GPUs Latest news
Secret change to the sense pins starting from the GeForce RTX 4070 FE and no one noticed it
Sometimes you are blind or just don’t look closely enough. This surprises me, frankly, with the mass of reviewers, but then again, I wasn’t any better. After having examined some headers of the Founders Editions from the current Ada series more closely, I noticed something interesting. Since the GeForce RTX 4070 FE, NVIDIA has already been using a modified 12VHPWR connector with significantly recessed pins! While the GeForce RTX 4080 Founders Edition still relies on the header from the CEM 5.0 with only 0.45 mm offset, the GeForce RTX 4070 Founders Edition has been using a modified variant with 1.7 mm inward offset since its launch, similar to the 12V-2×6 connector.
I have included a simple slider as a reminder, so you can compare the two variants even in the dimensioned sectional drawing.
And because it’s so nice, I will show you a close-up of a dismantled GeForce RTX 4070 from the warehouse. And now, we will move on to this very one.
And what about the board partner cards?
By now, I have been able to take a look at various cards from the launch period and have compared these cards with new stock, or have had them compared. First, we see an MSI RTX 4080 Gaming X Trio White with the familiar header:
And now let’s look at the slightly newer MSI RTX 4070 Gaming X Trio and what do we see there? Oops, it seems like someone has shortened the pins! Mind you, here too it’s the familiar 1.7 mm offset and already a newer header model. But according to the label, it’s still the 12VHPWR with the old H+ label.
And where is the 12V-2×6 header?
Of course, one will ask oneself why one didn’t use the new H++ header right away. As far as I could find out, Astron is already producing it. Otherwise, NVIDIA wouldn’t be testing it there. But there is also something happening with the power supplies, because apparently an OEM like CWT is already using these headers on the power supply side for the new products (e.g. for MSI power supplies). Of course, the question arises why a header that has not yet been fully specified is already being used in mass production. But I hope to find out more about this soon.
It’s really interesting that such a significant change was made here without any communication to the outside. But in some way, this fits with the confusion around this connector. I find this approach of a covert live experiment on the customer quite interesting, although as a patient, I would have liked to know where and how much the doctor is cutting off me. Side effects and so on. Because there was no package insert and you couldn’t ask the pharmacist.
And for tomorrow, I’m going to tease the next green nail in the coffin: What does a GeForce RTX 4060 MSRP card with a real 115 watt power limit deliver? This answer will come tomorrow, because I still have to build all the metrics. It’s basically the scope of the launch article in Full-HD with supervised drinking. That’s sure to be exciting!
Rest in Peace 12VHPWR Connector – Welcome 12V-2×6 Connector, important modifications and PCIe Base 6 | Exclusive
Roland83
708 Kommentare 549 Likes
Frei nach Louis de Funes: Nein! - Doch! - Ooooh! :cool:
big-maec
916 Kommentare 542 Likes
Einfließende Änderungen werden in der Regel nicht kommuniziert, da ist es jedem selber überlassen, wann er das ändert. Das kann wirklich nur jemanden finden, der über mehrere Karten schauen kann.
konkretor
312 Kommentare 321 Likes
Uh da bin ich auf morgen gespannt
Es ist aber gegen die geltenden Specs, das nur mal am Rande :)
Roland83
Da hast du natürlich Recht... immerhin gehts ja hier um einen Standard an dem wohl einfach mal so etwas bei ausgelieferten Produkten geändert wurde. Aber neuerdings überrascht einen ja kaum noch etwas :LOL:
m
meilodasreh
572 Kommentare 284 Likes
ach das sind doch nur ganz normale "CE" Fertigungstoleranzen (ja, der Mittelstrich vom E ist genauso lang wie die anderen)
mblaster4711
53 Kommentare 27 Likes
@Igor Wallossek wäre es beim Slider-Vergleich nicht hübscher gewesen die Grössen der Bilder anzupassen ?
1,699 Kommentare 1,032 Likes
Da hatte Nvidia wohl schon auf die angeschmorten Stecker reagiert und wohl auch reagieren wollen, allerdings ohne hier gleich die Anpassungen groß anzukündigen. Wahrscheinlich auch, um eine ansonsten uU fällige Rückrufaktion (v.a. in den USA) der Karten mit dem ursprünglichen Steckerdesign zu vermeiden. Aber, dank Igor ist jetzt die Katze auch so aus dem Sack.
echolot
1,118 Kommentare 875 Likes
Es kann ja noch mehr passieren, wenn es Probleme gibt...zum Beispiel das Haus fackelt ab...kam wohl direkt von oben. Mit Strom spielt man nicht.
Wenn ich mal gelangweilt bin und ein paar Diener habe, dann mache ich das sicher. Zeitlich wars bisher halt nicht drin, sorry.
Case39
2,550 Kommentare 965 Likes
Zum Verständnis: Würde jetzt mein Adapter von modDIY auf ne 4060 passen?
Roland83
Nein, da die 4060 soweit ich weiß einen stinkormalen 8 Pin (6+2) PCIE ATX Stromstecker hat und keinen 12VHPWR
Exakt. Weil der aktuelle 12VHPWR erst ab 300 Watt eingesetzt werden sollte. Die 150-Watt-Klasse kommt erst mit den CEM 5.1 Specs.
P
Pokerclock
486 Kommentare 422 Likes
Ist doch schön. Kaufe mir jetzt so ne Karte und nach knapp zwei Jahren mache ich einen Sachmangel geltend weil die Buchsen nicht den (damals) geltenden Normen entsprochen haben. :)
Case39
LEUTE...dann halt die 4070. Mitdenken ist nicht, oder?🙄
LurkingInShadows
1,386 Kommentare 584 Likes
Das ausgerechnet von jemandem der mich vermutlich immer noch auf ignore hat da ich ihn auf ein nicht mitgedachtes Zitat angesprochen habe....
Roland83
Er wird mit an Sicherheit grenzender Wahrscheinlichkeit in alle aktuell auf der 4070 verbauten Buchsen passen, aber in keinen der Stecker die du gepostet hast da es immer schlecht ist wenn sich die selben Seiten einer Verbindung treffen.
Case39
r
rokzo
54 Kommentare 13 Likes
Ja und die neu hergestellten 4090/4080, haben die auch schon den modifizierten Stecker?
Natürlich ist es nicht konform dies ohne Mitteilung zu ändern, aber trotzdem sollte dies für die Neukunden, welche die neuen Stecker erhalten, vorteilhaft sein.
Follow Igor:
