Today we take a look at the current top model of an AIO water cooling system from Enermax. As the title already hinted at, a few things here and there reminded me of a very popular product from a competitor. You can find out whether this is a productive inspiration or a disappointing copy in the following review.
Click here for the latest article on another AIO series from this manufacturer:
Enermax Aquafusion ADV 240 Black and 360 White in the test – Two are better than one!
An elaborately printed cardboard box in several colors protects the contents on the way to us and presents it classically on the front with a large product image.
On the reverse side we find the table with the specifications and an overview of the most important features.
If you open the lid and take a look inside, you’ll see another familiar picture. The contents, wrapped in bags, are protected from impact by a cardboard shell, and the radiator has even been given a second cover.
The accessories are quite extensive and, in addition to the various brackets for the supported sockets, also include an aRGB controller with buttons, clamps for the hoses and a tube of thermal paste. But that’s not all, a bottle filled with replacement coolant and a 24-pin ATX jumper are also included.
Assembly and installation
Depending on the socket, the appropriate bracket is pushed into the pump head. With the AM4 socket used here, the existing backplate of the mainboard is reused after the plastic holder on the front has been replaced with spacers from Enermax.
Finally, everything is screwed onto the short threads with four spring-loaded screws and can be put into operation after connecting the cables.
Specifications
As usual, here is an overview of the technical details, further information can be found on the manufacturer’s product page.
Enermax Liqmaxflo 360 ARGB (ELC-LMF360T-ARGB)
![]() | Abhol-/Versandbereit in 1-3 Werktagen | 99,28 €*Stand: 16.07.24 06:17 |
![]() | Lagernd im Versandlager - Lieferzeit 2-5 Werktage | 99,89 €*Stand: 15.07.24 23:50 |
![]() | Auf Lager | 99,90 €*Stand: 16.07.24 06:18 |
25 Antworten
