Cooling Practice Reviews Watercooling
When the OEM slackens or saves money – AiO compact water cooling systems with pre-programmed expiry date and an example from our lab | Investigative
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
The suppliers of so-called all-in-one compact water cooling systems (AiO for short) and their product managers (PM for short) do not find it easy to always find the really suitable (and honest) OEM for the expansion of their own product portfolio. Because also the supplier of the today’s product do not manufacture themselves, but go trustingly into the hand of a large manufacturer (OEM), which from its own product range such products optically also externally individualizes and/or also mechanically adapts.
There are two very big OEMs like Asetek and CoolIT or even medium and smaller ones like Cooler Master, Dynatron, Deep Cool, Swiftech or Apaltek. And at SHENZHEN APALTEK CO., LTD always sets off alarm bells inside me, because it wouldn’t be the first time that something would go wrong here in the long run. There have already been various problems with the products, starting with Silverstone’s Tundra and their Container-wise returns, various died AiOs from Enermax / Lepa and others. This time it seems to hit another big supplier, which among others also buys from Apaltek. In the interest of fairness, I’ve kept both the OEM customer’s company name and the product out of today’s article for now, or anonymized it. For now, but more on that in a moment.
Regarding Apaltek as an OEM, you should also know that there is a lawsuit going on in the Texas Western District Court where Asetek sued Apaltek for patent infringement. I recently published an original warning letter (in this case to Arctic) in the article “Asetek with problems – wave of warnings against many companies, profit correction and dangerous negative trend“. If the supplier wants to claim financially from the OEM in case of a real serial problem, he should probably hurry up a bit.
However, since it could be an isolated case and I would like to wait for the opinion of the OEM as well as a special expert opinion that the supplier has commissioned independently of the OEM, it will therefore go into overtime once again with a part 2. I am not interested in destroying a product that is already on the market (in case of doubt, the OEM has already taken care of that) and to cause panic among the customers, but to make it possible for the supplier and OEM customer to settle the matter in the best possible way in the interest of the customer.
Because you first have to find out if it is only a partial problem with one or a few products, if a whole delivery is affected or if there is a general manufacturing problem with all products. All-clear or recall? Let’s be surprised. To be continued.
Exactly one of these affected AiOs is (or rather was) also in use at our company, and since the employee habitually logs the temperatures from time to time, he noticed a creeping deterioration weeks ago, which now even led to the final failure. We have disassembled this specimen, analysed it and also gone in search of clues, because knowledge of which OEM manufactures for which supplier is first of all part of the well-guarded internal company information that outsiders only rarely find out about.
I have taken this very specific case as an opportunity to compile a few facts about small closed AiO solutions in general, which many readers may not be aware of in this depth. Nevertheless, I want to avoid giving a basic course in inorganic chemistry here, but I can’t do without certain details either. That’s why I had to generalize a lot of things a bit, so that the broad understanding is still preserved even without specialized knowledge. So it’s a compromise, but still goes deep enough.
In addition, I am in contact with the product management from the OEM customer’s headquarters for other products as well, since it is also in the customer’s interest to be able to correctly classify such failures and make better judgments in the future when selecting the right OEM.  However, that is exactly what is still in process and I will be sure to report back as it progresses. Today, however, we first have the basic knowledge of the background and of course the pictures of horror from our own case. They’ve got a lot going for them.
I would also like to point out that the AiO, which was gently slumbering here, was only in use for a whole 6 months and was not even used or loaded very often or extensively. In the end, because we’re all working in the editorial department, that’s even less usage time than would occur for a passionate gamer. Let’s start with 2 screenshots from the early days of this AiO more than half a year ago:
And now we come to the disaster of last weekend and the total failure of the system up to the emergency shutdown by the boiled CPU.
Once that’s cleared up, we’ll go in search of clues, because not only is the CPU hot, but so is the subject .
RedF
5,113 Kommentare 2,928 Likes
Tippe mal auf Alusalze.
B
BloodReaver
56 Kommentare 20 Likes
Ich kenne die Kristallbildung nur am Korken von Rotwein ;)
Toller Bericht! Meine Alphacool Eisbaer Aurora werkelt immer noch tadellos vor sich hin. Ist ja aber auch erst 1/2 Jahr alt. Ich hoffe das bleibt auch so.
D
Deleportas
27 Kommentare 6 Likes
Sehr interessanter Bericht.
Danke dafür!
Dann werde ich heute Abend mal meine Pumpe etwas hoch regeln :)
Zum Glück bin ich vor Jahren auf einen Custom Loop umgestiegen, da kann man zumindest an einigen Stellen auch rein schauen :cool:
10,843 Kommentare 20,541 Likes
Turnusmäßige Kontrolle ist völlig ausreichend :)
Traue keiner AiO, die Du nicht selbst befüllt hast!
hansmuff
64 Kommentare 43 Likes
Ich benutze AIOs einfach weil die für mich leiser sind als Luftkühlung; dazu will ich sagen, daß mein Rechner so 1-2 Minuten lang alle 5-10 Minuten so richtig angefeuert wird. Mit jeder Luftkühlung habe ich das Problem, daß der Kühlkörper schnell an seine Kapazität kommt, und die Lüfter dann reinhauen müssen, und das habe ich mit AIO halt nicht, da dauert's wesentlich länger bis die Lüfter sich drum kümmern müssen. Dieses Aufbrausen der Lüfter hasse ich wie die Pest.
Aber naja, mein erster AIO von Corsair kackte nach 3 Jahren ab, der war $120. Neueres Modell gekauft, $150. Läuft jetzt seit 2 Jahren sehr gut, aber ich mach' mir auch nichts vor, ewig lebt das wohl auch nicht.
Ist dann halt eine Wahl: (1) Immer neue AIOs kaufen nach 3-5 Jahren (2) Luftkühler und mehr Lärm (3) selbstgebaute Wasserkühlung.
Ich bin für (1) weil ich keine Zeit habe, (3) wenn ich mal Zeit have. Lärm geht mir sehr auf den Senkel.
I
Irrer Pinguin
5 Kommentare 3 Likes
Kurz vorweg, ich bin ein totaler Laie was Wasserkühlungen im PC betrifft.
Meine Frage ist: Gibt es eine Ölkühlung, abgesehen von der Tauchbadkühlung, für Computer?
Ja die Spezifische Wärmekapazität von ÖL ist nur halb so hoch wie die von Wasser und müsste deswegen als größerer Volumenstrom durch die Wärmetauscher fließen.
Größere Kanäle in den Wärmetauschern wären, durch die höhere Viskosität des ÖLs, auch von nöten.
Trotz dieser, nicht unerheblichen, Nachteile, hätte man ein system, welches deutlich wartungsärmer als eine WaKü wäre, da Ausfällung, Kristallbildung und Korrosion sehr unwahrscheinlich bis zu nicht vorhanden wären.
Ein weiterer kleiner Vorteil ist, dass bei einem Leck kein Kurzschluss entstehen kann.
Mir ist bewusst, dass man nicht einfach ÖL in eine WaKü kippen kann, das müsste schon ein eigenständiges System sein.
Grüße gehen raus und allen eine schöne Restwoche.
Guest
@Irrer Pinguin
Steht in keinem vernünftig nutzbaren Verhältnis, wenn man Öl (gibt es ja auch in sehr dünnflüssig....kennst du auch = Diesel ) nehmen würde.
Will nicht zu pedantisch erscheinen, aber es ist sehr selten noch richtiges Eisen (=Element) zu bekommen. (Abschirmungen, Restauration, Chemie usw)
Eigentlich ist fast alles eine Legierung = Stahl ( alles über 0,5% Legierung nach Verhüttung), oder?
LEIV
1,580 Kommentare 667 Likes
Hätte ich meine Pure Loop nicht vor nem halben Jahr entsorgt, wäre es mal interessant gewesen das mal mit richtig dünnflüssigem Öl zu testen 🤔
I
Irrer Pinguin
Das wäre mal tatsächlich interessnnt gewesen. Auch wenn ich glaube, dass die Werte echt schlecht gewesen wären. Bzw, könnte die pumpe das vielleicht gar nicht bewältigen.
Guest
Gibt ja kaum eine leicht zu beschaffende Flüssigkeit mit dermassen hohen Wärmekapazität (Koeffizienten) wie Wasser.
P
Phelan
206 Kommentare 185 Likes
https://www.silentmaxx.de/lautlose-PC/?force_sid=38dq4cc5hdnou62e6fubap3kvc
Leise / Lautlos geht auch ohne Wasserkühlung, auch als Highend oder Gaming PC mit ner 3080 :)
S
Stormfirebird
41 Kommentare 13 Likes
Das ist jetzt nicht zufällig eine dieser schicken MSI Coreliquid mit nem R hinten? Da gabs im CB Forum schon den ein oder anderen Thread wo sich über Temperaturen gewundert wurde.
FfFCMAD
728 Kommentare 220 Likes
Ich hoffe das das bei meiner AIO nicht so kommt. Die ist erweiterbar und nutzt nur Kupfer + Destilliertes Wasser. Ist von Alphacool, die Eisbaer Aurora. Einzig die Verbindungsstutzen fuer die Schlauche machen mir Sorgen. (Habe nicht geprueft ob die komplett aus Kupfer sind) Ich hoffe, ja, das bei diesen nachgekauften Stutzen kein Alu mit dabei war... Ich habe auch beim zweiten Radiator darauf geachtet, einen aus Kupfer zu nehmen. Denn ich habe keine Lust, das da irgendein Teil Opferanode spielt.
Ich habe hier die Eisbär Pro sogar noch als Prototypen im Einsatz - da ist Nullkommanichts dran. Sauber wie im Krankenhaus. :D
Snipe
27 Kommentare 3 Likes
Ich habe eine Eisbär 280er -ich hoffe die lässt mich nicht im stich.
Seit 3 Monaten im Einsatz und bin sehr zufrieden :)
FfFCMAD
Ich kuehle aktuell einen 10900x mit auf 250Watt angehobener maximalen TDP, vorher einen leicht uebertakteten x5675. Die Dinger performen fuer die kleine Pumpe echt gut. Meine ist nun etwa ein Jahr alt. Ich hoffe die macht noch ein paar Jahre. Und ich hab sie gekauft, weil Igor gesagt hat, die ist gut xD
Alphacool
368 Kommentare 534 Likes
@Snipe
Wenn was sein sollte -> [email protected]
Egal wo du die gekauft hast.
Antwort 5 Likes
M
MHoppe
27 Kommentare 9 Likes
Ich hoffe das mir sowas mit meiner Eisbär Extreme, erweitert um einen 420er Radiator, auch erspart bleibt. Befüllt mit einer popelig klären Flüssigkeit ohne Farbspielerei der gleichen Firma (auf Rückfrage was denn vorbeifüllt ist) und TPV Schlauch.
Entgegen der Tests im Netz höre ich die Pumpe bis 75% kaum aus meinem Rechner heraus da fast alle Lüfter auf 1000U/Min lauter sind
S
Staarfury
258 Kommentare 206 Likes
Ich kann mir ganz ehrlich nicht vorstellen, wie die 600+ Watt Leistung passiv loswerden wollen.
Und irgendwie finde ich auch 0 Informationen oder Tests zu den Produkten.
Hast du denn Erfahrungen mit den Produkten?
Follow Igor:
