GPUs Graphics Latest news
Unicorn: PowerColor RX 6700 XT with correct pads and wrong assembly
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
Sure, this card is probably more of a one-off, but whoever has the this card doesn’t have to worry about the junk like that. And since you can’t reliably get temperatures displayed on the GDDR6 on AMD cards, you’re left wondering why the card isn’t performing what it could. With the crumbly pads from Ziitek PowerColor has done everything right, because there are certainly no oil sardines like in the last report about MSI and the GDDR6X. Well, what does right mean, something has probably been forgotten.
By the way, the picture rather unintentionally shows that the coolers are supplied by the cooler OEM (supplier) already with assembled pads. A circumstance that makes it almost impossible for companies like MSI to change pads so easily during production. Because the coolers are already in stock in quantities and to replace a pad you would have to remove the old one, clean the surface and then put the new one back on to fit. This costs time and also space, which is hard to find in the strictly optimised cycle lines.
With this I’ll let you off into the weekend and I’d like to explicitly thank the nice reader who made me happy with this pearl of asian serenity. If you also have such or similarly wacky things as picture material, please feel free to send it to me. The mail address is in the imprint. 🙂
T
Toacon
343 Kommentare 143 Likes
Immer wieder erstaunlich, was alles so passiert :D
Casi030
11,923 Kommentare 2,339 Likes
Der Monteur war bestimmt früher bei DFI beschäftigt.....
Martin Gut
7,950 Kommentare 3,703 Likes
An die GPU die schräg auf der Platine sitzt muss man sich auch erst gewöhnen. :cool:
Wenn die Zeit nicht mal für das Abziehen der Streifen reicht ...
Megaone
1,825 Kommentare 1,721 Likes
Willkommen bei der High-End Produktionslotterie.
Vorgartenzwerg42
22 Kommentare 12 Likes
Das macht das Routen der Kontakte nach außen unter Umständen einfacher. Wobei bei den BGA-Chips der Grafikkarten das meiste eh direkt nach unten auf andere Lagen geht.
Bei alten PCBs, die per Wave-Soldering gelötet wurden sieht man das auch oft, hier war es dazu da Lötbrücken zwischen den Kontakten zu verhindern.
Guest
Du schickst die Karte dann in die RMA, die nehmen den Kühler ab, staunen, ziehen die Padfolie ab und schicken dir das Teil wieder zu. Natürlich ohne Begründung weil ja sonst Powercolors Image leidet und alles ist wieder gut.
Powercolor? Produktendkontrolle beim Fertiger=6.
Danke für dergleichen Artikel!
Die gedrehte GPU kennt man von AMD doch schon, Tahiti. Hat was mit der gleichmäßigen Länge der Lanes des SI zum VRAM zu tun und deren Anordnung rund um die GPU. Kürzere Wege des Phy sparen Energie.
Guest
da konnte der Bandarbeiter nichts mit "Remov" oder "emove" anfangen! :ROFLMAO:
p
pedi
269 Kommentare 73 Likes
das wenn EVGA passiert wäre, gäbs wieder geplärre ohne ende.
[wege]mini
32 Kommentare 13 Likes
Die Flasche, die die Pads hätte begutachten sollen.....
Ach, Fehler gibt es überall.
"die Fläsche reinigen" ← Zitat aus dem Text :D
Bei einer Fließbandarbeit sollte so etwas jedoch nicht passieren, da ich persönlich stark davon ausgehe, dass dann alle Karten, mindestens eines Tages, so aus sehen. Das sind dann wohl alles Montagsmodelle und der Typ, der sein "i.o." draufschreibt, war noch bekifft vom WE.
mfg
M
Marf
14 Kommentare 17 Likes
Hi Igor, so absonderlich ist das garnicht,
Guck mal wie meine PowerColor RX Vega 56 Red Dragon zusammengebaut war:
Ich hatte mich schon gewundert, warum der Hot Spot so komische Temperaturen hatte.
LG Marfy
Antwort 12 Likes
E
Ebatman
28 Kommentare 27 Likes
Das kommt davon wenn man das Personal nur noch als "einen Handgriff Arbeitsdrohne" einsetzt und keinem Erklärt was er da eigentlich nützliches gerade macht.
Lerne den Leuten einen Handgriff aber gib Ihnen nicht das Verständniß was für einen wichtigen Teil sie zu dem Produkt beitragen, dann passiert genau so etwas.
Willkommen in der Zukunft des Prozessoptimierten Qualitätsmanagment in dem man per Arbeitsanweisung auch die "einfachsten" Personen einsetzten kann. Nur WEHE man vergisst nur einen einzigen Vorgang, Kontrollschritt exakt aufzuzeichnen oder schludert bei der Einweisung.
Verweigere den Leuten das Denken, und sie erkennen die Zusammenhänge und damit einfachsten Fehler nicht mehr.
Die Intelligenz aus der Fließbandfertigung nehmen um auch mit den billigsten und sofort tauschbaren Arbeitskräften auszukommen.
Und das Managment schnippselt mit der Zeit dann die "Entwickler" (Teuren) raus welche das System aufgebaut haben damit es so funktionieren kann.
Ich habe schon einige Firmen gesehen die hierdurch draufgegangen sind, weil keiner mehr da war der bei einer Änderung die richtigen Korrekturen durchführen konnte.
Antwort 6 Likes
D
Deridex
2,224 Kommentare 858 Likes
Edit: Hier stand Mist der nicht zwingend etwas mit dem Thema zu tun hatte.
Denke mal, dass da einige Probleme zusammen kommen. Wobei ich bei den meisten der Probleme Einsparungen als Ursache sehe.
RaptorTP
327 Kommentare 158 Likes
Ist ja jetzt nix neues, würde ich meinen:
B
Besterino
6,901 Kommentare 3,472 Likes
„If you pay peanuts, you get monkeys.“
Aber: kann mal passieren. Schlimmer als Eintönigkeit ist aber m.E. die Zeitoptimierung / Stress durch Zeitmangel. Das ist schon hardcore, was da zum Teil geleistet werden muss. :(
Ramon
1 Kommentare 0 Likes
Früher hatte man Fachpersonal gehabt und die wurden nach und nach von 5€ die Stunde Jobber eingetauscht, die so viel Englisch können wie ne Maus vom Pizza backen.
Aber es wird überall gespart an Fachpersonal.......l
Zanza
45 Kommentare 8 Likes
Das kommt davon, wenn man schnell sehr viele Karten nach Deutschland schicken muss. Sonst muss der Kunde länger warten und das will er ja nicht. Fachpersonal gibt es genug nur die Entlohnung für das" Fachpersonal" ist zu viel da sonst macht der Hersteller kein Gewinn.
I
Ishe
5 Kommentare 0 Likes
Meine Asus RTX TUF 3090 hatte das selbe Problem, Folie wurde nicht abgezogen. leider keine Bilder gemacht :sneaky:
Sci-Man
147 Kommentare 93 Likes
Leider Gottes sieht das hier in Deutschland nicht anders aus. Ich habe in den letzten 13 Jahren für drei Firmen unterschiedlicher Branchen geabreitet und muss leider sagen "Made in Germany" ist tot. Zumindest dann, wenn es um Serienproduktion geht, denn da wird genauso verfahren wie oben erwähnt. Und dann wundern sich alle warum es nicht mehr läuft, Politiker wie Wirtschaftler.
Es gibt Leute, die machen gerne so monotone Arbeit. Die sagen sich "ich brauch mir dabei um nichts einen Kopf machen, es muss nur laufen". Darunter leidet irgendwann die Qualität, spätestens dann, wenn "Wachstum, Wachstum über alles" gesungen wird, dem Mitarbeiter selbst immer mehr eingetrichtert wird, dass es das wichtigste ist, dass die Maschine/Anlage laufen muss.
Es wird dann zwar immer betont, wie wichtig es sei die Qualität dabei zu wahren, aber WEHE du machst auch etwas pro Qualität, was dann natürlich der Quantität im Wege steht... Nicht selten Packen dann die Fachkräfte ihre sieben Sachen und es kommen die oben erwähnten "Monkeys" die man am liebsten mit heißer Luft bezahlen würde.
Und nein, das sind keine Firmen die um ihre Existenz bangen müssten wenn sie es ein wenig langsamer angehen würden, oder in Mitarbeiter und/oder Maschinen investieren würden. Aber das würde ja etwas von den millionen und milliarden-Gewinnen kosten...
Wie sagte es der neue Geschäftsführer der letzten Firma in der Mitarbeiterversammlung über die begangenen Kündigungen? Ziemlich genau waren die Worte "Der angestrebte Gewinn wurde nicht erreicht". Man beachte dass die Aussage beinhaltet, dass Gewinn gemacht wurde. 🤮🤬
(auch der alte Geschäftsführer wurde gegangen weil er kein Mensch dieser Politik war)
Und am Ende zahlt der Kunde, meißt doppelt: Irgendwann ist er selbst von solchen Maßnahmen betroffen und hat dadurch ein schwereres Leben und zum Anderen die mangelhafte Ware, die auch immer und immer Teurer wird (z.B. verlauf der Preise für GraKas in den letzten 10-12 Jahren).
Antwort 4 Likes
Atze Wellblech
110 Kommentare 21 Likes
Dummheit, Gleichgültigkeit, Absicht, was denn noch alles?
Die Sparmaßnahmen der großen Firmen sind doch allzu bekannt.
Hier über mir sehr gut beschrieben was abgeht.
Damals in Kamp Lintfort, habs mal nen bissle live erlebt weil wir zu dem Zeitpunkt ne Baustelle um der Ecke hatten, wurde gekämpft.
Nämlich um den Erhalt von NOKIA am Standort.
Umgezogen nach Rumänien sind die und haben dort u.a. versucht einheimische "Holzfäller" auf Feinmechanik umzupolen.
Die Löhne lagen mit etwas über 2,50 €uronen weit unter denen der Kamp Lintforter und Bochumer.
Ging gut in die Hose/Produktion, so wie auch hier an den Beispielen.
Ich selbst hatte nur in einer Radeon 6870 einen Wollknollen ungefähr so groß wie eine Daumenkuppe gefunden.
Der roch auch penetrant nach Chemie, irgendwie nicht genau deutbar.
Follow Igor:
