Audio Audio/Peripherals Headphones Headsets Practice Reviews Sound Systems Soundcards
“Equalizer APO” and “Peace Equalizer” – Perfect adjustment of headphones or loudspeakers using a real parametric equalizer | Tutorial
Today I’m going to introduce you to an equalizer software that no PC should be without if you seriously want to enjoy music on your PC or play games in style. Forget all the sliders on Realtek or Nahimic drivers or the software that often comes with gaming headsets. With 5 to 7 controls, fixed frequency settings and opaque filters of the simple graphic equalizers, you won’t win a flower pot. The “Equalizer APO”, a parametric equalizer software for Windows 10 and Windows 11, is better.
The “Peace Equalizer” based on this is a graphical extension for this software. This combination allows users to fine-tune freely selectable bass, mid or treble frequencies of the sound from headphones or loudspeakers to eliminate unwanted peaks or weakening frequency ranges and to emphasize or adjust the important frequencies for an immersive sound experience.
Another outstanding feature of Peace is the integration of AutoEQ, a collection of equalizer profiles for different headphone models that enables personalized sound adjustment. Users can choose from a variety of profiles and apply them as they wish or download and integrate them themselves from various sources. In the future, I will probably also make suggestions for profiles in the most important tests, because it’s the obvious thing to do. Peace also supports importing profiles from text files (and vice versa), which further increases the customization options.
Download and installation
The installation of Peace Equalizer and Equalizer APO requires a few steps and prerequisites. Peace Equalizer and Equalizer APO are designed for current Windows operating systems and are (as of today) compatible with Windows 10 and Windows 11. It is necessary to have administrator rights on the computer for the installation, as changes are made to the audio system. In addition, functioning audio hardware (sound card, integrated audio chipsets, etc.) is required, which is usually the case. An Internet connection is of course required to download the installation files and any necessary updates, but we know that.
First, Equalizer APO, the basic software for Peace, must be downloaded and installed. During the intuitive installation process, you will be asked to select an audio device for which you want to configure Equalizer APO. During the installation of Equalizer APO, the option “Install as SFX/EFX” should be selected. This is the default option for Windows 10 and Windows 11. The download button below will take you to SourceForge in a new window/tab, where you will find the latest version of this freeware:
after installing Equalizer APO, you will usually need to restart your computer. This step is necessary because Peace Equalizer tests the correct installation of EQ APO before setup and only then can the setup be continued. Once the computer has been restarted, Peace Equalizer can be downloaded and installed.
After installing Peace, you should check the settings and adjust them to your needs (and level of knowledge). This includes access to the Equalizer APO configurator via the “Debugging and Testing” tab in Peace, which should be particularly useful in case of problems after Windows updates. Within the Peace user interface, AutoEQ can also be used to load and apply specific equalizer profiles for different headphone models. But I’ll come to that in a moment.
These initial steps and requirements are of course only a basic guide and it is important to pay attention to any specific instructions or options during the installation process to ensure correct setup and function. This is because versions can change and some menus or queries may look different. Regardless of this, I am also happy to provide Peter’s videos:
115 Antworten
1,698 Kommentare 1,031 Likes
Danke, sehr interessant! Die Software werde ich auf jeden Fall einmal ausprobieren! Verstehe ich das richtig, damit kann man den rechten und linken Audiokanal jeweils auch richtig separat abmischen? Das wäre wirklich toll, da mein rechtes und linkes Ohr deutlich unterschiedlich gut tiefe und mittelhohe Töne wahrnehmen, (Spätfolgen einer ziemlich schweren Mittelohrentzündung in meiner Kindheit), und normale Equalizer mir dafür nicht viel bringen.
ipat66
1,422 Kommentare 1,436 Likes
Beste PC Equalizer-Software ever :)
Sollte bei keinem audiophilen PC Enthusiasten fehlen.
Einfach ein geniales Tool !
ufopizza
1 Kommentare 0 Likes
Ich nutze die Kombi auch schon seit Jahren. Wirklich tolle Software. Danke für den Test!
Ja, das kannst Du sogar für JEDEN Kanal einzeln, egal ob Stereo oder Surround :)
RaptorTP
327 Kommentare 158 Likes
OMG, ich hab noch so viel nachzuholen xD ...
Vielen vielen Dank - werde ich durchlesen & testen.
Was ich auch schon Jahre vor hatte und bis heute nicht gemacht habe - Lautsprecher des Heimkinos zu vermessen und zu konfigurieren.
Das Wohnzimmer ist jetzt umgezogen und dieses Jahr (ist ja noch jung) möchte ich das endlich mal angehen ! Da ist aber noch völlig offen mit was und wie.
m
maikrosoft
105 Kommentare 26 Likes
Entweder hab ichs überlesen oder es wurde im Artikel nicht erwähnt.
Angenommen ich habe Kopfhörer und Lautsprecher, wie und wo stelle ich da für jedes Gerät ein eigenes Klangbild ein und gibt es die Möglichkeit, wie im Easyeffects unter Linux, dass die Profile beim Wechsel des Audiogerätes automatisch wechseln?
RedF
4,888 Kommentare 2,717 Likes
Sehr Cool das Tut : )
Gregor Kacknoob
536 Kommentare 449 Likes
Jep, das Tool kann ich auch nur wärmstens empfehlen :)
Schau Dir die Oberfläche noch einmal genau an :)
Bei "Lautsprechekombinationen" kannst Du die Ausgabeart wählen und untendrunter das jeweilige Gerät. Abspeichern und fertig. Einen automatischen Wechsel habe ich eigentlich nie vermisst, weil ich das Teil nur für die KH nehme.
P
ParrotHH
178 Kommentare 191 Likes
Ja, die Option der Automatisierung gibt es, und das nutze ich auch recht intensiv, weil ich immer mal wieder die Kopfhörer am PC wechsele. Dafür gibt es im Hauptfenster "das kleine grüne Männchen":
Damit öffnest Du ein Fenster, mit dem Du steuern kannst, welche Aktionen wann ausgeführt werden.
Über den Reiter "Activate at device selection" kannst Du genau das erreichen: wird ein Gerät erkannt, wird ein Profil geladen.
Man kann dann dem ganzen auch noch eine Farbe des TRay-Icons zuweisen, so dass man erkennen kann, ob und welches Profil gerade aktiv ist.
Antwort 7 Likes
Inzingor
198 Kommentare 120 Likes
Für Linux Nutzer:
Megaone
1,833 Kommentare 1,726 Likes
Unter
gibt es Voreinstellungen für eine ganze Reihe Kopfhörer. Die Einstellungen entsprechen der Harman Kurve.
Ich nutze die Einstellungen mit einem Beyer 990pro und 2 preiswerten Hifimännern von Massdrop dem HE4X und dem HE4XX. Danach hab ich eine ganze Reihe von sehr teuren Kopfhörern verkauft, weil es wirklich klanglich keinen Sinn ergab. Der Beyer wird dadurch klanglich zum Überflieger. Die Hifimänner machen für mich nach der Anpassung die deutlich teureren ziemlich obsolet.
Vorausgesetzt natürlich man hat einen brauchbaren KHV!
k
kermit_nc
51 Kommentare 19 Likes
Sehr schöner Artikel zum Thema Audio-Equipment.
In der Abbildung „Parametric Equalizer Overview“, auf Seite 2 sind die Farben in der Legende für „High Boost“ und „Mid Cut“ vertauscht.
Auf Seite 4 muss ich der Aussage widersprechen, das Linkwitz-Riley (LR) Filter sich aus Butterworth (BW) Filtern zusammen setzt, denn diese sind vom Konzept her verschieden und es gibt auch LR12 mit 12dB/Oct. Der Unterschied ist, dass sich BW im Durchlass-Bereich sehr Phasenstabil verhalten aber ihre Probleme im Übergangsbereich haben und daher einen Kompromiss darstellen. Da die Grenzfrequenz -3dB entspricht, entsteht ein 3dB Buckel im Übernahmebereich, wenn auf „der anderen Seite“ die gleich Grenzfrequenz verwendet wurde. Da BW Filter sehr gutmütig sind, werden diese bei Lautsprechern gerne verwendet, da die Entwickler teilweise mit großen Toleranzen und parasitären Effekten bzw. frequenzabhängige Impedanzen zu kämpfen haben. Weiter wirkt sich die unsaubere Phase im Übergang nicht sehr stark aus, da die akustische Grenzfrequenz der Komponenten „mithilft“ z.B. Bei einem Hochpass-Filter eines Hochtöners ist die effektive Flankensteilheit deutlich höher.
Bei LR ist die Grenzfrequenz -6dB und der Buckel im Übernahmebereich entfällt. LR wird gerne in aktiven Systemen (OP, DSP) verwendet und oft in LR24 / LR48 mit LR12 (180° Phasendrehung) kaskadiert, wo sich bei LR24 (2x180) / LR48 (4x180) wieder Phasengleichheit herstellt. Das ist möglich, da der Phasenverlauf im Übergang linear verläuft, was bei BW Filtern nicht der Fall ist und sich daher nicht so gut kaskadieren lassen. Siehe auch LR24 aktiv Weiche
Nicht zu vernachlässigen ist, dass sie jeder Filter auf die Gruppenlaufzeit auswirkt, was sich aber nur bei sehr tiefen Frequenzen bemerkbar macht.
Weiter noch viel Erfolg im Jahr 2024 und viele Grüße
B
Byowa
12 Kommentare 9 Likes
Super Thema! Aber die Offenbarung erlebt man - meiner Erfahrung nach - erst mit einem kalibrierten Mikrofon (z.B. UMIK-1) und REW (Messsoftware). Habe das Spiel am PC nun mit mehreren unterschiedlichen Lautsprechern ausprobiert - die Resultate waren klasse. Die ~ 100 € für das kalibrierten Mikrofon kann man durchaus bei den Lautsprechern einsparen (vorausgesetzt natürlich, dass die Räumlichkeiten entsprechend negative Auswirkungen haben). Und es gibt einen regen Gebrauchtmarkt.
Grafik:
Seit heute früh längst getauscht. Muss noch im Cache klemmen...
Zum LR-Filter:
Sollte Wiki nicht stimmen, bitte dort ändern :)
Genau deshalb mag ich die aktiven Nuberts. Das automatische Einmessen per App funktioniert absolut klaglos, sogar in meinem L-förmigen Raum. Der hörbare Gewinn ist unbezahlbar. Wer sich vierstellig Lautsprecher kauft und die nicht einmisst, ist eh nicht zu retten :D
Antwort 4 Likes
MechUnit
70 Kommentare 40 Likes
Naja, mit dedizierter Soundkarte (deren EQ natürlich komplett aus) direkt am guten Denon-Verstärker oder Luxmann-Röhrenverstärker, dazu eingemessene (via Denon mit Auddyssey EQ) , gute (Studio-) Lautsprecher oder Kopfhörer (nicht so Gaming Headset Schrott) und der Klang ist perfekt, auch ohne EQ.
Gut, nicht jeder verfügt über derlei Hifi Equipment und natürlich kommt der Klang zunächst aus der Sounkarte (die natürlich onboard-Sound vorzuziehen ist). Aber bevor ich irgend etwas an einem EQ einstellen würde, sorge ich erst dafür, dass die klangliche Basis hardwareseitig für einen natürlichen, neutralen Sound gegeben ist.
Wenn dieser passt, benötigt man im Endeffekt keinen EQ mehr - insofern man mit dem Klang zufrieden ist.
Ein EQ wäre dann eher ein Notnagel, wenn es an der klanglichen Basis bzw. der Soundhardware fehlen würde. Z.B. mit billigen onboard-Sound. Ansonsten nur direkt in Musikprogrammen beim Abmischen.
Ich habe im Wohnzimmer an den nuLine 334 und dem 1200er nuSub einen sehr guten Denon AV (die grafische Oberfläche ist die Pest), eingemessen mit dem beiligenden Mikrofon. Jain. Das Gröbste ist weg, aber bestimmte Eigenheiten des Raums bekommt man mit den einfachen Regelmöglichkeiten einen grafisches EQ nicht ganz weg. Das mit den Moden geht aber ganz gut. Ich habe dann mit Messmikro und Laptop im Raum nach den Bösewichten gesucht und teilweise auch in den Massivschränken die Inhalte anders eingeräumt. Da helfen schon Servietten zwischen den Tellern oder Bücher von oben nach unten verlagern... :D
...mal abgesehen von den neuen, bodenlangen Vorhängen, die zwar unpraktisch, aber aktustisch so wertvoll sind. :D
ipat66
Meine Aussage bezieht sich auf das individuelle Einstellen eines KH.
Meine Hifi Anlage ist komplet „ flat“ ohne Nichts.....
Aber wie Igor schon sagte, kann das mit manchen räumlichen Begebenheiten
auch ein nützliches Tool sein...
Follow Igor:
