Cooling Practice Reviews Watercooling
High-End Gaming PC 2021/2022 with Custom Water Cooling | Part 2 Assembly
Time is running out and many are already waiting for the second part and today is the day (who missed the first part: click here). We take a look at the finished high-end gaming PC including the peripherals. The focus will be on the topic of custom water cooling. So if you expect there to be much on the subject of PC assembly in general today, I’m afraid I’ll have to disappoint you. A few pictures and words I will certainly also let go to this on you, do not worry! But how to assemble a PC I don’t have to show or explain to most readers here.
There are probably also some readers among you who have already had some experience with custom water cooling. On the one hand, they will probably see how the PC has turned out, and on the other hand, they will be able to confirm one or two of our experiences. My goal for this article for today’s Easter Sunday is to take some of the fear out of a custom water cooling project for one or two readers. At the first moment this sounds like mysterious voodoo, I can assure you, it is in no way!
In the last half year, you’ve read a few unpleasant articles here on Igor’s site about all-in-one water cooling systems. I myself fell victim to such a botched AiO, and as a result, completely converted my test bench to custom water cooling. Article available here: Click! Since I have to rebuild a lot during testing and a hard-tubing in this case only disturbs, you see a pure soft-tubing with me. For me, this is quite enough!
Anyone who is seriously considering a custom water cooling system should definitely think carefully beforehand: What do I actually want? How much space do I need? Do I prefer to use soft tubing or do I want to bend hard tubing? And very important: Really think about how the whole thing should look in the end. Most importantly, start thinking about possible alternatives right at the beginning. Who seriously wants to use Hard-Tubes, which should think in any case about angle pieces (corner connectors) as a contingency plan and buy such also if necessary equal! Why? I’ll come back to that later.
Since my brother-in-law has a CAD program, we didn’t have to resort to paper and pencil to sketch out the project once. This also makes alternative plans possible in advance already for the “What if” drawer, since all you have to do here is redesign and click on Save plan A/B/C. Since not everyone has such a thing, you should make hand sketches. With soft tubing, you can just build everything into the PC, put the fittings on the components you want to cool, and then run the tubing freehand. Nobody has to be afraid of that! When bending pipes, however, the wheat is quickly separated from the chaff and sometimes even man from monkey. Laughter is allowed!
To get you started, here’s my brother-in-law’s master plan!
Yes, that looks pretty neat. Even the Be Quiet! Silent Base 802 can be recognized! Anyone who has spatial imagination will now realize that this is not just a matter of bending 1 times 90 °. Here are several bends to make in 3D space. I had to pause for a moment and called a few colleagues to see what they thought. Next page please.
konkretor
312 Kommentare 321 Likes
Wie oft wird das Wasser gewechselt?
Wenn ich überlege was vor über 20 Jahren Wasserkühlung für ein Aufwand war und jetzt, kein Vergleich.
Nulight
249 Kommentare 170 Likes
Sehr schöner Bericht, erinnert mich an meine erste Bastelei (y)
Was für ein Krampf damals * lach * , ich hatte NULL Backup-Winkel, mittlerweile wieder Schlauch.
Schöne Ostern euch allen .
Antwort 4 Likes
ApolloX
1,687 Kommentare 955 Likes
@FritzHunter01 endlich :-)
Sehr schön gemacht, auch mit dem Video am Schluss gut dokumentiert.
Puh, was fürn Kampf mit dem Biegen. Ich hatte keine Vorstellung, da ich nur weiche Schläuche nutzen, aber das hier bestätigts mir mal wieder, selbst den richtigen Weg eingeschlagen zu haben. Mich schreckt auch ab, dass man bei den festen Rohren einmal wissen muss, was man will und dann bleibts dabei. Bei meinem Spieltrieb müsst ich alle paar Wochen Rohre neu biegen.
Ich hatte in dem Gehäuse jetzt mal ne Zeit lang zwei 140er Lüfter drin, aber mehr und mehr glaubte ich, dass es bei der Wasserkühlung auf die beiden unten auch nicht mehr ankommt. Und dass es unten irgendwie nicht ganz einfach zu bauen ist, hab ich ebenfalls festgestellt. Da wo ihr geschnitten habt, hab ich auch schon mal überlegt zu dremeln, weil man einfach mit der Struktur im Gehäuse nicht ideal arbeiten kann. Wäre bissl einfacher, wenn man die Trennung zu unten herausnehmen könnte.
Puh, der Ablasshahn, der ist zwar unten, aber kannst du da auch ablassen? Da musst es dann durch den Gehäuseboden laufen lassen und das Gehäuse auf nen Eimer stellen?
@konkretor Hä? Ich war mit meiner Facharbeit 2000 in Passau bei Jugend Forscht im Regionalwettbewerb. Gewinner waren ein paar so Kids, die kurz vorher in der PC Games den Artikel zu den CPU Wasserkühlungen gelesen haben und nachgebaut hatten. Als AGB diente ein offener Eimer Wasser, paar Schläuche, Aquariumpumpe. Alles total einfach, weiß nicht, was du hast :-)
O
Ozzy
225 Kommentare 137 Likes
Schöne Arbeit, was mir an Info fehlt, wieso habt ihr mehr Rohr verbraucht. Was passiert mit den Rohren, wenn es nicht klappt. Gehen sie kaputt, weil Material nicht nachfliesst oder wenn der Winkel nicht stimmt muss man ein neues nehmen, da man nicht "nachbiegen" kann?
Bild 3 könnte gedreht werden, da es auf der Seite liegt :)
Viel Spaß mit dem Schmuckstück.
B
Besterino
6,897 Kommentare 3,470 Likes
Wieso soll man eine (diese?) Pumpe immer auf 100% setzen? Da sucht man doch in der Regel den Sweet Spot zwischen Durchfluss und Lautstärke… (jede Pumpe erzeugt etwas andere Geräusche je nach Drehzahl) - genau deshalb gibt es ja viele Systeme mit mehr als einer Pumpe (um diese eben mit möglichst geringer Lautstärke betreiben zu können und trotzdem den gewünschten Durchfluss zu haben). Im Prinzip so wie bei Lüftern…
Ich gebe auch offen zu, dass ich für Hard Tubes zu ungeduldig bin. Auch traue ich den Befestigungen irgendwie nicht so richtig (wahrscheinlich zu unrecht). Bei Schlauch mit Fittingen kannste Dich gefühlt dranhängen und das hält. Da hat man eigentlich nur das Risiko, dass eine Dichtung vom Fitting fehlt/kaputt ist - aber wenn das einmal dicht ist, kannste so einen Loop schütteln, auf den Kopf stellen oder auch mal kräftig (aus Versehen) gegen stoßen ohne gleich an ein Not-Aus denken zu müssen. ;)
Aber das ist natürlich alles selten so schön wie mit Tubes, das sehe selbst ich sofort ein. :)
FritzHunter01
1,216 Kommentare 1,649 Likes
Ja, das mit dem Ablasshahn ist einfach ziemlich bescheiden! Mein Schwager musste das Wasser schon ablassen, weil der O-Ring an der Pumpe etwas geleckt hat. Geht ganz gut siehe Bild. Eimer drunter fertig!
Der Ablasshahn hat ein Gewinde, man kann also auch einen Schlauch mit Fitting aufschrauben, dann geht das denke ich besser!
FritzHunter01
Pauschal sollte man das Wasser alle zwei Jahre wechseln. Wenn man zusätzliche Farbstoffe nutzt würde ich das eher jährlich machen und alle Komponenten ordentlich spülen!
B
Besterino
Statt Ablasshahn würde ich immer Schnelltrenner nehmen…. Das geht aber wiederum nur sinnvoll, wenn man irgendwo (z.B. im nicht sichtbaren Bereich) eine gewisse Länge Schlauch hat.
Casi030
11,923 Kommentare 2,339 Likes
Du hast so viel Platz unten und quetscht den Haan dazwischen......
Warum hast ihn nicht ein wenig freier verlegt wo man besser ran kommt,dann noch ein Loch durch den Boden mit Gummiring und flexiblen Schlauch der im Gehäuse aufgerollt ist und beim Ablassen kannst ihn einfach durch das Loch stecken.
FritzHunter01
Also bzgl der Pumpe:
Ich nutze die gleiche und bei steht die offen rum. Die läuft auf 100% und ich höre da nix! Die Lüfter drehen bei mir auch mit 1000 rpm und übersteuern alles.
Bisher war der PC von dem Projekt einmal bei mir, um die Kiste mal zu knechten! Daher stammen auch die Messungen im Artikel. Der PC war deutlich leiser als meine Testbench. Und um längen leiser als mein Gaming-PC, denn die 240er AiO macht selbst mit 800 rpm einen lärm, unglaublich!
Aber grundsätzlich hast du Recht, eine zweite Pumpe wäre auch bzgl Redundanz keine schlechte Idee! Lautstärke ist immer so individuell, da stört mich 40 dB nur, wenn ein nerviges Lagergeräusch mitschwingt, wie bei der 240er AiO.
Ich sollte die eh mal ersetzen, die ist über zwei Jahre alt und Wasserwechsel ist nicht möglich! Dafür war die mir 55 Euro nicht zu teuer…
FritzHunter01
Danke für den Tipp! Ich hatte wenig Aktien an dem Zusammenbau. Hat der Schwager alleine gemacht. Pascal und ich waren nur ab und zu telefonisch zugeschalten… Sorgentelefon!
Der Schlauch liegt übrigens bei mir hier rum 😂
Leider vergessen!
Ich gebe es weiter!
v
vonXanten
812 Kommentare 343 Likes
@FritzHunter01 endlich Teil 2! Vielen Dank!
Schick sieht es aus, aber die Geduld beim biegen kann ich auch nur bewundern.
Wie oft lässt sich so ein Rohr eigentlich biegen? Oder ist das eine einmalige Angelegenheit?
Und wenn der Rechner wie beim ablassen steht, hast keine Probleme mit Staub vom Boden ansaugen :ROFLMAO: (y)
B
Besterino
@FritzHunter01 Ich kenne niemanden mit Sinn und Verstand, der bei einer Wakü Lüfter mit 1000rpm laufen lässt… da fehlen dann entweder Lüfter oder Radi-Fläche oder beides… ;) Vielleicht mal als Stresstest oder Benchmarking inkl. Klima vorm PC / Fenstermod… aber das Ziel einer Wakü sind doch leise bzw. sogar lautlose Systeme und Lüfter (wo das ist, scheiden sich die Geister: für mich bei so 350 RPM). Hat man da seinen Sweet Spot gefunden, hat man quasi das Prinzip vom umgekehrten Flaschenhals: jetzt hörst Du auf einmal die Pumpe. Oder die Spulen der Graka. Oder den Lüfter vom Netzteil. Oder den Lüfter von Chipsatz (if any). Oder ein Zirpen der SSD beim Zugriff. Oder das Brummen vom Netzteil des Monitors/USB-Hubs/FRITZ!Box/Lautsprecher/Dimmers von der …
Alles schon gehabt und alles kein Thema, wenn eben auch nur ein Krawallbruder alles andere eh niederbrüllt. ;)
Bei mir höre ich leider immer noch die Pumpen - ansonsten herrscht tatsächlich weitestgehend Ruhe. Subjektive Ruhe hätte ich, wenn ich die 3 DDC-Pumpen bei 1200RPM (mindest-Drehzahl) laufen liesse - dann aber für mein Wohlbefinden zu wenig Durchfluss mit ca. 60l/h. Der nächste Sweetspot vor allem bei der Frequenz des Geräuschs ist dann leider erst bei ca. 33% (~160l/h)…
Casi030
Wenn du von deinem Mora mit 140er Lüfter redest hast recht.
Aber es kommt ja auf auf die Lage der Lüfter an wo sie verbaut sind und wie die Struktur des Bleches/des Radis und und und ist.
Wie viel drücken/Verwirbeln die Lüfter bei 350U/min?!
Bisher lagen die 120er Lüfter bei rund 600-750U/min,die neueren Arctic bringen untenrum z.b. weniger druck und Luftverwirbelungen und sind dadurch auch erst bei rund 1000U/min zu hören je nach dem wo sie Verbaut sind.......
FritzHunter01
Also bei mir gehen die Rise Lüfter 120mm bis 800 rpm, dann gehen sie aus… der Geräuschpegel bleibt subjektiv gleich! Leistung verliert bzw gewinnt man auch nicht wirklich!
Wir müssen den Rechner mal bzgl Lautstärke messen. Dann können wir mal den sweat spot suchen…
Schon wieder ein Artikel gewonnen… so wird es nicht langweilig
FritzHunter01
Wenn du das Rohr einmal gebogen hast, dann ist es entweder gut oder für die Tonne! Zumindest bei den PMMA Rohren ist das so…
Bzgl Geduld:
Wenn ich den PC hätte mit AiO oder Luftkühlung bauen müssen, dann wäre das ganz in einer bis eineinhalb Stunden erledigt gewesen. Für so eine Hard Tubing Nummer sollte man min 3 eher 5 Tage planen!
B
Besterino
Eben… wenn zwischen 800RPM und 500RPM ein großer Performance-Unterschied ist —> zu wenig Radifläche und/oder Airflow drumherum insgesamt zu schlecht.
Wenn man den Unterschied nicht hört… sehr seltsame Lüfter, Gehör oder große Entfernung? ;)
FritzHunter01
2x 360 mm reicht eigentlich für das System…
Man sagt als Faustregel 100 mm/100 Watt…
B
Besterino
Nee… 120er/100W und bei Lüftern auf volle Pulle!
Fritz Hunter
