Case Reviews
FRACTAL DESIGN Era 2 Mini-ITX Case Review – From blast furnace to elegant mini fridge with targeted optimizations?
Admittedly, the headline is a bit sensationalist. But compared to the total thermal failure of the first Era generation, things could only get better. Read on to find out how Fractal Design has transformed the Era 2 into a really good ITX case.
With the first Era, Fractal made the fatal mistake of concentrating exclusively on the design of the dwarf case. With fatal consequences, as the thermal performance of the case was torn to shreds in practically all tests and the general ratings were correspondingly negative. A missed opportunity, as FRACTAL DESIGN has already proven several times in recent years that it is possible to build high-quality and high-performance cases. The Era 2 should now have completely left the weaknesses of the first generation behind and because our ITX specialist Tim had to miss out due to a lack of time, I stepped in to test it. As pictures say more than 1000 words, let’s start by freeing the case from its housing.
Unboxing
Scandinavian minimalism starts with the design of the outer box. Apart from the manufacturer’s logo and a discreet inscription, there is nothing to see here.
There it is! The test specimen comes in frosty silver and even with the direct lighting, you can already get an idea of the elaborate design.
Minimal curvatures make the Era 2 look like a work of art.
Although the front I/O also looks very minimalist, the connectivity leaves nothing to be desired. Well, you have to do without the reset switch, HDD LED and the separate jack connections, but this is the rule rather than the exception, even with large ATX cases.
Both side panels are perforated over a large area – apparently they have learned from the catastrophic ventilation of the first Era.
Viewed from behind, the Era 2 reminds me of a fusion of an XBOX 360 and a NAS drive. Simple and tidy, we will come back to the individual elements later.
And from this perspective, we also see the wooden roof for the first time. Who would have thought that the wooden elements of the Fractal North would be so well received that they would make it into the ITX segment? Between you and me: I think it’s dead chic!
Elegant down to the smallest detail:
The wooden panel is mounted on a metal support frame, which in turn is held in position magnetically. A clever solution, as the waste heat is likely to damage the wood over time, so it is protected by the metal support.
Back to the rear. The “handle” at the bottom turned out to be a pull-out dust filter for the intake fans in the floor:
But the insert not only serves as a dust filter, it also operates the mechanism for unlocking the aluminum cover of the Era 2. A discreet symbol already hinted that there was more to it than that.
Once the mechanism is unlocked, the cover can be pulled upwards in one piece:
A look inside the cover once again underlines the completely new approach of the Era 2. Air supply is the motto and, as you can see, this can be achieved without compromising on design.
Without the lid, you start to get an idea of the structure of the interior. Interesting approach!
The left-hand “chamber” accommodates a vertically mounted graphics card and two 2.5″ drives.
Even at first glance, it is noticeable that even ballers >30cm long and 3 slots thick would fit here.
Two 120mm Aspect 12 fans are fitted in the base ex works to ensure an adequate supply of fresh air.
I explain what this “mechanism” is all about on the second page.
Viewed from the front, the right-hand side offers space for an SFX(L) power supply unit.
And of course for the ITX mainboard.
At least 0.1 points are deducted for the absence of the ever-popular “centering nub”. All four corners are fitted with simple spacers.
And at this point at the latest, as an ITX novice, I was a little confused. Isn’t that somehow “the wrong way round”? Resolution follows..
The next mechanism is already hidden in the lid. I wonder what the lever does with this arrow?
Oh look! This allows you to unlock the lid and install fans or an AIO water cooling system conveniently and without taking up too much space.
Finally, the enclosed accessories and paperwork:
p
pinkymee
130 Kommentare 157 Likes
Es ist wirklich ein sehr schönes Gehäuse. Gefällt mir. Alugehäuse von Lian Li sind auch nicht günstiger. Das Fractal Design Era 2 punktet in meinen Augen mit jeder Menge Features, die sonst nur sehr wenige anbieten. Ich finde es sehr gelungen. Danke für den tollen Test! (y):)
Antwort 5 Likes
RedF
5,127 Kommentare 2,931 Likes
Ja das Ding gefällt : )
HJD1966
11 Kommentare 9 Likes
Guten Morgen,
das ist ein fast unglaublich hübsches, feines, kleines Gehäuse! Interessanterweise hatte ich überlegt, genau so etwas in der Art (selbst) zusammenzuschrauben. Insbesondere die Montage der GraKa ist prima gelöst; auf einem Threadripper-Board (TR 4) hatte ich wegen des „Durchhängens“ der Komponenten mal massive Probleme mit der Systemstabilität, die sich erst durch horizontalen Einbau des Board in ein Cube-Case lösen ließen - Halterungen zum Abstützen hatten nichts gebracht.
Der Preis ist m. E. angesichts der hervorragenden Umsetzung noch gerechtfertigt, die Materialgüte und die Optik fügen hier ihren Teil bei.
Eine Bitte hätte ich noch: Da ich kein Freund von WaKü bin, wäre ein Test mit Lüfterkühlung sehr wünschenswert.
Falls das mal möglich wäre, herzlichen Dank!
Smartengine
153 Kommentare 140 Likes
Schaut wirklich gut aus.
Eines gibt mir aber zu denken. Der hintere untere Lüfter liefert sich ein Duell mit dem Netzteil da der Luftauslass des Netzteiles nach unten gerichtet ist.
Wird vermutlich bei dem Stromverbrauch nix viel ausmachen, bei manchen Netzteilen würde ich mir aber sorgen um ein verfrühtes ableben machen.
Dem schließe ich mich an da hier eher im Normalfall Mitelklasse komponenten verbaut werden. Auch wenn intel derzeit ein "bisschen" heizt ;)
P
Pokerclock
563 Kommentare 500 Likes
Als ich anfing ein paar neue Miet-PCs zu konzipieren (ITX, klein, drei in eine Kiste, weniger schleppen und so), war ich vom Schiebemechanismus im Terra sehr begeistert. Diese Illusionen sollten sich recht schnell zerstreuen, denn das ist zuweilen eine recht windige Angelegenheit, mit extra großen Löchern, die entstehen. Soll ja Kleinkinder geben, die ihre Finger in alles reinstecken.
Dazu kommt, dass man es am Ende ohnehin in der Standardeinstellung belässt, weil jeder Lüfter, der zu nahe am gelochten Seitenteil ist, extreme Geräusche durch Luftbewegungen erzeugt. Beim Terra kann man den Vergleich toll machen. Klappe auf, klappe zu.
Toll, dass da 3-Slot-Karten reinpassen. In der Realität wird man von nervtötenden, hochfrequenten Luftbewegungen abgenervt.
c
carrera
146 Kommentare 89 Likes
@Alexander Brose: schön geschriebener Test (y) ... eine Frage habe ich doch noch. Die RAM Bausteine scheinen auf einem Foto beidseitg von Kabeln / Schläuchen "umrahmt" ... wird es denen dadurch nicht wärmer?
Tim Kutzner
893 Kommentare 734 Likes
Sehr hübsches Ding :)
OldMan
134 Kommentare 54 Likes
@Alexander Brose erst mal danke für den Test. Ich finde das Gehäuse schon richtig gut gelungen, vor allem optisch. Was mich aber schon an diesen kleinen Gehäusen stört ist dass die irgendwie immer "vollgestopft" wirken. Ich kenne diese Lüftergrills tatsächlich noch ;) Man hat die früher aber außen als Schutz angebracht und nicht innen damit keine Kabel oder Schläuche von den Lüftern geschreddert werden.
Wenn man überlegt dass bei dem Gehäuse auch ein Riser Kabel mit dabei ist, dann relativiert sich der Preis. (Ist das bei allen ITX Gehäusen so?) Klar ist immer noch viel aber man bekommt ja was für sein Geld.
Und, bei einer größeren CPU kommt man um eine AIO nicht herum, da der Platz, max. 70mm, für einen "richtigen" Luftkühler nicht ausreicht.
Ich bin jetzt echt am Überlegen ob ich mein "kleines" AM4 System (5950x) mal versuche in solch ein Gehäuse zu "stopfen", damit könnte ich meine Frau begeistern und mir würde eine menge Arbeit erspart. :cool:
p
passivecool
58 Kommentare 32 Likes
Das wird nicht zufällig verlost? ... 😉
in eine Ära wo für den meisten Familienmitglieder eine APU ausreicht, ist das Angebot an schicken kleinen Gehäusen fürs SOHO leider wirklich übersichtlich. Und das, was da ist, wird, wie hier, Bikini-mäßig bepreist: je weniger, desto teurer.
v
vonXanten
832 Kommentare 367 Likes
Schöner Test,
was mir mal wieder auffällt, der Staubfilter geht nach hinten zu entnehmen. Das ist für mich schlimmer als der fehlende Nupsi für das Board.
Ansonsten das ganze mal mit einer Luftkühlung @Alexander Brose wäre auch nicht uninteressant.
Ansonsten erst einmal ein schickes kleines Gehäuse, wäre bei ITX Builds sicher auch in der engeren Auswahl.
i
istherelifeonmars
75 Kommentare 13 Likes
Joo, sieht richtig geil aus.
Nur die Staubentwicklung von oben macht mir etwas Sorgen, aber da kann man ja dann holzfarbene Nylons einkleben.
T
TheSmart
448 Kommentare 224 Likes
Ein sehr schönes Gehäuse.
Okay der Preis ist auch sehr nett, aber ich denke mal da muss man halt das sehr interessante Design..was sich eindeutig vom sonst üblichen Einheitsbrei absetzt, sowie die Materialwahl (Aluminium ist halt nciht ganz billig) mitbezahlen.
Aber wenn man etwas besonderes auf dem Schreibtisch haben möchte, der muss halt auch mal etwas tiefer in die Tasche greifen.
Zumal es jetzt auch super mit der Kühlung zu funktionien scheint.
Und vlt wird sich der Preis mit der Zeit dann auch ein wenig nach unten einpendeln.
Haeger
13 Kommentare 7 Likes
Die riesigen "Schaukästen" bin ich langsam leid. Deswegen werde ich bei meinem nächsten System auf jeden Fall auch auf die Außenmaße achten.
Von daher gefällt mir das Era 2 sowohl von außen als auch vom Innenausbau. Auf den Holzdeckel könnte allerdings verzichten; ist halt Geschmackssache.
Die Frontanschlüsse lassen bei mir, entgegen der Formulierung im Artikel, jedoch einen Wunsch offen. Ich hätte mich sehr gefreut, einen USB4/Thunderbolt Anschluss vorzufinden. So könnte ich dann auch die Geschwindigkeit meiner, wirklich sehr schnellen, externen SSD voll ausschöpfen, ohne immer hinten rumfummeln zu müssen; wäre IMHO zukunftsweisender gewesen.
Momentan würde es für mich aber auch in die engere Auswahl fallen.
Alexander Brose
839 Kommentare 607 Likes
Danke für das Feedback und die rege Beteiligung!
Ich werden mal zusehen, dass ich zeitnah einen Low-Profile CPU-Kühler organisiert bekomme und nochmal ein kleines Follow-Up mit Luftkühlung nachreiche (y)
Grüße!
S
S.nase
1,523 Kommentare 525 Likes
@Alexander Brose
In der Anleitung wird ja auch noch eine Alternative beim Verlegen der NT Kabel zum Mainboard beschrieben. Warum hast du die NT-Kabel nicht so um das NT verlegt, und stattdessen um die Speichermodule "geschlungen"?
ipat66
1,498 Kommentare 1,555 Likes
Weil das Review von Alexander ist .... :)
Vielleicht kann er was dazu schreiben ?
Übrigens ... Vielen Dank Alex für die Vorstellung dieses schönen Gehäuses :)
S
S.nase
Hab es korrigiert...Danke für den Hinweis
DrDre
305 Kommentare 158 Likes
Weil er wie jeder richtige Handwerker, keine Anleitung braucht 😂 😂
Antwort 4 Likes
ssj3rd
239 Kommentare 168 Likes
Und es dann "erstmal" provisorisch (also für die Ewigkeit!) befestigt/aufbaut? :ROFLMAO:
Antwort 5 Likes
Alexander Brose
