Aircooling Audio/Peripherals Case Fans Reviews
Fractal Design North Follow-Up – temperature behavior with large graphics card and more case fans
Due to the high popularity and the many requests, we are following up today with a small follow-up on the Fractal Design North case. Many users have asked “does this work thermally with a large graphics card?” We got to the bottom of this question, installed a Radeon 6900XT without further ado and Fractal was even able to provide us with additional case fans at short notice. How the North performs with a large graphics card can be read in the review.
Fractal Design really deserves some praise. Not only can these guys build good cases, they also respond extremely quickly to requests from editors. When many readers asked the question mentioned at the beginning in the comments to our review of the Fractal Design North, I directly contacted the press department and asked for a few additional fans for a retest regarding the heat development. They were pleased that their latest creation was so well received and immediately sent the matching fans on their way.
Fractal Design Aspect 12/14 PWM
I already knew the Aspect fans in the RGB version from the Fractal Design Pop Air case. These are relatively simple but solidly made case fans that offer decent performance for the called price of around 12-18€ depending on the size and retailer.
The technical data:
Up to a speed of about 800 rpm, the fans are quite restrained in terms of noise, but individual models tend to clack a bit from the bearing at minimum speed. Since some air is already moved at relatively low speeds and the fans get quite loud at maximum speed, it doesn’t make sense for me to turn them up to full speed.
Guest
Sehr interessante Ergänzung.
Was ich mich aber frage: Merkt man von der geringen GPU-Lüfterdrehzahl real auch etwas oder wird die leisere GPU durch die Mehrzahl der Gehäuselüfter lautstärkemäßig wieder ausgeglichen?
v
vonXanten
813 Kommentare 343 Likes
Danke für die Ergänzung @wuchzael
Also ein schickes kleines Case mit der Option auf mehr ;)
Fractal reagiert übrigens auch auf Fragen von Endkunden bei Problemen/Defekten sehr schnell und kompetent.
grimm
3,193 Kommentare 2,125 Likes
Vielen Dank! Wäre auf jeden Fall ne Option für nen HTPC.
P
Phoenixxl
160 Kommentare 124 Likes
Ich muss unbedingt Bilder von dem Gehäuse meiner Mutter schicken.
Vllt kann ich sie damit überzeugen, dass ihr i5 aus der 4. Generation langsam ausgedient hat...
Wobei das Teil schon lustig ist:
Der i5 läuft standardmäßig auf 3,6 GHz, ließ sich aber ohne Probleme auf 4,2 GHz übertakten.
Da ich auf Wasser umgestiegen bin, thront da ein Noctua NH-D15 drauf. Auf einer 77W CPU.
Die Lüfterkurve habe ich etwas angepasst und so läuft das Teil quasi passiv...
Ich würde aber gerne auf die kleinen 4000er Karten von Nvidia warten...
Aber eine 4050 oder so wird wohl noch laaaaange auf sich warten lassen.
Nagah
115 Kommentare 94 Likes
Besteht vielleicht noch die Möglichkeit die beiden 140er im Deckel als Intake zu testen?
Erscheint zwar unlogisch, aber vielleicht drückt man so noch mehr frische Luft durch den CPU-Kühler zur Grafikkarte, die dann nach hinten raus muss.
Das Ergebnis würde mich noch brennend interessieren. :)
Alexander Brose
836 Kommentare 598 Likes
Leider schon wieder alles komplett zerlegt, weil die Vorbereitungen für den nächsten Gehäusetest schon laufen. Ich befürchte, dass ich das nicht mehr nachreichen kann. Für mein Verständnis macht das aber relativ wenig Sinn, weil warme Luft ja nach oben steigt und ich bin mir nicht sicher, ob das irgendwelche Vorteile bringen würde, die warme Luft nach unten durch den CPU Kühler zu drücken. Vielleicht hat @Igor Wallossek das ja sogar schon mal getestet?
Nein, bei knapp 2000 rpm machen +/- rpm nicht wirklich einen Unterschied. Da die Gehäuselüfter aber generell recht leise sind, ist das ein "fairer Preis" für die verringerten Temperaturen. Die Grafikkarte lässt sich aber mittels undervolting deutlich leiser machen (y)
Grüße!
Nagah
Damit hast du Recht, doch bei Anwesenheit eines Lüfters spielt die natürliche Konvektion von warmer Luft keine große Rolle mehr (behaupte ich mal frech).
Deswegen hätte mich das Ergebnis brennend interessiert. :)
Allerdings habe ich mir schon gedacht dass dein Aufbau wieder weg ist. Aber hey, fragen kostet nichts. :)
Dank dir auf jeden Fall für deine schnelle Rückmeldung!
Haru
117 Kommentare 65 Likes
Konvektion mag zwar n reelles Ding sein, ist bei einem Lüfter aber nachher eher weniger bemerkbar.
Merke ich bspw. bei meinen Toprads. Da kommt die Luft auch unten gut raus.
Werner Wernersen
47 Kommentare 47 Likes
Ich habe ein enormes Kühlungsplus durch einen dritten 140/150er Lüfter in der Front erhalten.
Dieser ist dann von innen, halb verstzetz angebracht, so das sich 1/3 der beiden Lüfter überschneiden.
Nicht optimal, aber es funktioniert.
Ich denke die 2 Lüfter vorn können keinen ordentlichen Strom/Druck aufbauen wenn daneben überall offen ist.
Ich denke 3x120 funktionieren auch besser als 2x140.
Werner Wernersen
Der hintere obere Lüfter drückt ordentlich Warme Luft raus. Ich denke also das wäre nicht Zielführend.
Guest
Vielen Dank für den Bericht,
das beantwortet ein paar Fragen, die ich noch hatte und bestätigt meine Annahme, dass zusätzliche Lüfter leiser laufen oder etwas mehr kühlen.
Mein nächstes Gehäuse wird bestimmt ein Fractal Design Meshify 2, Dephine 7 oder Torrent.
D
Daedalus
158 Kommentare 139 Likes
Vielen Dank für das Follow-up!
MeinBenutzername
214 Kommentare 76 Likes
Danke für den Nachtrag! :)
.Da ich es gerade auf deren Webpräsenz sehe... ob die Variante mit Mesh als Seitenteil & die seitliche Lüfterhalterung noch mehr spürsame Veränderungen mit sich bringen, als ein offenes Seitenteil?:D?
T
TR2013
54 Kommentare 4 Likes
Blöde Frage aber was ist denn das für eine optisch ansprechende Tastatur auf den Fractal Design Fotos?
Alexander Brose
Ich kann sie nicht identifizieren. In der Regel handelt es sich aber auch um gerenderte Fotos von Produkten, die so nicht existieren.
Aber fragt gerne mal weiter nach der Peripherie, vielleicht lässt Fractal sich dann breitschlagen, entsprechende Geräte zu entwickeln 😁
Grüße!
c
checki
79 Kommentare 5 Likes
Das ist absoluter Schwachsinn.
Bester airflow = eine Richtung durchziehen.
dieses links / rechts reingeblase verwirbelt alles und führt zu nichts.
ist ja auch logisch.
und von oben entgegen warmer Luft und quer zum Luftstrom, das ist ungefähr das schlechteste.
Nagah
Grundsätzlich stimme ich dir zu. Aber Luftstrom ist so eine komplexe Welt, da wurde ich schon öfter entgegen meiner Annahme überrascht.
#stayopenminded
Bei Anwesenheit von Lüftern, spielt die natürliche Konvektion von warmer Luft nach oben, keine Rolle mehr.
P.S. Anderen Leuten direkt "Schwachsinn" an den Kopf zu werfen, zeugt nicht grade von geistiger Reife. Schönen Dank auch.
Antwort 5 Likes
Martin Gut
7,955 Kommentare 3,710 Likes
Genau. Ich habe einmal nachgerechnet wie stark die Konvektion in einem PC-Gehäuse mit brauchbarer Belüftung ist (Temperaturunterschied 3 bis 6 Grad). Schon die langsamsten Silentlüfter die ich kenne (Noiseblocker B14-1) bringen bei der langsamsten Drehzahl etwa so viel Druck wie die natürliche Konvektion. Ausser bei solchen Lüftern auf kleinster Drehzahl kann man die Konvektion gut vernachlässigen.
Kavitation ist etwas anderes als Konvektion. Es ist auch ein interessanter physikalischer Effekt dem es sich mal nachzugehen lohnt.
Strömungslehre ist für die meisten kein Fachgebiet, in dem sie sich gut auskennen. Bei meinen Modellfliegern habe ich auch viele Erfahrungen gemacht, die mich überrascht haben. Auch wenn man denkt, man habe langsam ein Gefühl dafür kann einem doch immer wieder etwas überraschen. Leider sehn wir die Luft nicht und wir spüren sie auch nur sehr beschränkt. Das ist einfach nicht so unser Element in dem wir zu Hause sind (natürlich schon, aber ihr wisst wie ich es meine). Wir sind leider keine Vögel die Stunden mit Fliegen verbringen und die Wirkung der Luft mit jeder Feder spüren.
Steffdeff
777 Kommentare 729 Likes
Danke für den Nachtest!
Das Fractal North wird das neue Gehäuse meiner Tochter. Sie hat es gesehen und war sofort begeistert. Das Design war ausschlaggebend, und wenn die Temperaturen auch noch passen, umso besser!
Alexander Brose
