We recently tested two visually appealing mini systems from the Geekom brand. According to the comments, you also liked the elegant aluminum housing, although it doesn’t only offer advantages. Both times an AMD processor was used, but with the GT13 Pro this changes today. So let’s take a look together at what this gray version has to offer.
Click here for the review of the silver AMD version:
Geekom A8 Mini-PC in test – A Ryzen 8945HS at the physical limit
The box was designed to match the contents and is mostly printed in black. The front is dominated by a large product image, while the back only has a sticker with some key data.
When you lift the lid, the GT13 Pro appears to be standing on a small pedestal.
There areno big surprises when it comes to accessories; the usual range of power supply unit, HDMI cable and combined VESA or wall mount are included.
Incidentally, the power supply unit comes from hyleton and can be found under the model number 120W-1906320.
Specifications
Before we get to the details, here is an overview of the key technical data. Further information can be found on themanufacturer’s product page.
[the_ad_group id=”7834″]
7 Antworten
