GPUs Graphics Reviews
KFA2 GeForce RTX 4070 EX Gamer (1-Click-OC) 12 GB Review – Cheap OC card, extra cool & quiet, with a lot of ARGB
Despite all the features like higher power limit, 3-fan design and ARGB, the KFA2 GeForce RTX 4070 EX Gamer (outside EU sold as Galax) belongs to the inexpensive models of the GeForce RTX 4070 series, which are now also sold well below the MSRP. So good, so exciting. Because the current street price is around 629 Euros and is really a real challenge to all the competitors. But how does that actually work when you look at the other competitor products in comparison and many features are simply missing at the same or even higher price? Ok, I kind of feel challenged to question this.
The card already uses a power limit of 215 watts from the factory, which is quite enough. Let’s remember my launch article, where even the NVIDIA RTX 4070 FE never really got above 215 watts despite the 220 watt power limit. This makes the card tested today a true OC card with non-OC default clock and the easy chance for the one OC click in the in-house software (gladly also via app) that is so fondly advertised by marketing. I would still set it manually, because the 3 GHz mark is definitely in there, depending on the chip lottery. And you could have done it right from the factory and thus kept the product name a bit shorter.
Why the MSRP card has a power limit of 215 instead of 200 watts (officially even allowed) has a very piquant background, which I explained in an extra article (link below). Because nothing has been written or leaked about it yet. That comes then exclusively from me 🙂
Of course, there is, as usual, the comprehensive teardown, an extensive PCB and cooler analysis with some reverse engineering, as well as the analysis of the power consumption and the load peaks including a suitable power supply recommendation. After all, we want to know everything in detail. Since I know that many colleagues will also repeat all the technical details including theory, which have already been presented in various tidbits, I’ll spare myself that today on a large scale and only briefly refer to the already known data. All cards with a factory clock or OC are within a tolerance range of less than 1%. These are measurement errors that can be safely ignored. The rest is decided by the selected chip anyway.
Various binnings in NVIDIA’s GeForce RTX 4070 – MSRP cards with unintended OC feature and the technical background (of Boost) | Exclusive
The AD 104 and the new Ada architecture
The 294.5 mm² chip of the NVIDIA GeForce RTX 4070 is also manufactured in the TSMC 4N process and has 35.8 billion transistors. The AD104-250 still has four Graphic Processing Clusters (GPC) and 46 new Streaming Multiprocessors (SM) with 5888 CUDA cores, whose performance and energy efficiency has increased significantly compared to Ampere. Add to that 184 4th generation Tensor cores and Optical Flow, enabling transformative AI technologies including NVIDIA DLSS and the new frame rate multiplier NVIDIA DLSS 3.
The 46 3rd generation RT cores provide up to 2x ray tracing performance, Shader Execution Reordering (SER) also improves ray tracing operations by 2x. In addition, there are a total of 23 Texture Processing Clusters (TPC), 184 Texture Units (TU) and 64 ROPs. The L2 cache is a total of 36864 KB and the card, like the GeForce RTX 4070 Ti, uses the familiar 12 GB GDDR6X with 10500 MHz clock on a rather narrow 192-bit interface, which corresponds to a data rate of 21 Gbps and a bandwidth of 504 GB/s. The AD104-250 of the GeForce RTX 4070 only offers one NVDEC (decoder) instead of four and a single NVENC (encoder). The AV1 encoder is said to work up to 40% more efficiently than H.264.
KFA2 GeForce RTX 4070 EX Gamer (1-Click-OC) 12 GB in detail
The card weighs 1063 grams, which puts it in the same weight class as NVIDIA’s Founders Edition. The length of 32.5 cm is anything but short and the height of 12 cm is also a bit above normal. You’ll need a lot of space in the case, even if you don’t have to use a 12VHPWR adapter. The installation depth is 4.3 cm plus the 5 mm for the backplate on the back. Thus, it is a rather expansive 2.5 slot card.
The design language of the fan, cover and slot bezel follow the company’s language and don’t surprise. The feel and look are of course also somewhat due to the price, even though there is of course ARGB galore. Two 9 cm and one 10 cm fan have the full power, plus the GeForce light field on top. The RGB has not been spared.
The card still relies on a PCIe Gen. 4 interface and the nice 8-pin connector, which has been recessed really deep. The default TBP is 215 watts and can’t be raised any further (which is pointless anyway, because then the voltage limits anyway). That’s also the reason for using the 8-pin connector, although it gets a bit tight. But I’ll come to that later,
You can not only put power into the card, but also video connectors. There are four of them, to be exact, as there are: three DisplayPort 1.4a and one HDMI 2.1a. That’s a shame, especially with the DisplayPort, when it comes to the new specifications. A missed opportunity, unfortunately. And with HDMI, you have to trick with the compression from 4K onwards if you want it to go above 120 Hz. I’ll go into the four screws in the direction of the cooler later in the teardown, because they are incredibly important.
The screenshot from GPU-Z shows us the default settings of the RTX 4070, which are almost identical for all cards:
This is the first page and we are slowly preparing for the test. For the forgetful or newcomers, I have also linked the launch article again, which offers more details and my comments on the MSRP cards:
T
TheSmart
432 Kommentare 216 Likes
Joa abgesehen vom "Running Gag" wofür der Hersteller ja nichts kann.
Ist das eine richtig gute Karte.
Mir gefällt hier vor allem das Kühlsystem bestehend aus direkt 3 Lüftern. Sowas sorgt bei so einer Karte direkt für ein deutlich angenehmeres Betriebsgeräusch.
Die RGB-Farbenpracht dagegen brauche ich nicht..aber ist mir auch völlig schnuppe, weil der Hersteller dafür keinen Aufpreis verlangt. Und ich sowieso nur geschlossene Gehäuse benutze.
Die Karte bestätigt mir wieder: Man sollte möglichst nie zu den "Erstkäufern" gehören.
Denn die mussten sich dann erstmal mit den fast schon nur mit Panzertape zusammengehaltenen Billigkarten zufrieden geben.
Und jetzt kommen durchaus ansehnliche Karten heraus, wo man das ganze mit ein bisschen Grips angegangen ist.
echolot
1,118 Kommentare 875 Likes
Ich finde es erstaunlich, dass die 3080 bei 1080p und 2160p langsamer ist und bei 1440p immer vorne liegt. Woran liegt das?
pantsuki
37 Kommentare 6 Likes
ich würde behaupten das 1440p der "standart" ist und es dafür optimiert ist.
Megaone
1,833 Kommentare 1,726 Likes
Deutlich schneller als eine 2080ti mit 1 GB mehr zum halben Preis.
Kann man ja auch mal so sehen.
Ausserdem glaube ich, das bei den "Straßenpreisen" auch noch was passieren wird.
Aber Igor, weiss man eigentlich wo es bei der 7800er Serie hakt?
Wieso dauert das so lange?
Man kann sich zwar mit der aktuellen 6000er Serie noch ganz gut behelfen, aber im Sinne des Erfinders ist das ja alles nicht.
T
TheSmart
Ja das denke ich auch. Eine 3080 vernachlässigt eher den 1080p Bereich, weil dafür die nächst niedrigere Variante vorgesehen ist und bei 2160p ist der Vorsprung eher hauchdünn finde ich. Das könnte auch an den 2 GB mehr VRam liegen. Da wurde ja die 10GB Variante als Benchmarkreferenz genutzt.
Und im Prinzip muss man es wohl so sehen.. ist eine 4070 wohl nichts anderes als eine weiterentwickelte und optimierte 3080. Nur halt für die entsprechende Zielgruppe optimiert.
Nicht ganz. In Ultra-HD bricht die 3080 überdimensional ein (Speicher) und ist mit DLSS deutlich langsamer (alte Tensor- und RT-Cores). In Full-HD ist lustigerweise der Treiber-Overhead der 4070 etwas geringer, was die CPU weniger limitieren lässt. Das sind aber keine neuen Erkenntnisse :)
echolot
FritzHunter01
1,216 Kommentare 1,649 Likes
Das wäre genau die richtige Karte für den PC meiner Frau. Die passt optisch sowas von ins System... RGB ftw!
Die 12 GB halte ich zwar in Punkto Zukunftssicherheit für fragwürdig, aber besser als die 8GB der 3070Ti. Hinzu kommt, dass die 4070 deutlich effizienter läuft als die 3070Ti und mehr Leistung bringt die 4070 auch noch mit. DLSS 3 Frame Generation für single player kommt ja auch noch on top!
Aus meiner Sicht ist die KFA2 EX Gamer die beste 4070 auf dem Markt und optisch sowieso die schönste!
Jicaraen
54 Kommentare 29 Likes
Auch wenn es mich juckt, allerdings 12GB sind mir zu wenig und ich zocke nur in WQHD ein Upgrade von meiner 3070 lohnt einfach nicht. Vor allem nicht bei dem Preis. Mal sehen wann AMD endlich die 7800er Karte präsentiert und was diese liefern gerade im Hinblick auf Effizienz.
R
Robofighter
91 Kommentare 33 Likes
Guest
Kfa ist nice die 2070super eine kollege läuft noch immer gut :) aber surren hört man da bei dem sound sample wohl pech gehabt^^. das hat meine null komma josef :D
Guest
Habe jetzt über 50 games durch in 4k nicht einmal wurden die 12gb annähernd voll auch nicht in den neuen spielen :)
R
Robofighter
Jicaraen
Tests zu diversen neuen Spielen zeigen was anderes. Anyway. Ich denke es lohnt sich für mich einfach nicht.
R
Robofighter
Ultra HD = 3840x1440? Bitte korrigieren.
Guest
Aha wo denn ? wie gesagt ich schaffe es nicht ausser ich forciere 8k. last of us sind es 10gb
forspoken sind es 9gb. imnetz steht so viel müll
Guest
seit wann ist 1440p ultra hd.
R
Robofighter
Ich denke 12gb werden noch eine Weile reichen nur nicht bei schlecht programmierten Spielen oder zu frühen, nicht optimierten Neuerscheinungen.
Jicaraen
hardwareluxx, computerbase. Teilweise auch golem und heise. Jetzt nicht unbedingt Seiten, die Müll in die Welt setzen.
Follow Igor:
