It was less than half a year ago when we last reviewed an ITX case from Fractal Design, and yet we already have another one. The Terra combines the elegant look with real wood from the “North” ATX cases with a small case that still has a trick up its sleeve.
Click here for the article of the latest ITX case from Fractal Design:
Fractal Design Ridge Review – The popular Node 202 ITX case finally also in modern
A simple design has always been important for this manufacturer, which is even evident in the case’s box. Mostly unprinted and only a few inscriptions and logos here and there.
Inside, the use of cardboard and the avoidance of plastic continues, the Terra is protected by a thick cardboard shell at the front and back during transport.
If I can believe the little enclosed letter, it seems that only 4 people at Fractal Design “invented” this case. And a lot of fun and challenges were probably had in the process.
The accessories then consist of a 2.5″ bracket, a cleaning cloth and various cable ties.
A whole slew of screws may not be missing, of course. Depending on how you want to fit the case to your hardware later on, you’ll still need the various spacers.
Specifications
The following is an overview of the technical details, more information can be found on the product page from the manufacturer:
Fractal Design Terra Silver, Mini-ITX (FD-C-TER1N-02)
![]() | siehe Shop | 159,90 €*Stand: 16.07.24 07:40 |
![]() | Onlineshop: lagernd, Lieferung 2-3 WerktageHannover/Laatzen: lagernd (keine Online-Reservierung möglich)Berlin, Dortmund, Düsseldorf, Hamburg, München, Stuttgart: nicht lagerndStand: 16.07.24 06:59 | 159,90 €*Stand: 16.07.24 07:07 |
![]() | Auf Lager, 1-2 Werktage | 166,42 €*Stand: 16.07.24 07:23 |
29 Antworten
