Audio Audio/Peripherals Headsets Reviews
HIFIMAN HE400se Bargain Review – Excellent planar headphones for 100 euros with only few weaknesses for music and gaming
The HIFIMAN HE400se (se stands for stealth edition) is characterized by its planar magnetic technology, which results in a very clear and detailed sound image. This technology, usually found in much more expensive headphones, enables a surprisingly even and very precise sound transmission. In addition, the HE400se offers an open design that contributes to a very natural soundstage, with certain acoustic disadvantages for the environment.
Despite these high-quality features, these headphones are available at a comparatively extremely low price of less than 100 euros in some cases, making them an attractive proposition for audiophiles looking for high sound quality at an affordable price and providing me with an ideal template for a bargain check. Planar headphones in this price range? Yes, it’s possible and it works amazingly well and almost without any major compromises.
What distinguishes magnetostats from conventional headphones?
Planar magnetic headphones use a thin membrane embedded between a magnetic array and printed with conductive material. When current flows through the material, it interacts with the magnetic field, causing the entire diaphragm to vibrate evenly and produce sound. In contrast, dynamic headphones use a coil that is attached to a diaphragm and moves in a magnetic field.
The current through the coil creates a force that moves the coil and diaphragm to produce sound. Planar magnetic headphones often offer less distortion and a more detailed sound due to the even excitation of the diaphragm, but are often larger and heavier due to the magnetic structures required. And they also require a sufficiently powerful headphone amplifier, which effectively rules out onboard solutions. A pity, but you can’t have everything at the same time.
Scope of delivery
You receive the headphone, an almost 1.5 meter long stereo cable with a Y-whip for connection to the shells on both sides and with an angled 3.5 stereo jack plug for connection to analog outputs. The angle is nonsensical because no smartphone is likely to be able to deliver the necessary levels. In addition, such a useless angle prevents the use of extension cables. Yes, it would work, but it looks really silly.
Nobody will understand what HIFIMAN was thinking here. In addition to the rubber-sheathed cable, there is at least an adapter to 6.3 mm stereo, which makes the bracket on the desktop or good amplifiers seem even more pointless. Here I recommend a suitable cable from the accessories with a suitable length and neutral, ultra-soft sheathing.
Technical data
Now you can certainly write yourself silly about the technical data, but I’ll conveniently let the manual from the website speak for itself. There are many more things described there that go beyond the scope of a review like this, marketing included. In a nutshell, it reads like this:
Frequency Response: 20 Hz – 20 kHz
Impedance: 32 Ω
Sensitivity: 91 dB
Weight: 385 g
Manual
HiFiMAN HE400se
179 Antworten
Rizoma
184 Kommentare 156 Likes
Das hört sich sich ja gut an bei den auf gerufenen Talerchen. Das mit dem Gewinkelten Stecker würde mich nicht stören da meine Soundkarte eh nahe am Mauspad Steht und ich bei meinen DT990 schon einen Winkeladapter dazwischen habe damit das Kabel nicht auf dem Pad liegt. Igor da du ja sehr viel Erfahrung mit den Beyer hast wie würdest du sie im Vergleich zu den DT990 Beurteilen bzw. Kennst du Gute Preiswerte Alternativen die ich sogar an den Balanced Anschluss dran kann?
Ghoster52
1,460 Kommentare 1,123 Likes
Von mir bekommst ein Daumen, Danke für den Test! (y)
Der Winkelstecker hat so seine Vor- & Nachteile, jedoch finde ich den durchaus sympathisch.
Am DAP oder Smartphone hat man so weniger Hebelwirkung am Stecker, der KH ist ja Richtung "mobil" ausgerichtet.
Hätte mein olles LG V30 nicht diese 50 Ohm Automatik, könnte ich den HE direkt am Smartphone nutzen.
(das kann 2VRMS im High-Gain)
So ein kleiner "Hifi Walker H2" mit Winkelstecker passt besser in die Tasche (mal so als Argument in den Raum geworfen). ;)
Der Preis ist eine klare Kampfansage, selbst in den typischen "CN-Shops" findet man keine Treiber für DIY in der Preisklasse,
unter 65€ das Stück hab ich noch nichts brauchbares gefunden.
PS. mMn sollte man sich ein paar Ersatz-Pads in den Schrank legen, die Hybridpads von Hifiman zerfallen auch gern nach
1-2 Jahren und je nach Nutzung.
Edith: scheinbar ist das schon v2
Die 1. Version (2021) hatte noch ein störrisches Silberkabel und 25 Ohm
big-maec
916 Kommentare 542 Likes
Der Satz diente mir als Steilvorlage und man könnte ja auch noch den HIFIMAN EF400 Kopfhörerverstärker testen.:whistle:
Inzingor
198 Kommentare 120 Likes
Guter Test - danke dir! Mein Kaffee hat jetzt gleich noch besser geschmeckt :) Bin schon gespannt auf den Test der Fiio EM5 ;)
Der steht bei mir aufm Tisch :D Danke für den Hinweis, ich hatte vergessen, das Bild ins Intro zu packen :)
Antwort 6 Likes
1,698 Kommentare 1,031 Likes
Wenn ich das richtig in Erinnerung habe, brauchen Planarmagnetische KHs eben doch einiges an Stromstärke. Wie lange halten denn die Membranen?
Ghoster52
Den Fostex T50rp gibt es schon "ewig", also die Treiber altern auch nicht anders, wenn da bei den "Hifiman-Folien" nichts spröde wird,
halten die ewig.
ein paar Klassen drüber (subjektiv), der HE klingt offener mit weniger Beyer-Peak.... :LOL:
Dank 3,5 mm Klinke findest im Fluss (Amaz...) sicher auch sym. Kabel für den HE
(Suchbegriff: Ersatzkabel für Hifiman HE-xxx, Denon AH-D7200 usw.)
PS: meine "Chill-Ecke" mit kleinen GU-32 Röhri, da kann ich 2 KH testen (Umschaltung)
Ich würde sogar soweit gehen, zu behaupten, dass man den DT1990 Pro danach nicht mehr mag. :D
Inzingor
Ich gehe noch einen Schritt weiter und würde behaupten, dass man den T1 danach nicht mehr mag, falls man ihn überhaupt je gemocht hat xD.
Ghoster52
Ich hatte mal T1 mit OE-Mod (der war perfekt für Klassik)) & HD-800 (mit & ohne French-Mod) hier, die sind vor den Hifimänner gegangen wurden.
Es ist aber Geschmackssache, im HF gibt es auch Stimmen die ein Dynamiker vorziehen.
Die 1. Gen. war noch ganz brauchbar, die aktuelle ist fürchterlich. Das frifft auch den offenen T5. Ich kaufe bei Beyer solange nichts mehr, wie nicht wieder jemand aus der Familie oder mit Ahnung den CEO spielt. Das ist nur noch gewinnorientierter und kostenoptimierter Mainstream :( Meinen Amiron Home habe ich verschenkt, der MMX 300 2. Gen liegt noch im Archiv. Nutzen mag ich den auch nicht mehr.
Inzingor
Ich besitze auch den Amiron Home und dazu noch den DT 700 Pro X. Letzterer kommt bei mir unterwegs zum Einsatz und wenn ich mich daheim komplett abschotten möchte. Für diesen Zweck reicht er allemal, solange sich die Polster nicht auflösen :).
thartel
10 Kommentare 6 Likes
Hm fast 400gr schwer und dieses wirklich dicke Kopfband. Nich so schön :) Wenn ich allerdings höre dass die Beyerdynamic Qualität nachgelassen hat und ich mir eigentlich nen neuen DT990 schenken wollte, vielleicht dann doch nen Hifiman? Preislich interessant ...
D
Der Do
85 Kommentare 37 Likes
Die einzige Angabe die mir fehlt (überlesen?) ist die Größe der Treiber, 40 oder 50 mm Durchmesser, On-Ear oder Over -Ear?
Ich hab relativ große Ohren und 40 mm ist für mich "On-Ear", wäre ein Ausschlußkriterium.
Megaone
1,833 Kommentare 1,726 Likes
Ich beschäftige mich mit der Thematik Planarkopfhörer + KHV seit vielen Jahren.
Ich würde gern 2 weitere Hifimänner ins Spiel bringen, die kaum Teurer aber Imho besser sind.
Das sind die Modelle von Massdrop. ( Achtung, das muss man mögen in den USA zu bestellen, aber ich habe dort die letzten Jahre 5 Kopfhörer bestellt und nie Probleme gehabt.)
Einmal den HE4xx für 169 Dollar und den HE-4X für 129 Dollar. Im Angebot sind beide häufig nochmal 25% günstiger. Ich halte beide für besser verarbeitet und klanglich leicht überlegen und beide finden sich in der Reddit Optimierungsliste für Peace!
Hier mal ein paar Tests dazu.
https://www.mmorpg.com/hardware-reviews/drop-hifiman-he-x4-review-2000121924
Wer was günstiges und wirklich gut für seinen Kopfhörer sucht, ist mit folgenden KHV`s exact in der Reihenfolge am besten bedient.
Aikido Otto KHV.
Gibt es vorkonferiert als Bausatz , aber auf Wunsch auch komplett, einfach anrufen. Das mit Abstand Beste was ich je gehört habe. Und zwar Preisunabhängig! Hervorragender Class A Verstärker.
Ziemlich legendäre Verstärkerschaltung, Einfach ein wenig googeln.
Topping A30 Pro.
Extrem Leistungsstarker KHV. Auf Wunsch kombinierbar mit hauseigenem DAC. Ebenfalls Class A
Fiio k5Pro DAC Desktop.
Toller Verstärker mit hervorragendem Dac.
Alle 3 bieten genug Reserven, auch für leistungsfressende Kopfhörer!
Als letztes aber dennoch. Wer auf die Harmankurve und die Redditvorschläge umsetzt und das Ergebnis schätzt, wird erkennen das der 990er klanglich schwindelerregende Qualitäten erreicht.
Die Hifimänner habe ich dennoch behalten, weil sie einfach spaß und Magnetostaten bezahlbar machen.
Dennoch ist das hier meine subjektive Meinung und Geschmäcker sind natürlich jenseits aller Messungen verschieden!
Antwort 6 Likes
Guest
Super Test am Jahresanfang!
Ein Kollege ( Tontechniker) hat mich auf den hingewiesen.
Macht sauber für seine 99 Taler und ist robust Holzkopf gebaut.
Den hör ich mir an.
Eig wollte ich 2024 genau nichts kaufen. ( Verarschen von Nvidia und co ist net)
Aber das ist was anderes.
( ps 2.. langsam gewöhne ich mich an den gebogenen Samsung G9.. DCS.. grad eine Mig 29 runter geholt.. Mirrage 2000.. Reiisling)
Danke 5 Sterne Peace :)
T
Tralien
96 Kommentare 42 Likes
Ich habe mich auch sehr über diesen Test gefreut. Ich selbst habe mir vor Wochen den Hifiman Sundara gegönnt, um 300€. Ich bin immer wieder total baff wie Unterschiedlich ein flac von Adele z.b. klingt im Vergleich zu meinen Alten....einfach Hammer diese Planar-Technik.
Ich bin auch echt dankbar über den Artikel zum EQ, hab den zwar schon im Einsatz, aber nur sehr rudimentär.
Super Job Igor
RevAngel
122 Kommentare 89 Likes
Danke an Igor für den Artikel!
Und auch danke an die Kommentare bisher. Wünsche Euch allen alles Gute für 2024!
Xaphyr
67 Kommentare 65 Likes
Naja, soweit würde ich nicht gehen. Aber seit dem Edition XS verstaubt der 1990 bei mir tatsächlich. Zusammen mit den Dekoni Elite Sheepskin Pads ist der ist nochmal ein gigantischer Sprung vom HE, gerade bei der Auflösung und Bühne. Allerdings ist der Vergleich natürlich unfair, alleine die Earpads kosten fast so viel wie der HE.
Ansonsten danke für den Test, Planare bekommen nach wie vor definitiv zu wenig Aufmerksamkeit.
Follow Igor:
