GPUs Reviews
Defective graphics cards 20 years ago: ATI Radeon 9800 Pro 256MB and Nvidia Geforce 6800 512MB
There were two upsets in the graphics card sector this year: at the beginning of the year, Nvidia launched the 6 GB version of the Geforce RTX 3050 on the market. However, the cards were not only cut in terms of memory expansion, but also in terms of the entire architecture – in the end, around 20-30% gaming performance was lacking compared to the 8 GB versions. In August, things continued with the Geforce RTX 4070, which is now also available with GDDR6 instead of GDDR6X memory. Although the difference in speed is only marginal, the differences between the two variants are not obvious at first glance.
We can actually still count ourselves lucky these days, because around 20 years ago, graphics cards were much more likely to be fiddled, cheated and lied about. For this article, I have collected two particularly brazen attempts, from which not even the buyers of high-end graphics cards have been spared.
I’ll start with the Radeon 9800 Pro from AMD’s predecessor ATI, which changed hands for just over 400 euros when it was released in the first half of 2003, gave the competition from Nvidia a run for their money at the time and has gone down in hardware history as an icon. On Nvidia’s side, the Geforce 6800 is used, which came onto the market around a year after the Radeon 9800 series and, in contrast to the mediocre previous generation Geforce FX, was generally convincing. With a starting price of around 300 euros, the Geforce 6800 represented the entry into the upper class, as the top models 6800 GT and 6800 Ultra were positioned even higher with a fully unlocked NV40 graphics chip and GDDR3 graphics memory.
Incidentally, the two cards are not directly comparable, as the Geforce 6800 competed against the X800 series from ATI, which in turn represents the next generation of the Radeon 9000 series. One of the reasons for this is the more modern feature set of the Geforce 6800, which already supports DirectX 9.0c with Shader Model 3, while the Radeon 9800 still has to make do with Shader Model 2.0. In addition, the Geforce 6 series was already available for the then newly introduced PCI Express slot, while the Radeon 9000 series was only available for the AGP slot.
Originals vs. cheat packs
  Radeon 9800 Pro “Cheat pack” Radeon 9800 Pro “Original” Geforce 6800 “Cheat pack” Geforce 6800 “Original”
GPU R350 R350 NV40 NV40
Pixel/vertex shader 8 / 4 8 / 4 8 / 3 12 / 5
TMU / ROP 8 / 8 8 / 8 12 / 12 12 / 12
Graphics memory 256MB DDR 128MB DDR 512MB DDR2 128MB DDR
Interface 128 bit 256 bit 128 bit 256 bit
Clock rate chip 378 MHz 378 MHz 325 MHz 325 MHz
Clock rate memory (bandwidth) 250 MHz (8.0GB/s) 338 MHz (21.6GB/s) 300 MHz (9.6GB/s) 350 MHz (22.4GB/s)
Curious: While a sufficient amount of graphics memory seems to be in short supply in today’s generation of graphics cards, there is more than enough of it on the cheat packs – in the Geforce 6800 even four times as much as the original. However, savings have been made in the crucial areas, as a halved memory interface or reduced clock rates have an enormous impact on gaming performance. In the Geforce cheat pack, the graphics chip was even cut by additional pixel and vertex shaders.
The tactics of the cheat packs are clear to see: A large amount of memory was intended to lure inexperienced buyers 20 years ago; after all, the misconception that “more memory = faster graphics card” was still widespread. Many buyers will probably never have noticed that memory bandwidths were cut or clock rates reduced. Incidentally, the blue PCB of the Geforce 6800 cheat pack represents the ultimate recycling of leftovers and was manufactured in calendar week 46 of 2008 (red arrow) – over four years after the graphics chip was released. The Geforce GTX 280 was already available at this time. The free areas of the graphics memory, which explain the halved interface, are also clearly visible.
There are no free areas to be seen on the Radeon cheat pack, and overall the model manufactured by Etonda is quite close to the reference design from a visual point of view. However, the halved interface can also be seen here in detail, as the graphics memory is installed in a straight line on the PCB and not in an “L” shape as in the original.
konkretor
321 Kommentare 329 Likes
einfacg, letzte Seite
ipat66
1,507 Kommentare 1,568 Likes
Schöne nostalgische Morgenlektüre über, um es mal sanft auszudrücken, Augenwischerei und Etikettenschwindel unser so lieb gewonnenen Hardware-Hersteller.
Danke Hendrik für die Auffrischung :)
Antwort 5 Likes
10,962 Kommentare 20,790 Likes
Ich glaube, ich muss auch mal im Lager nachsehen, was meine Oldies so machen. Nur der Ultra-Buckelwal ist hin, der braucht keine Hilfe mehr :(
karre
35 Kommentare 25 Likes
Schöner Beitrag. Auch die FX5200 ist da ein guter Kandidat zu diesem Thema :)
1,900 Kommentare 1,193 Likes
Danke für die Erinnerung! Die 4060 Ti mit 16 GB ist ja, wenn keine Mogelpackung, dann zumindest ein Fall von GPU mit angezogener Handbremse. Der Speicher ist schon da, nur kommt die GPU kaum in den Genuss der ganzen teuren Pracht, denn dafür ist der Bus einfach zu schmal.
L
Ladykiller
38 Kommentare 20 Likes
schöner bericht, danke dafür. nächster teil geforce 6200turbo cache und gtx970 3,5gb mit 512mb bildspeicher gratis dazu bitte :)
p
prinzkarneval
1 Kommentare 0 Likes
Schöner Artikel !
Das waren zwar auch schon Zeiten, wo die beiden Big Player im Markt den Kunden gezielt hinters Licht führen wollten, ABER:
Nvidia Karten zu der Zeit und noch eine Weile danach konnten per Firmware Mod freigeschaltet werden und bei den Radeons griff man auch noch erfolgreich zum Lötkolben. So konnte man sehr schön eine Radeon 9500 so zu einer 9500 pro aufwerten.
Leider sind Nvidia und AMD heutzutage schlauer.
FfFCMAD
770 Kommentare 238 Likes
Ich sag nur Geforce 4 MX 440
Bin damals auch drauf reingefallen. Ne Geforce 2 mit minimalen Verbesserungen war das... Nix Geforce 4, nicht mal Geforce 3.
Die Karte war sogar mit UT99 überfordert.
War damals ein Schnelllauf, war nicht gut informiert, hatte nur Geforce 4 im Kopf... Seit dem gucke ich vorher ^^
A
Arcbound
147 Kommentare 107 Likes
Ha, ich hatte damals ne 9800 Pro AiW. Das war schon ein Erlebnis, als man in Games dann plötzlich die Details hochdrehen konnte 😁
Riegelstriegel
112 Kommentare 62 Likes
Ich hatte eine. Die war in einem Komplettrechner von Acer verbaut. Hammer-Specs, Pentium 4 mit HT, 1GB RAM und eine 6000-er Nvidia-Karte. Was konnte schiefgehen.
Naja, der "Turbo Cache" hat dann doch nicht so angeschlagen (war glaube ich ein Euphemismus dafür dass die Graka Daten in den RAM auslagert) und ich hab kurz danach eine 6800 GS gekauft.
RaptorTP
352 Kommentare 183 Likes
Retro, hier ?
Ja geil. Danke!
Hab mal geschaut. Hatte 2023 eine Radeon 9800 Pro AiW hier. 256bit :)
Bilder kommen nachher - Update:
Bild vom Röhrenbildschirm, logo:
amd64
1,126 Kommentare 701 Likes
Wegen NFS Underground musste ich "leider" auf eine ATI 9800pro aufrüsten, es ging nicht anders. Die Details mussten hoch! 😄
m
miwin1977
38 Kommentare 10 Likes
danke, jetzt fühl ich mich alt. ;)
amd64
Mein letzter echter Firmware-Mod war eine Radeon HD 6950 -> 6970. Frühe Versionen konnten mittels BIOS flash umgeflashed werden. Mit einem besseren Kühler bekam man dann trotz wackeliger Stromversorgung sogar noch etwas OC hin. Leider hatte die Karte nur 1GB und flog deswegen früher als nötig raus, lief aber noch jahrelang bei einem Kumpel ohne Probleme.
DigitalBlizzard
3,272 Kommentare 2,282 Likes
Moin und danke an @ Hendrik ( welcher Nick überhaupt?)
Ja, Mogelpackungen sind weißgott keine neuzeitliche Erfindung, doppelter RAM bei halbiertem Interface, noch immer gerne genommen, eine Frage der Kosten.
Retro hat auch Nachteile, wehmütig liest man ATI 9000 und denkt daran zurück das ATIs Ende mit 9000 und zuletzt X begonnen hat, ich will jetzt ja nicht unken, aber bei AMD steht auch bald 9000 an und die Entwicklungen sind derzeit da gerade nicht als hoffnungsvoll zu bezeichnen. Rückzug aus dem HighEnd Markt usw.
Aber schön trotzdem das hier immer mehr neues ( auch wenns Retro ist ) kommt, immer mal eine schöne Auffrischung und eine willkommene Abwechslung, wie beim Cocktail, die Mischung ist der Schlüssel zum Erfolg.
big-maec
988 Kommentare 598 Likes
Das erinnert mich so an die Nvidia GT 7xx Serie mit 2 GB DDR5 empfand die kleineren Chips als Mogelpackung. Von denen müsste ich eigentlich noch was hier herumliegen haben wegen PCI Bus, einmal in der Desktopversion und einmal eine Gamingversion.
DigitalBlizzard
Ich habe definitiv in den unendlichen Weiten des Lagers noch einige HIS Radeons, auch IceQ Modelle rumfliegen, hatt sogar mal einen Shuttle Barebone XPC SN45G Sockel A der in einer geairbrushten Edition mit irgendeinem Gaming Theme daherkam und die passende Nvidia Gainward FX5900 Ultra hatte ich auch dazu, alter bin ich alt
Antwort 6 Likes
RaptorTP
und noch die Rückseite ... also was Bilder hochladen angeht ist das Forum schon etwas arg begrenzt :/
c
carrera
156 Kommentare 96 Likes
what a blast from the past :) ... danke @_chiller_ ...
Die 9800er habe ich gerne verbaut... und ganz früher - ich erinnere mich noch gut an den TSENG ET4000 (da habe ich einige Maschinchen mit gebaut) und an die ATI-Mach8 8514 Ultra ... (https://www.os2museum.com/wp/the-8514a-graphics-accelerator/) ... mit der alleine konntest Du nicht mal booten. hast also noch ein DOS-ISA-Kärtchen benötigt... remember the times ...
Follow Igor:
