Audio/Peripherals Microphone Reviews
Endgame Gear XSTRM USB Microphone Review – Golden capsule or bitter pill?
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
With the XSTRM, Endgame Gear brings a modern condenser microphone to the market, which is primarily aimed at streamers. Through a mix of sophisticated technology and contemporary lighting elements (yes, that’s supposed to be all the rage now), gamers or streamers are supposed to be provided with studio-grade voice and lighting quality. Whether this succeeds and where marketing and reality (perhaps) drift apart a bit, you can read in the test.
Endgame Gear? Another one of those Chinese firecrackers? Not at all! The relatively young company was founded in Berlin and immediately gained a good reputation with its first product, the XM1 mouse. This initial success brought international reinforcements to the team and also secured various competencies to develop high-quality peripherals in other areas as well. Through various evolutionary stages of the XM1 and a newly developed high-end fabric for mouse pads, the company now sees itself in a position to gain a foothold in the audio sector. Of course, this is not 100% made in Germany, but at least engineered in Germany. It’s not possible to do it completely without an external workbench.
Unboxing
Before we take a closer look at the device, we first have to free it from the packaging, of course. The microphone comes in an imposing cardboard box, which is kept in plain black.
When I opened the package, I immediately thought of such a small soundproof chamber, as it is often used for recording podcasts and audio books. Pyramid foam – a nice gimmick
The XSTRM comes to the customer completely pre-assembled.
Besides the microphone and the just photographed nubby foam, there is also a cable, some adhesive strips and an actually even helpful manual in the box.
The pop shield, which is intended to prevent overmodulation of plosive sounds, is magnetic and can be flexibly attached to the microphone.
The triangular device comes with a spider that can be mounted on the sturdy stand at a freely adjustable angle. Of course, you can also unscrew them and attach them to a microphone holder.
On the back is the switch for AI Noise Cancellation, the USB-C port and a 3.5 mm jack for connecting headphones.
There is a multifunctional knob on the front that can be used to adjust the volume or sensitivity of the microphone. Press the button to cycle through different lighting modes. There is an indicator above the switch that goes off when sounds are detected, making it a good indicator of whether the set sensitivity matches the volume of the sound source. The display is even equipped with a G-sensor and is inverted when the microphone is mounted upside down.
P
Phoenixxl
160 Kommentare 124 Likes
Hat jemand Erfahrung ob man mit so einem Mikrofon und einem Kopfhörer vernünftig per TeamSpeak, Discord nutzen kann?
Also so, dass die anderen einen gut verstehen, aber eben nicht tausend Nebengeräusche haben?
Alexander Brose
836 Kommentare 598 Likes
Das kann ich dir direkt beantworten, weil ich es im Rahmen des Reviews natürlich auch getestet hatte. Meine Zocker-Kollegen waren von der Sprachqualität begeistert und mit der Discord-Geräuschunterdrückung (Krisp) werden Nebengeräusche sehr gut herausgefiltert. Das Einzige, was weder Krisp noch die AI Noise Cancelation des Mikrofons herausfiltern, ist das Sprechen anderer Personen im Raum. In meinem Fall können meine Kollegen dann sozusagen immer mithören, wenn meine Frau mit etwas mitzuteilen hat 😉.
Grüße!
B
Besterino
6,906 Kommentare 3,474 Likes
Ich nutze ein Rode NT-USB für Teamspeak und Videokonferenzen (Zoom, Teams, Webex). Geht prima, auch auf einige Entfernung zwischen Mic und Sprecher. Nur meine Tastatur ist zu laut, die fängt das Ding leider auch ganz gut ein.
Ansonsten: Hurra, endlich Ton mit RGB... *seufz*
f
funkdas
633 Kommentare 259 Likes
Ich habe ein Blue Yeti X und solange die Tastatur hinter dem Mikro steht, hört man die nicht. Auch hier kann das Mikro weit vom Sprecher weg sein. Bin sehr zufrieden.
Noch mehr Beleuchtung auf dem Schreibtisch nervt mich. Das Ding darf mit möglichst wenig Klimbim darauf hinweisen, ob es an oder aus ist. Aber Lichtshow am Mikro schreckt mich ab.
Alexander Brose
Ich mag RGB schon, aber wenn es blendet, geht mir das auch etwas zu weit. Aber zum Glück kann man es ja auch ausschalten 👍🏻
Grüße!
w
windclimber
72 Kommentare 21 Likes
Habe hier auch ein Yeti X und nutze die in der Software aktivierbare Störgeräuschunterdrückung von Nvidia. Gibt es auch als extra Programm "Nvidia Broadcast". Meiner Meinung nach besser als die Funktion in Discord und lässt sich auch in der Stärke anpassen.
Alexander Brose
