Monitors Practice Reviews
LG Calibration Studio Software in test – Hardware calibration – less delta or more error?
We recently wrote about the LG UltraGear 27GR95QE-B in a detailed article, and I recommend it to those who already want to buy an OLED monitor. The OLED monitors are currently still quite expensive, but compared to some IPS or VA alternatives – especially the LG 27GR95QE – offers decisive advantages. Contrast and HDR gaming – without latency drawbacks! Only the issue of text rendering and a possible burn-in risk remains as a small downer.
Der LG UltraGear 27GR95QE-B im Test – Ein „preislich attraktiver“ OLED-Gaming-Monitor im Standard-Format
You can also find all information about the test system here.
Nevertheless, you can also use an OLED panel for image editing, for example. And, we’ll start with this topic again today. Because what is important in this topic? Correct – color accuracy. The LG 27GR95QE offers the buyer the option – to perform a hardware calibration. This calibration is stored in the monitor and can be accessed via the OSD menu. This offers the advantage that the calibration does not require app support – as is the case with a software calibration. A hardware calibration is thus more universal.
Before I get right to today’s topic, I have to make up for one important point. Even I’m not infallible, and during my testing of the LG 27GR95QE, I didn’t notice that the ON/OFF button (power button) below the display comes with basic OSD adjustments. Sorry for the mishap on my part! Still, you have to rely on the remote control, so that doesn’t change anything in my article.
Source: Prad.de
At this point I can only refer to the article from Prad.de (click here!), because I don’t have the monitor with me anymore. Thanks to the colleagues from Prad, that you didn’t miss it. But I think that the good Pascal will show us the whole thing again in his video.
That should clear that up and we can devote ourselves to the actual topic.
S
SpotNic
1,086 Kommentare 460 Likes
Hm gleiches Problem wie beim GQ900, deutliche Streifen im Graubereich:
Hab ichs überlesen oder wird auf sowas nicht eingegangen?
w
wertzius
54 Kommentare 43 Likes
Ich würde eher sagen nicht alles was die Kamera sehen kann, sieht auch das Auge.
Das sind jedenfalls nicht die LG-OLED typischen grauen Streifen und Flecken im dunklen Graubereich, die durch den Herstellungsprozess entstehen.
F
Furda
663 Kommentare 373 Likes
Was ist der Unterschied zwischen den Optionen "Kalibrierung 1" und "2"?
Zitat:
"...Das bietet den Vorteil, dass die Kalibrierung nicht – wie bei einer Software-Kalibrierung – einen App-Support voraussetzt..."
Worin unterscheidet sich dies hier nun von dem Farb-Profil, welches unter Windows benutzt werden kann? Klar HW Kalibrierung ist im Monitor gespeichert und unabhängig vom Windows und allem Anderen. Aber wo liegt der Unterschied zwischen "App-Support" und dem universellen Windows-Profil? Muss eine App das Windows-Profil unterstützen? Überschreibt Windows da nicht autom. alle Farben gemäss Profil?
FritzHunter01
1,216 Kommentare 1,649 Likes
Nicht jede App unterstützt ICC-Profiles die via Software unter Windows hinterlegt sind. Eine Hardware-Kalibrierung ist somit universeller!
Der Unterschied zwischen kalibrierung 1 & 2 ist, dass unter der Kalibrierung 1 eine sRGB-Farbraum-Kalibrierung gespeichert ist, somit passt alles auf sRGB. Unter der Kalibrierung 2 liegt dann DCI-P3, zwar ist der Gamma-Wert mit 2.2 und der Weißpunkt 6500K hier der gleiche wie bei der Kalibrierung 1, aber der Farbraum ist erweitert (größer).
F
Furda
Danke für die Erklärung.
Auf den Screenshots siehts so aus, als könne man rechts von der Kalibrierung noch den Farbraum wählen (Combobox), doch dieser ist also fix für Kal. 1 oder 2.
8j0ern
2,756 Kommentare 854 Likes
@FritzHunter01
Ich finde den Bereich, der von der Kamera erfasst wird etwas klein.
Aber das sollte bei der Parameter Anzahl kein Problem sein.
Bei meinen TV wird eine größere Fläche vom Bildschirm genutzt, weil auch mehr als 3 Parameter erfasst werden. ;)
FritzHunter01
Du kannst im Zuge der Kalibrierung auswählen was du unter Kal. 1 bzw 2 machen willst. Du wählst den Farbraum, dann Weißpunkt, Gamma und Helligkeit
8j0ern
F
Furda
Hm, dann ist doch ein Unterschied zwischen 1 und 2? 🙈 Sorry dass ich frage, es interessiert mich, da ich noch nie so eine Kalibrierung gemacht habe (und müsste def. mal eine machen), ob da der Ablauf oder die Messwerte, Genauigkeit etc. variieren bei unterschiedlichen Kalibrationen? Wozu 1 oder 2? Da ist dich irgendwo ein Unterschied (den ich offensichtlich nicht peile).
FritzHunter01
Der Unterschied liegt einzig im Farbraum! Die Kalibrierung 1 ist auf den sRGB Farbraum definiert. Somit können auch nur die Farben (Farbtöne und Sättigung etc) aus den sRGB wiedergeben werden. Mit anderen Worten: schaust du einen Film der im DCI-P3 gemastert wurde auf der Kalibrierung 1 an, dann siehst du alles in Rec. 709/sRGB. Nimmst du die Kalibrierung 2 (DCI-P3) dann passt es grundsätzlich zum gemasterten Content. Mit der Kal. 2 wird aber sRGB Content „falsch“ wiedergeben. Da werden insbesondere Hautfarben (Töne) übersättigt.
Das siehst zum Beispiel an den Messungen die default mache. Ich teste jeden Monitor out of the box in Bezug D65, Gamma 2.2 im sRGB Farbraum. Weil es nun mal der Standard-Farbraum ist.
Die meisten Monitore laufen default im wide gamut und das für zu hohen delta E 2000 in Bezug auf Sättigung und Farbgenauigkeit. Unabhängig davon, ob der Weißpunkt und Gamma stimmt. Ohne Begrenzung des jeweiligen Farbraums passent zum Content gibt es keine guten delta E. Mal ganz einfach erklärt. Hoffe es kam verständlich rüber.
Abgesehen davon: wenn ich einen Monitor auf D65 Whitepoint mit gamma 2.2 kalibriere/einstelle. Dann passt die RGB Balance grundsätzlich zu allen Farbräumen. Wenn ich allen Farbräumen diese Settings haben möchte.
Problematisch ist dann nur das gamut clamping!
F
Furda
@FritzHunter01 danke nochmals für die Erklärung! Ich muss wirklich mal selbst eine Kalibrierung durchführen, dann sehe ich es aus erster Hand, und verstehe dann aus der Praxis (hoffentlich) auch mehr.
f
fixgdf
1 Kommentare 0 Likes
Hallo.... kurze Frage, das Colormeter kommt das dann per USB in den Monitor oder in den PC? oder ist das egal? bzw. wie werden dann dann die Daten in den Monitor geschrieben und nicht nur ein ICC Profil abgelegt?
A
Axident
10 Kommentare 7 Likes
1000 Dank für dies Review!!! Ich habe mir letzte Woche den LG UltraGear 48GQ900-B geholt (ich hasse glossy Panels / für 899€ LG OLED Versandkostenfrei... warum nicht). Ich bin meeega zufrieden mit dem Teil! Mit einem SpyderX Pro für unter 120€ nach Lektüre dieses Reviews habe ich das gute Stück hervorragend Hardware-kalibriert bekommen! Alle Werks-settings sind im Vergleich zur Kalibrierung Müll! Ich habe vom P3 Farbraum Abstand genommen und die beiden Speicherplätze mit sRGB 100 Nits und sRGB 200 Nits gespeichert. Die Kalibrierung scheint auch nach Firmewareupdate nicht überschrieben oder gelöscht zu werden. Also alles in allem absolut Top!
A
Axident
Das macht alles die LG Calibration Software. Die Daten werden in den Settings des UltraGear in der Elektronik des Panels gespeichert und sind über das Monitor-interne Menü aufrufbar.
Ich habe den Monitor per USB (2.0) an den PC und einen SpyderX Pro an den USB Hub des Monitors angeschlossen.
Die LG Calibration Software muss nach erfolgter Kalibrierung nicht per Autostart mitlaufen. Kann man auch direkt wieder deinstallieren und nur bei Bedarf (alle paar Wochen) mal kurz installieren. Ansonsten muss man den Prozess deaktivieren (lokale Dienste: LG Calibration Studio Service), wenn Windoof im Betrieb clean bleiben soll. Weder LG Displaytreiber, noch LG OnScreenControl sind nötig. Letzteres kann man aber auch vor der Kalibrierung installieren, wenn man vorher die Firmeware updaten möchte. Ich habe das hinterher getan. Bei Firmewareupdates ist mir immer mulmig, vor allem, weil einer (Amazon-review) danach keinen Ton mehr hatte und ich die recht probaten Lautsprecher des Monitors schon nutze, wenn ich nicht immer die 6 Kanal Anlage mit anschalten möchte.
Follow Igor:
