With a breathtaking refresh rate of 540 Hz and a lightning-fast response time of 0.2 ms (GtG), the AG246FK offers a smooth and responsive gaming experience that will delight even the most demanding gamers.
![](https://www.igorslab.de/wp-content/uploads/2024/04/AG246FK-2-980x776.webp)
Technical data at a glance:
- Display: 24.1 inch TN panel
- Resolution: 1920 x 1080 pixels (Full HD)
- Refresh rate: 540 Hz
- Response time: 0.2 ms (GtG)
- Brightness: 400 cd/m²
- Contrast ratio: 1000:1
- Viewing angle: 178°/178°
- Color gamut: 100% sRGB
- HDR: HDR400
- Connections: 2x HDMI 2.0, 1x DisplayPort 1.4, 4x USB 3.2 Gen 1
- Extras: RGB lighting, VESA mount compatible
The heart of the Agon Pro AG246FK is the record-breaking refresh rate of 540 Hz. This means that the display refreshes 540 frames per second, which is a massive improvement on standard 60 Hz or 144 Hz monitors. This high refresh rate virtually eliminates frame lags and tearing, so you can experience any gameplay smoothly and without annoying interruptions.
Lightning-fast response time for precise control
To take full advantage of the high refresh rate, the Agon Pro AG246FK has an ultra-fast response time of 0.2 ms (GtG). This means that the pixels on the display can change from one color to another in just 0.2 milliseconds. This is particularly important for fast games such as first-person shooters or racing games, where every millisecond counts.
![](https://www.igorslab.de/wp-content/uploads/2024/04/AG246FK-3-980x776.webp)
TN panel for uncompromising speed
While TN panels have been criticized in the past for their limited viewing angles and colour accuracy, modern TN panels such as the Agon Pro AG246FK have largely overcome these limitations. Thanks to advanced technology, TN panels now offer excellent response times and refresh rates that are ideal for e-sports and competitive gaming.
![](https://www.igorslab.de/wp-content/uploads/2024/04/AG246FK-4-980x245.webp)
Additional features for an optimized gaming experience
In addition to the impressive refresh rate and response time, the Agon Pro AG246FK offers a range of other features that enhance the gaming experience. These include:
- HDR400 support: HDR400 expands the contrast range of the display, allowing for a more realistic representation of colors and details in dark and bright areas.
- 100% sRGB color gamut: The Agon Pro AG246FK covers 100% of the sRGB color gamut, ensuring accurate and vivid color representation for gaming and other content.
- RGB lighting: The monitor features built-in RGB lighting that can be customized to match the mood of your game or setup.
- VESA mount compatible: The Agon Pro AG246FK is compatible with VESA-compatible wall mounts, allowing you to position the monitor for optimal ergonomics.
The AOC Agon Pro AG246FK is a no-compromise gaming monitor designed for e-sports enthusiasts and hardcore gamers looking for the ultimate competitive edge. With its record-breaking 540Hz refresh rate, lightning-fast 0.2ms response time (GtG) and a host of other features, the Agon Pro AG246FK delivers a smooth, responsive gaming experience
Source: Club386
18 Antworten
