Cooling Reviews Watercooling
G.Skill ENKI 360 All-in-One compact watercooler Review – first attempt successful, but with weaknesses
When you hear the name G.Skill, the vast majority of people will think of memory. A few may still have peripherals in the form of a mouse, keyboard and headset. But coolers? That’s new! So it was a big surprise when I was shown the new ENKI series and offered it for testing. With the power of the Sumerian god of water and no less than three versions in 240, 280 and 360mm, they want to expand their own product range a little.
In the following article you will find out if the first steps are successful or if it rather ends with a fall:
The box is mostly in the manufacturer’s colors of black and red. The front shows a large product picture with a bit of color around it, then on the back there are exact dimensions and technical specifications. All the pages around are left unused, apart from the product name.
While the exterior design still adheres to the unofficial standard, there is a rather rare sight on the inside: A large block of foam has been chosen for the transport protection. The pump head was additionally protected with several layers of foam foil, so well armored the AiO should survive even the bumpiest delivery route. The disadvantage is of course the environmental aspect, more about that in a moment.
Because what they did with the repackaging of the accessories is really over the top. 13 is the unlucky number and here also the number of bags. If you sell certain substances in addition to your PC hobby, you can get a supply of packaging material right here.
Even if neatly divided accessories are not bad in themselves, here one has overdone it. And if you haven’t noticed: Despite the many parts, they don’t include a PWM splitter with three fans. So depending on the number of case fans, you may have to get your own splitter or fan hub.
Finally freed from the foam block, a first look at the ENKI 360 can be taken. According to G.Skill, the focus is on performance, and the design is accordingly rather plain. Apart from the illuminated RGB ring on the pump head, the rest of the AiO is kept in black.
An oblique look at the cooling fins shows some bent fins, despite the good packaging. Performance losses are not to be expected, the whole thing is still within acceptable limits.
But what is already negatively noticeable are things like impurities in the pre-applied thermal paste or fibrous nylon sheathing of the hoses. Other users report both problems as well, so there seems to be a lack of quality control.
Assembly and installation
When mounting on the AM4 socket, you don’t reinvent the wheel and simply use the existing blackplate, put four spacers on it and fix the two brackets with four screws. After that it gets a bit trickier, because screw, spring and washer come as single parts and have to be pressed onto the CPU at the same time as the pump block. A third hand would certainly be helpful, alone one gets it best with the mainboard lying on the table. Here, too, there is room for improvement.
The three 120mm fans are attached to the radiator quite regularly with long screws, the corners are decoupled on the front and back with the same rubber pads. By the way, the coldplate hidden under the thermal paste is slightly convex
Specifications
Here is the overview of the technical details, more information can be found as always on the manufacturer’s site.
G.Skill ENKI Series AiO ENKI 360 (GW-DTNL9A1P-A360XG1)
Tim Kutzner
874 Kommentare 714 Likes
Tja, da hätte man doch lieber nochmal etwas länger dran gearbeitet oder besseren OEM genommen :D
Wo würdet ihr die AiO realistisch im Preis einordnen, die 5 Jahre Garantie mit bedacht?
Z
Zoomman
3 Kommentare 0 Likes
20€ weniger und bessere Lüfter wären eine feine Sache.
30% mehr Umdrehungen bringen scheinbar nur knapp 0,9C und das in einem offenen Aufbau.
B
BloodReaver
56 Kommentare 20 Likes
Die Eisbaer Aurora 360 fehlt mir noch im Benchmark. Die wurde von dir ja noch vor nicht all zu langer Zeit getestet :)
Tim Kutzner
10,658 Kommentare 20,067 Likes
Es wird demnächst die Aurora mit neuen Lüftern geben. Die werden wir sicher auch noch einmal testen :)
F
Fonsa
60 Kommentare 54 Likes
Bitte weniger Einlassungen über die Verpackung und den Umweltaspekt, dafür die Specs in den Artikel kopieren.... Abgesehen davon ist der Verpackungsmüll einer wegwerf AIO das kleine "Problem" ;)
Die Specs sind doch drin...
Tim Kutzner
Siehe Ende der ersten Seite
F
Fonsa
Sorry, lese den Artikel auf dem Smartphone, sehe es jetzt auch. Das ist leider bei mir sehr dunkel und hab es deshalb nicht gleich gesehen. :)
B
BloodReaver
Oh wirklich? Die aktuellen sind ja auch nicht schlecht. Bin ich gespannt :)
B
Basti198320
17 Kommentare 2 Likes
Für die wahrscheinlichen Preise könnte man aber ruhig noch ein wenig mehr RGB 💡 verlangen... Wenn die AIO dann auch noch ungenaue RPM angibt, ist es eigentlich noch zu früh diese sein eigen zu nennen. Interessant wäre eigentlich, bei den Test das Temperaturverhältniss des Radiators im stehenden und hängenden Zustand. :unsure: :coffee:
Wurden eigentlich schon die Corsair Capellix 360er AIO getestest?
Tim Kutzner
Ja, ist doch auch im Vergleich auf der zweiten Seite dabei.
E
Extra300s
78 Kommentare 10 Likes
Ich bin im Thema Wasserkühlung jetzt noch nicht sehr lange dabei, hab aber schon etwas Erfahrung sammeln können. Beim Lesen des Artikels ist mir aufgefallen, dass nicht nochmal erwähnt wird, dass hier ein Aluminium-Radiator und ein Pumpen/Kühlblock aus Kupfer verwendet wird (kann aber auch sein, dass ich das komplett überlesen habe). Ich weiß, dass in der Kühlflüssigkeit definitiv Zusatzstoffe enthalten sind, die Korrosion verhindern sollen, jedoch bezweifle ich stark, dass man das zu 100% schafft. Was mich dann dazu bringt, dass 5 Jahre Garantie sehr gewagt sind. Oder hab ich da irgendwas wichtiges übersehen? Ansonsten finde ich für eine 360er AIO den Preis sehr hoch, vorallem, wenn man bedenkt, dass man "nur" einen Aluminium Radiator bekommt. Da würde ich persönlich dann lieber zu Alphacool greifen, wo ich weiß das alles aus Kupfer ist.
Generell noch danke für die Tests.
Tim Kutzner
Kupferblock und Aluminium-Radiator ist Standard bei 99% aller AiO-Wasserkühlungen, daher nicht erwähnenswert und idR auch absolut kein Problem :)
Man kann sich als Hersteller zwischen
.. mehr Zusatzstoffen = weniger Kühlleistung + längerem Lebenszyklus vor Korrosion
.. weniger Zusatzstoffen = höherer Kühlleistung + kürzerem Lebenszyklus vor Korrosion
entscheiden. Der Sinn einer AiO ist ja auch nicht unbedingt, eine Custom Loop zu ersetzen, sondern eine einfache sowie wartungslose Alternative zu bieten. Eine "richtige" Wasserkühlung setzt du nicht so schnell in deinen PC wie eine AiO :p
E
Extra300s
Erstmal danke für die schnelle Antwort. Und ich finde das echt krass. Ich hätte gedacht ab einem bestimmten Preis könnte man damit rechnen nur eine Sorte von Metal im Loop zu haben. Da hab ich mich wohl getäuscht, hab deswegen gerade nochmal im Internet geschaut und ja, die etwa gleich preisigen AIOs von NZXT oder auch Corsair haben alle einen Aluminium Radiator und eine Kupfer Bodenplatte. Ich mein die AIO von Alphacool ist preislich ja etwa gleich , ist komplett aus Kupfer, da sag ich Mal good Job Alphacool, somit eine der wenigen (wenn nicht die einzige) AIOs komplett aus Kupfer. Hat jemand schon Mal nach 5 Jahren so eine Metallmix AIO auf gemacht? Würde mich echt interessieren in wie weit der Korrosionsvorgang gestoppt wird.
Tim Kutzner
Liegt eben auch daran, dass die OEMs ihre Fabriken nicht mal eben so umstellen und die Kühlleistung ja trotzdem gut sein kann.
Nicht die Einzige, aber eine der Wenigen :D
Soweit ich weiß, benutzt Gamers Nexus seit bald 5 Jahren die NZXT Kraken irgendwas und die laufen weiterhin.
Korrosion ist meistens nicht das Problem, eher andere Faktoren
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
