersichtliches Datum sind oft alt, dadurch ergeben sich oft abweichende Angaben.
Bestimmte Sorten Internals sind nicht datiert. 🙂
Wären sie richtig alt, wären sie längst geleakt worden.
R
Rooter
Wenn das generell so wäre, würden wir ständig Leaks in der Form sehen. Das ist aber eher selten. Abschließend lässt sich feststellen, dass es sich nicht klären lässt, ob das alte Slides sind oder nicht.
Ich weiß nur, wann der Mitarbeiter sie bekommen hat. Und das war nicht schon vor Monaten. Wie oft Intel die eigenen PDFs korrigiert und Dinge im Detail ersetzt, sei mal dahingestellt :)
Follow Igor:
