Aircooling Case Reviews
DEEPCOOL CH560 WH Mid-Tower in test – All-White DeepCool build ensures a white (and cold) Christmas even without snow
With the CH560, DeepCool remains true to its design language and appeals particularly to fans of simple shapes. The highlight: the CH560 “DIGITAL” version with integrated temperature display is available for an extra 10 euros. Read on to find out how the compact case for around 120 euros performs in everyday use.
During the Christmas season, I prefer to build white systems to at least create a little winter atmosphere on the desk when there is usually no snow. in 2021, the Raijintek Silenos MS had to be used for this, last year it was the turn of the Thermaltake Ceres 500 – after some delay. The anticipation was correspondingly great when DeepCool came around the corner with the CH560 for this period and even gave me an all-white build with additional components.
In addition to the four included ARGB fans and the expected good airflow, another feature caught my attention, which is, however, reserved for the 10 euro more expensive “DIGITAL” version of the CH560: a small “display” to show the current CPU temperature. Although the samples with display were all sold out, I can still show you the display in a similar form thanks to the use of the AK620 CPU cooler, which is also available as a “DIGITAL” variant and which Tim already presented to you yesterday. Before I go into the technical details, let’s unpack the case together. And one more note: I’m using the AK620 that I tested yesterday, but in the white version and with a digital display. This also gives you a reference point for the temperatures.
Deepcool AK620 CPU air cooler review – A real insider tip in the dry biotope?!
Unboxing
In keeping with the simple design, the outer box of the CH560 also comes without a glamorous appearance.
Here’s the thing. The side window is slightly smaller because around a third of the side section is made of mesh. This not only helps the temperatures, but also accommodates the above-mentioned display in the DIGITAL version.
The front could hardly be simpler: full-surface mesh with a generous grid, so there’s certainly no need to fear suffocation.
As with almost every case of this type today, the entire front of the CH560 can also be removed.
A dust filter is embedded in the front, but this can only be removed by loosening a few screws. Normally, however, it is sufficient to remove the dust regularly with a brush and cloth.
There are four pre-installed 140mm ARGB fans behind the cover, which are relatively quiet and also look good.
While we’re on the subject: The fans are attached to a small bracket that can be separated from the housing with four screws. The use of this bracket is optional, but allows fans or radiators to be mounted more conveniently outside the housing.
At the bottom, apart from the feet and the guides for the sliding HDD cage, we only find a small dust filter that is difficult to remove and clean.
I don’t quite understand why they didn’t at least use a filter that can be pulled out to the rear when there are already guides for one.
The rear is plain and simple, no mounting frame for the power supply unit, no slot bezels for vertical mounting of a graphics card, just a well-ventilated rear of the case.
Next, let’s take a look at the top of the case.
The upper fan mounts are adorned with a magnetic dust filter, which can be easily removed.
The front I/O has also been moved upwards in favor of the airflow. In addition to the power button and a button for the integrated ARGB controller, we find a manageable number of ports. 1 x USB 3.0, 1 x USB Type-C and a 3.5mm combo jack – that’s it. As I often work with USB sticks or use USB receivers as part of peripheral tests, I would have welcomed more normal USB ports here.
As there are a few more pictures of the unboxing to follow, I’m splitting it into two pages again.
Tim Kutzner
857 Kommentare 700 Likes
Du und deine weißen Gehäuse :D
Schönes Ding!
ipat66
1,422 Kommentare 1,436 Likes
Mann, ist die erste Seite heute hell...
Bin ja sonst im Dark-Mode unterwegs.
Mit Sonnenbrille ging es aber ;)
Nettes,weißes Airflow-Gehäuse.
Schoener Build.
Danke Alex.
Xaphyr
67 Kommentare 65 Likes
Cool, genau das Gehäuse finde ich äußerst interessant, vielen Dank für den Test! Ich mag den kantigen Style von Deepcool.
Die Lüfterplätze auf der Netzteilabdeckung erscheinen mir sinnlos, ohne eine Perforierung derselben oder der anderen Seitenwand, ebenso der lächerliche Staubfilter des Netzteils, trotz vorhandener Schienen für einen, den man zumindest nach hinten herausziehen kann. Aber ansonsten ein echt nettes Teil. Sieht in weiß echt klasse aus.
Atze Wellblech
110 Kommentare 21 Likes
Schickes weisses Gehäuse. Schwöre auf das be quiet! PURE BASE 500DX WHITE.
Ein starkes Stück weisses Blech worin ich auch schon den DC AK620 WH verbaut habe.
Weiss boomt irgendwie in den letzten Jahren, hab ich zumindest das Gefühl.
Vielleicht kann ich beim nächsten Zusammenbau ja mal jemandem das CH560 WH empfehlen.
Alexander Brose
