CPU Latest news
Extreme load peaks measured for AMDs Ryzen 7000 CPUs – also in idle!
Meanwhile, some (few) users reported serious problems with the new AMD Ryzen 7000 processors, which had led to destroyed CPUs and motherboards. My friend Aris discovered, actually rather by accident, an interesting thing, which he had measured with his Powenetics v2, a shunt-based measurement setup and also logged. I don’t want to withhold this from you, because I already made high-resolution measurements with my oscillographs at the time of the Intel Core i9-12900K, where so-called transients occurred that looked similar. However, not to this extreme as now with the new Ryzen CPUs.
Aris has already reviewed several CPUs like the AMD Ryzen 7 7800X3D, AMD Ryzen 9 7950X3D, AMD Ryzen 9 7900X, AMD Ryzen 9 7900 and the AMD Ryzen 5 7600X. Therefore I recommend you to read the Original article on his hwbusters.com homepage with all tested CPUs because I only picked the Ryzen 9 7950X as an example for this news, for which I also have measured values from my own practice. And yes, you can only be amazed. Apart from that: Aris’ homepage is a treasure trove for technical details, especially the power supply tests. You should definitely bookmark it, even if articles by him appear or are mentioned here from time to time.
As it seems, we were both lucky that we didn’t have any problems with burned processors and/or motherboards due to excessive power consumption during our intensive measurements and tests. This was not the case with some users on Reddit, notably Speedrookie, who destroyed his motherboard and CPU. This user also stated at the time that he did not overclock his 7800X3D CPU, but only used the EXPO 1 profile for the RAM. He also hadn’t noticed any temperature or performance issues and his system was running 24/7 (i.e. all the time).
He left the system idle and when he went to use it again, he noticed that the system could no longer post and had a QCode of 00. The AIO cooling he was using was hot, too hot as he described, showing that it was getting tremendous load from the CPU, which is odd considering the system was idle. His mention of leaving the system idle for a while and then finding that his processor was burned up then led Aris to look more closely at the idle log data he got from his Powenetics v2 and subsequently test some more load scenarios and other processors.
Ryzen 9 7950X3D
State Power Consumption
Idle Peak (PBO/CO-15) 130.04 W (124.73 W)
Idle AVG (PBO/CO-15) 50.531 W (45.952 W)
Blender Peak 189.586 W
Prime95 (small FFTs) Peak 170.352 W
There is a high peak of up to 130W during idle with the Ryzen 9 7950X3D, which is actually unjustified since the highest CPU load is only 3.53%. Even with curve optimization enabled and a setting of -15, the idle peak remains at 125W, so something is happening here that shouldn’t be happening like this. Aris tested all the CPUs on three motherboards from Asus, MSI and Gigabyte. More details about the test systems can be found in the corresponding tests from Aris on their homepage, which I can only recommend.
Aris and I are of the opinion that these load peaks (which I could reproduce 1:1 in the meantime, by the way), primarily have nothing to do with the described CPU dying – we put a lot of emphasis on that to avoid a false panic. But on the other hand, such transients are nothing you need for a really stable system. Aris has also already spoken to some of his industry contacts, who have told him that the overall RMA rates of the 7000 series are actually lower than those of the 5000 series. This should avoid panic and also not discourage anyone from buying a new AMD CPU.
Pin analysis of the destroyed Ryzen 7800X3D – All burned pins supply the VDDCR (CPU Core Power Supply)
Source: hwbusters.com
1,698 Kommentare 1,031 Likes
Um das Mal so ganz naiv anzugehen: gibt's da irgendwelche transiente (oder, in den extremen Fällen mit den verbrutzelten CPUs, nicht ganz so transiente) Kurzschlüsse in den jeweiligen CPUs, bzw auch schon zwischen den Kontakten am oder im Sockel? Denn sonst machen weder über 100 W im Idle (hier), noch die deutlich über 200 °C bei den zu Schmorbraten verbackenen CPUs irgendwo Sinn. Um bei unter 2 V trotzdem derartige Hitze zu erzeugen, muß da schon ganz schön viel Strom fließen, und das ganze sieht mir einfach sehr nach Kurzschluss aus. Aber wie gesagt, vielleicht bin ich einfach zu naiv, oder hab zu wenig Fantasie.
Ich hatte ja reproduzierbar den S3-Fehler, also ein Wake-up, nachdem kein Kühler mehr lief. Wenn der Reddit-User den PC verlassen hat, der in den Ruhemodus ging und dann erwacht ist, weil irgendeine Erschütterung die Maus hat tanzen lassen und mit Zero in den Temps eine Überhitzung stattfand...
Ich habe es ja am Trottling und anschließenden kompletten Einfrieren gemerkt und den PC dann manuell sofort vom Netz getrennt. Stelt sich die Frage, was passiert wäre, hätte ich das nicht getan. Ich habe mittlerweile die komplette Hibernation deaktiviert und sogar das File gelöscht. Alle Lüfter haben jetzt eine Mindestdrehzahl - adé semi-passiver Silent-PC :(
RedF
4,888 Kommentare 2,717 Likes
Da lobe ich mir eine Wassertemperatur gesteuerte Kühlung.
Die dir da aucht nichts hilft :)
RedF
Na dann kannst die lüfter ja auch aus lassen.
Casi030
11,923 Kommentare 2,339 Likes
Warum funktionieren nach den S3 die Pumpe,dessen Temperatur und die Lüfter die daran angeschlossen sind dann auch nicht mehr?
grimm
3,194 Kommentare 2,127 Likes
Und wie ist das mit optimierten CPUs, bei denen PPT & Co. begrenzt wurden? Die SoC-Spannung ist dann auch entsprechend niedriger. Oder wird das vom EXPO einfach überschrieben?
Shakj
18 Kommentare 19 Likes
Ich hatte das Video gestern gesehen und jetzt seinen und den Artikel hier gelesen. Was heißt Idle im Windows? Die referenzierten 3% macht auch der Suchindex, wenn der random losläuft. Ich weiß dass, weil ich ihn argwöhnisch beobachtete. :D Der wachen alle Kerne mal kurz auf und dann arbeitet einer, wie auf der Baustelle. Dass die Ryzens, da auf einen Boostkern erstaunlich viel Last geben Stock, als wenn man es auf 16 Kerne verteilen würde, ist ja jetzt auch keine Neuigkeit. Oder welche Erkenntnis entgeht mir hier gerade?
Meinen 7950x hatte ich am Anfang Stock laufen, dann Eco-Modus 142, was dazu geführt hat, dass das Ding kühler im Cinebench war als im "Idle", wenn der Suchindex gerade was gemacht hat.
LastSPITZEN im ms-Bereich macht kein Indizierer. Hier geht es um echte Spikes und die 3% sind Average. Das ist wie bei den Grafikkarten. Unter Volllast ist es ja das gleiche, einfach mal die Werte in den News genießen. Ich sage nur ATX 3.0. Mit dem Scope komme ich im Microsekundenbereich sogar bis auf über 200 Watt in Blender. Mit dem 7950X3D!
ssj3rd
225 Kommentare 156 Likes
Ein paar User hatten halt paar Montags CPU‘s, so what?
Shakj
@Igor Wallossek Aber dann schreib das doch etwas für uns Normalsterbliche. Mit dem Hinweis habe ich jetzt gesehen, dass Aris im Artikel schreibt, dass er da 1000+ Messungen die Sekunde macht, also ist das Intervall 1ms und weniger, richtig? Und im Screenshot ist "Max" angeklickt, also der maximale Wert von Zeitraum X über eine max 1ms, eher Mikrosekunden. Ist das jetzt neu bei den 7000er Ryzens oder besonders "unfein", dass da CPUs bei einer angelegten Last erst wieder ins Target eingefangen werden müssen? Also das, was Nvidia z.B. zwischen 3000 und 4000 gemacht hat, dass da die Lastspitzen nicht so ausfällig werden.
Weil so überbordend viel sieht das ja nicht aus, gehen ja keine 300 Watt durch, 200 Watt bei einer 162 Watt PPT CPU bei Blenderstart. Agieren andere CPUs da nicht auch so, dass die für den kurzen Bereich mal über das Powertarget gehen und dann wieder eingefangen werden? Das ist nicht böse gemeint, ich möchte nur das Problem verstehen. ;)
Antwort 5 Likes
E
Eribaeri
129 Kommentare 49 Likes
Das Problem liegt auf der Hand. Voltage-Spikes.
RedF
Also der Hybernate friert die Tempüberwachung ein, die Spikes werden nicht mehr gedrosselt und das Substrat wirft Beulen?
Das Expo setzt die Spannungen an die grenzen was das ganze noch anfälliger macht.
Not_A_Nerd
49 Kommentare 45 Likes
Den S3 Temp 0 Bug gibt zum Beispiel MSi bei einem ihrer letzten Bios Updates für AM5 an in den Releasenote, als behoben. Bios Versionen vom 14.4 war das vermerkt.
RedF
Passt auch zur aussage von ASUS das beim neusten BIOS an der Temp überwachung gedreht wurde.
C
Coppy
5 Kommentare 1 Likes
Kollege hat ein Asrock X670E Pro RS Board und den 7700X im System. Reicht es aus den Hybernate zu deaktivieren und das Expo deaktiviert zu lassen bis ein BIOS Update zur Verfügung steht der das ganze fixt? Oder kann es auch ohne EXPO auftreten? Grüße
QBiT
6 Kommentare 0 Likes
Hab ein 7950X3D und ein AsusX670E Crosshair Gene Board, in Verbindung mit den G. Skill Trident Z 6400, läuft bisher am Anfang auf dem Expo Profil und ohne Probleme, vcore ist auf 1.40.. Gekühlt wird das ganze von einem Watercool HEATKILLER und einem Mora.. Temps sind bisher unauffällig, im idle sowie unter Nutzung immer um die 40 Grad...
Ps: Bios ist das aktuelle stable 1202... Das Beta BIOS läuft bei mir nicht... Kommt immer F4 als Q-Code...
N
Nasneuliing
21 Kommentare 1 Likes
Also ich muss sagen, das ich schon ob der ganzen Berichterstattung extremst verunsichert bin.
Ich verwende ja selbst ein Ryzen 5 3600x derzeit, wollte eigentlich irgendwann mal die Plattform wechseln und dachte mir, bleib doch bei AMD.
Aber wenn ich lese, das Prozessoren hochgehen sich wölben und auch das Mainboard in Mitleidenschaft gezogen wird, überlege ich gerade entweder beim AM4 zu bleiben und da die CPU aufzurüsten, was aber in meinen Augen wenig Sinn macht, weil AM4 de fakto tot ist.
Ich bin aber auch kein Hardcore User der sich so super gut mit modernen CPUs auskennt.
Inital habe ich mir gedacht, da kann ich mir als Gelegenheitszocker mit meiner 1080 Ti auch mal ein Intelsystem aufbauen.
Mein Traumboard hätte ich schon sogar. Ein Asrock Z790 Steel Legend Wifi, weil es fünf nmve's unterbringen kann.
C
ChaosKopp
573 Kommentare 608 Likes
Mal ganz naiv gefragt: Hast Du denn Aufrüstdruck aktuell?
Momentan dürften AMD und die Boardpartner auf Hochtouren rotieren, weil es sonst teuer wird.
Warte mal ne Woche, denke man wird dann mehr wissen.
Follow Igor:
