CPU Motherboard Reviews
Extensive workstation and AI test with Intel’s i9-13900K – The power profiles Baseline, Performance, Extreme and Insane from reasonable to pointless in practice
After we published Aris’ article about the power consumption of the Core i9-13900K in Cinebench 23 on Monday, I’m following up today with a larger program scope. And yes, I’m deliberately using a Z690 board because I also used it for the launch of Raptor Lake S and the subsequent refresh. That makes the comparison much easier. And as I already teased on Sunday: Intel’s half-hearted revelation with the new profiles for the Z790 boards also pissed me off a bit. When I explicitly asked an employee responsible for motherboards at a major Taiwanese manufacturer, all I got was a bored As of now, we only have “Intel Default Settings” for some Z790 models. When I asked why the whole thing was still dragging on, the answer was a terse Intel doesn’t have an official information about the root cause yet. Aha, no cause, no updates. So the rest is just cosmetic. Well…
Lately, people have been writing about Intel’s possible degradation problems with the high-end CPUs of the 13th and 14th generation and I’m sick and tired of all these discussions. Since I’m not interested in the rather useless gaming crown anyway, because I play almost exclusively in Ultra HD, where the CPU is of secondary importance, I’ve chosen the area where the mainstream doesn’t test: the workstation and AI area. And because some tests run for a very, very long time and involve a lot of load changes, stability is all the more important here. I also very reluctantly remember the Core i7-14700K from the launch article, which didn’t even run stably without overpowering. That was practically degradation out of the box. I have no idea where the part ended up after I returned it.
Performance profiles
I’m going to be mean today and test two profiles that Intel no longer wants to see. So there are now four. The so-called Baseline profile with 188 watts, which was still the standard in the first slides before the Raptor Lake launch, the so-called Performance profile (now “Intel Recommended”), the Extreme profile for the heating technicians among us and the completely stupid “Insane” profile of the motherboard suppliers with the no less insane 4096 watts as a placeholder for the infinite expanses of overclocking space.
And I can already spoil the fact that only two profiles are actually suitable for practical use. The move that Intel would now prefer to hide the baseline profile as “n/a” is probably also due to the fact that not every older Core i9-13900K still runs stably with it after all the energetic kicks in recent months. I deliberately didn’t use Intel’s Golden Sample for today’s test, but rather my own purchased retail model, whose average clock rates were somewhat lower in practice.
Intel Core i9-13900K (14900K) Baseline Performance Extreme “Insane”
Base performance of the processor 125 125 125 125
PL1 125 125 253 4096
PL2 188 253 253 4096
Iccmax 249 307 400 512
Intel therefore recommends implementing the highest power supply profile that is compatible with each individual motherboard design, not entirely without ulterior motives. What a nonsense, because I still pay for my electricity. As you’ll see from my test results, the baseline profile does affect performance from time to time, but I wouldn’t call it unusable. As long as the CPU runs stably with it, it’s a real alternative. Just not for blind marketing. I took the remaining settings from Intel’s slide, unless they were already set by default. And since the Z690 Unify used was not doped with pointless settings, customers should still be on the safe side in many respects. Things like CEP and eTVB limit are of course set as Intel would like them to be.
Test system and methodology
Let’s take a brief look at the test system, which offers no secrets. The power consumption measurement is carried out as usual using a high-resolution oscilloscope and the measuring clamps, but this time deliberately on the 8-pin EPS. I use this to measure BEFORE the voltage converters, whose maximum losses of 8 percent we still have to include here. However, I do this deliberately in order to remain comparable with Aris and also to record the actual load on the power supply unit.
Environment/laboratory Ambient temperature: 22°C ±1°C
Motherboard MSI MEG Z690 Unify
CPU Intel Coire i9-13900K
GPU KFA2 GeForce RTX 4090 SG
NVMe MSI Spatium M580 FrozR 4 TB
MEMORY TForce DDR5 6000
Power supply Be Quiet! Dark Power Pro 13
CPU cooler Be Quiet! Pure Loop 360 (Fan Speed max.)
Case Bykski Benchtable
Although I used a powerful cooling solution to test how high the Intel CPU can run when all restrictions are lifted, I deliberately refrained from using a custom loop solution with the IKA lab chiller for reasons of practical relevance. This should also cover over 90% of configurations. I have also dispensed with air cooling for the energetic Nimmersatt, as I don’t want to organize a BBQ.
128 Antworten
echolot
1,118 Kommentare 875 Likes
Mal unabhängig von dem Wattwahnsinn. Was empfiehlt man da für ein Netzteil bei einer mittelprächtigen GPU ala RTX 4070 Ti oder RTX 7900 XT? Oder gar einer RTX 4090 am Limit?
H
HabeLeiderKeinLabor
150 Kommentare 129 Likes
Wir hatten bis anhin häufiger Abstürze in Twinmotion auf unseren 13900K und seltener auch auf unseren 13700K. Sind an die 20 Computer.
Nach dem BIOS Update von Asus welches laut changelog "The update introduces the Intel Baseline Profile option" einführt, dachte ich diese Intel Baseline wäre nun der Default. Das ist aber nicht so!
Das Wort "Intel Baseline" kommt im ganzen BIOS nicht einmal vor. Auch ASUS Multicore enhancement ist per default auf Auto.
Nachdem wir nun Asus Multicore auf
"Disabled, enforce all limits"
und SVID auf
"Intel failsafe"
umgeschaltet haben, sind die Abstürze verschwunden.
Danke für die Benchmarks, die meine Gefühl bestätigen:
Ein echte Leistungseinbusse ist (für unseren workload) nicht vorhanden.
B
Besterino
6,906 Kommentare 3,474 Likes
Danke. Muss ich also doch nochmal ins BIOS krabbeln und an den Settings fummeln. Mist.
Rechne alle Wattfresser zusammen und multipliziere mit 1.5, um völlig sicher zu sein oder nimm gleich ATX 3.x
Lohnt sich aber sicher.
1,698 Kommentare 1,031 Likes
Also verhält sich RL genau wie erwartet - vernünftig eingestellt laufen die gut und nicht hart am Rand der Kernschmelze. Danke an @Igor Wallossek für das Testen aller 4 Profile in den Anwendungen, denn jetzt kann man's ja nachlesen. Daß "insane setting" dann genau das ist (verrückt) überrascht zwar nicht, aber wie weit die Unvernunft hier ging bzw geht ist schon beeindruckend (und deprimierend).
LurkingInShadows
1,386 Kommentare 584 Likes
kannte ich nur als qed
Es geht auch Deutsch statt Latein. Unser Mathelehrer legte da sehr großen Wert drauf. :D
P
Pokerclock
486 Kommentare 420 Likes
Ich bin mittlerweile ganz froh darum die ganzen i9er bei mir in den Mietsystemen immer mit 307A ICCmax und PL1/PL2 253 Watt eingetellt zu haben. Da hätte ich ja mal überhaupt keine Lust dazu, die (zurecht) angenervten Reklamationen meiner Kunden entgegennehmen zu müssen, weil die CPUs ihren langsamen Tod sterben. Vor allem würde man daran überhaupt gar nicht denken und andere Komponenten vermuten.
Ändern werde ich daran auch nichts, denn unterschiedliche PL1/PL2 sagen mir im Sinne einer konsistenten und damit nachvollziehbaren Leistung mehr zu. Gibt nichts Schlimmeres als verwirrte Kunden, die sich Fragen, warum der PC nach 56 Sekunden immer langsamer wird...
Man sieht auch ganz schön, dass lang andauernde Volllastszenarien mit gängigen Kühlmethoden überhaupt gar nicht möglich sind.
Lieblingsbesuch
463 Kommentare 86 Likes
Danke für den Test aber warum wurde keine Spiele getestet?
R
RazielNoir
439 Kommentare 202 Likes
Das ist ja das Ergebnis dessen, was befeuert von den ganzen OC-Gedöns der letzten Jahre im DIY-Bereich gefeiert wurde. Der Review wurde fast nie mit dem Baselineprofil (wie es jetzt heißt) gemacht. Und die meisten haben immer die -K oder KF/KS Prozessoren getetstet.
Eine Server- oder Workstation-CPU wird nicht getunt, läuft also quasi immer mit den Spezifikationen des Herstellers.
Weil Stabilität und Zuverlässigkeit der Ergebnisse wichtiger als das letzte Promille Mehrleistung.
Das zeigt m.M.n. der schon etwas älter Test des Xeon w9-3495X auf HWLuxx
Daher ist mir ein nativer 10 Kerner nur mit P-Cores bei stabilen 3,7Ghz und 125w Dauerlast lieber als diese Chimären-Cpu's ab Alder Lake.
RX480
1,887 Kommentare 879 Likes
richtig dolle guuut, das Du zeigen konntest, das "Performance" nur 1% ineffizienter als "Baseline" arbeitet (x)
Das werden schon genügend Andere zeigen.
(x) wird in Games nicht groß anders sein
LurkingInShadows
Artikel lesen hilft:
LurkingInShadows
Meine meinte immer "Mathematiker sind faule Leute, drum suchen sie immer Abkürzungen, zB Multiplikation statt Kettenaddition" :)
HerrRossi
6,821 Kommentare 2,256 Likes
Intel wollte halt mit allen Mitteln die Gamingkrone holen, bei den min fps hat das ja auch manchmal funktioniert, der Preis ist halt der hohe Stromverbrauch und, wenn man Pech hat, eine kaputte CPU.
Lieblingsbesuch
Mit dem Insane Profil wird man die Gamingkrone bestimmt behalten können ....
... und gleich noch einschmelzen. :D
Lieblingsbesuch
Aber auch das Insane Profil ist inoffiziell von Intel frei freigeben oder nicht?
Wenn es stabil bei Spielen eingesetzt werden kann, warum nicht damit auch testen ...
Follow Igor:
