Cooling Fans Latest news Practice
Case Fan Testing 2.0 – Improved Pressure Measurement and new Metrics for even better Reviews
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
We have taken the feedback of the readers, evaluated it and improved it again together with an aerodynamicist. Afterwards, everything was recalibrated and the evaluation was extended by new chart graphics, which now finally cover the entire speed band. But more on that in a moment. Of course we noticed that our new measurements were taken up and copied by some competitors, however, politeness forbids to list names and also recognized errors here. Instead, one should always strive to simply do even better oneself and accept the challenge, because the imitators also show that we were the first to discover a real gap in demand!
We have only changed the measurement of the airflow and the sound pressure level in the chamber in small details, because they are still accurate enough to stand up well in professional counter tests. On the other hand, we have been able to improve the accuracy of static pressure, especially at lower pressures. Thanks to newly designed and self-printed funnels with special seals, it is now possible to work even better.
Improved measurement setup
Since my former employer is also one of those who now try to copy us, the angles in the 3D graphics and also in the following two photos are of course not quite right, because without knowing the exact dimensions of the funnel, a copy is virtually pointless and it also works only in a quite small tolerance range really quite accurate. We have also made comparative measurement series for this once again. In practice, the whole thing looks like the two pictures below.
The installation is trouble-free and the pressure receptacle now also closes perfectly thanks to a special seal. The rest is just a matter of calibration, which we also did again. It’s unlikely to get much more accurate with semi-professional methods. However, especially in printing, mistakes are quickly possible, which above all are not immediately recognizable. Even if the deviations are small, we will still measure all previous fans again and prepare them for the database.
New metrics and graphics
Apart from the fact that we now also record the minimum and maximum values for the flowing currents and the power consumption, we have fulfilled two further wishes of the readers and extended the measurement series in this respect. In order to be able to assess the fans really objectively, we first graduated the resulting volume flow and measured the sound pressure level in many individual steps. Fas result for a fan then looks like this in comparison to the reference fan:
We see that the increase in the sound pressure level of our test fan is not as even compared to the reference, but the level is still lower at a comparable volume flow. In addition, the fan tested and compared here also delivers a significantly higher airflow due to a 50% higher maximum speed, which in the end is bought with a similar sound pressure level as the reference fan, but whose performance is significantly lower.
And because we just wrote about the rotational speeds, there are also new comparative graphics for this, at the express request of the reader, by showing which rotational speeds are necessary to achieve a certain volume flow. In practice, we can now also see where the dip in the upper graph comes from in terms of volume, because there is a speed range (rather a smaller window) where the fan doesn’t perform so perfectly and spins higher to reach the desired CFM than a more even rise in the curve would have led us to expect.
In tomorrow’s fan test, we will include all these changes in an article for the first time, and our thanks go once again to the community for all the suggestions, the expert advisor for his competent help, and our Pascal, on whom the work will stick in the end. But we’re happy to do it all for our readers. 🙂
ipat66
1,452 Kommentare 1,484 Likes
Super !
Das Gute wird noch besser...:)
Diese Seiten sind einfach mit das Beste,was man (weltweit)finden kann.
Danke Igor,und danke an das Team !
Ihr macht einfach Laune!!!
Antwort 8 Likes
Pascal TM-Custom
1,122 Kommentare 1,362 Likes
RedF
4,966 Kommentare 2,812 Likes
Wow, da habt ihr echt noch einen draufgelegt.
Pascal TM-Custom
Na klar müssen uns ja abheben vom Rest :D
Antwort 4 Likes
LEIV
1,559 Kommentare 649 Likes
Freu mich da auch sehr drauf.
Will gar nicht wissen, wie viel Aufwand ihr da betreibt 😅
B
Besterino
6,990 Kommentare 3,564 Likes
Für die Wunschliste: nötige Drehzahl/Spannung etc. angeben, um auf 200LFM (linear feet per minute) zu kommen - das ist so ein gängiger Wert im Umfeld von Enterprise-Hardware.
Pascal TM-Custom
Wir haben schon in der Glaskugel gesehen das so ein Wunsch kommt :D Abwarten wir sind noch net am Ende
B
Besterino
Na das sieht doch schon vielversprechend aus! Für Doofe wie mich gerne wirklich die jeweiligen Werte für Verbrauch, Drehzahl und Lautstärke bei einem konstanten Airflow X - das ist für mich zumindest am aussagekräftigsten bei der Vergleichbarkeit der "Leistung".
Pascal TM-Custom
wäre das alles nicht so ein extremer Aufwand würden wir gerne jede kleine Lücke schließen das mit der Abstufung ist eine Nummer für sich die ich nur Abends machen kann. Die dBa Messanlage ist so feinfühlig das ein Auto das vorbeifährt sich anhört wie ein Panzer.
Wir betreiben natürlich gerne diesen Aufwand und wollen uns abheben zum Rest. Deswegen hab ich das auch mit der Leistungsaufnahme noch mit reingepackt. Dauert nur bissel bis wir alles nach und nach drin haben. Klein wenig Geduld noch :) dann haben wir alles drin.
Antwort 5 Likes
Pascal TM-Custom
einen Großen 🤣 der sich aber Lohnt Thema Lüfter wurde am Anfang Unterschätzt wobei es sehr komplex ist und sich viele nur durch RGB blenden lassen und sich unter umständen das Falsche kaufen.
Wir räumen jetzt auf und ihr bekommt harte Zahlen und Fakten.
Antwort 7 Likes
M
Multiknife
7 Kommentare 2 Likes
ich bin schon gespannt auf euren Test des neuen Phanteks T30!
Pascal TM-Custom
kommt vielleicht schneller als man denken kann ;)
g
goch
499 Kommentare 182 Likes
Mir gefällt diese vornehme Bescheidenheit. Frei nach Oscar Wilde, kann man mindestens die Annahme zu Grunde legen, das Nachahmung die höchste Form der Anerkennung ist - und Ihr euch diese mit den Lüftertests mehr als verdient habt!
Klasse, macht weiter so!
v
vonXanten
820 Kommentare 351 Likes
Bin schon gespannt auf den heutigen Test :cool:
Ihr schreibt zum Glück nicht nur die Werte der Hersteller ab, sondern fühlt den Mustern auf den Zahn. Ist bisher einzigartig! Und das wichtigste, es wird nichts beschönigt. (Was sicher nicht jedem Hersteller gefällt)
Weiter so!
C
Caposo
58 Kommentare 5 Likes
Richtig gut, vielen Dank!
Das "Volumetric Aitflow vs sound pressure level"-Diagramm war genau das, was mir noch gefehlt hat. Der einfache Quotient von früher war leider nicht wirklich sinnvoll, weil der Wert einer linearen Skala (Volumenstrom) durch den einer logarithmischen Skala (Schalldruckpegel) geteilt wurde. Da gewinnt tendenziell einfach der Lüfter, der am stärksten pustet...
So hat das jetzt richtig Aussagekraft. :)(y) Vielen Dank für die ganze Mühe!
ro///M3o
365 Kommentare 252 Likes
Mega! Danke für die Mühen. Eins meiner Lieblingsthemen hier. Nicht weil ich lüfterfetischist bin, sondern weil ihr das sehr gut, anders (vor allem richtig) und interessant macht 😁
c
creeeech
14 Kommentare 2 Likes
ich fände einen Test von einem Airflow-Lüfter interessant, zB dem Noctua NF-S12A und ob das als Gehäuselüfter Vorteile bringt
S
Sternengucker80
227 Kommentare 64 Likes
Wow, ich bin schwer begeistert, was ihr für einen Aufwand für eure Tests betreibt. So ins Detail, geht sonst keiner. Respekt, macht weiter so 👍👌
Guest
lol
tomshardware? 😆 😅
Follow Igor:
