Keyboard Practice Reviews
Corsair PBT Double-Shot PRO Keycaps – Durable finger food and noble caps at a fair price
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
As mentioned in one of my last keyboard articles, keyboard modding is becoming increasingly popular in our neck of the woods. The exchange of the keycaps is an extremely simple way of individualisation and is becoming more and more popular. In the twinkling of an eye, the caps have been pulled off and replaced with new ones. There are almost no limits to the imagination and because almost all manufacturers use switches in the format of the Cherry MX switches, there is quite a large compatibility between all the keycaps and keyboards. Today, let’s take a look at how class leader Corsair enters this scene.
More and more manufacturers recognize the potential of this simple possibility of modding and jump on the bandwagon. So now Corsair is also preparing to bring noble PBT keycaps for their keyboards to the market. At a price of about 30€, which is rather in the lower midfield, comes the complete set of all 104 caps including cap puller and damping rings. In total, the kit comes in six different colors:
What are PBT “double-shot” keycaps anyway?
Since there is still a product or two on the horizon with regard to this topic, and it will show up at Igor’s Lab sooner rather than later, I’d like to briefly go over what PBT “double-shot” actually means. Nowadays, a translucent, i.e. translucent, material is used for the production of keycaps and cast into the corresponding key moulds. Later, the keys are covered with an opaque paint and only the corresponding letters/characters/symbols are left free, so that later the light shines through only the symbols from below.
This is the most widespread and cheapest solution, but it has the disadvantage that the paint will peel off over time, resulting in unsightly effects. With the very first keyboards, where low-cost production was not yet a priority and there were no illuminated keys, one was faced with a similar problem: The printed symbols were worn off after prolonged use and only the “blank” cream-colored keys remained. To get around this problem, the so-called “double-shot” process was already used at that time and keycaps were produced from two layers. An “inner layer” (the color of the symbol on the key) and an outer layer (the color of the key), which found each other in an elaborate process.
At first glance, there is hardly any difference between the inexpensively produced and the elaborate “double-shot” keys:
Viewed from below, however, you can quickly see the difference. While the black keycap consists of only one “painted” layer, you can clearly see the two separate and much thicker layers of the double-shot key:
It might be more obvious in a rendered image of the cross section:
The advantages are obvious: “Double-Shot” caps feel much higher quality in terms of material alone and are much more durable. However, there are also some disadvantages, which I will discuss later.
Tim Kutzner
855 Kommentare 700 Likes
35€ für ein Keycap Set im deutsches Layout und von deutschen Händlern ist Bombe
Antwort 4 Likes
10,466 Kommentare 19,586 Likes
Da muss man gar nicht drüber nachdenken
Atze Wellblech
110 Kommentare 21 Likes
Interessant, das überleg ich mir, hätte 2 Bretter zu bestücken (y)
ArthurUnaBrau
330 Kommentare 162 Likes
Vielleicht weiß hier ja jemand mehr: Deutsche Layouts sind immer schwer zu finden. Hat jemand ne Ahnung, wo man nicht-Standard Profile keycaps im deutschen Layout herbekommt? DSA, etc.?
Tim Kutzner
AliExpress und Glück haben :D
n
netterman
159 Kommentare 62 Likes
passen die Dinger eventuell auch auf ne Ducky - wenn es die dann nochmal irgenwann als Pudding geben würde wäre das genial - iso de pudding pbt gibt es einfach nicht und die von Ducky vor über 2 Jahren bereits in Aussicht gestellten sind nach wie vor nirgendes zu finden :(
Alexander Brose
836 Kommentare 598 Likes
Auf der Seite von Corsair findest du beide verfügbaren Layouts. Bei manchen Corsair Tastaturen haben die Sondertaste (STRG, WIN, FN usw.) etwas unterschiedliche Größen.
Grüße!
RAZORLIGHT
360 Kommentare 266 Likes
Durchaus fairer Preis gefällt mir.
Flache PBT Kappen wären noch cool.
Sind die Kappen nur für Corsair Tastaturen, da sind einige Tasten ja nicht im Standard-Layout.
Außerdem gefällt mir die Schriftart nicht wirklich.
Blubbie
808 Kommentare 275 Likes
Blöde frage zu keycaps, angenommen man hat eine Tastatur im US Layout. Also "z" an der stelle vom "y", keine Umlaute und so... Kann ich mir einen deutschen keycaps Satz kaufen und diese einfach auswechseln?
Man würde ja vorher schon im Betriebssystem die Tastatur auf ANSI (?) also deutschen Layout umstellen.
Mich wurmt dass es doch tolle Tastaturen aus Kickstarter kampagnen gibt, die aber nur im US Layout sind....
I
Irrer Pinguin
5 Kommentare 3 Likes
Hallo,
Also ich weiß nicht, ob die Caps von Mountain genau passen, aber da die Cherry switches in den Tastaturen haben ist die Wahrscheinlichkeit hoch.
Black Pudding ist bei denen gerade noch im Angebot für 25€
Vielleicht hilft dir das.
D
Der Do
83 Kommentare 32 Likes
Schade dass die nicht auf eine K70 Lux passen, die hat leide eine große Enter Taste
Alexander Brose
Die Kompatibilität ist hier einzusehen: https://www.corsair.com/de/de/pbt-double-shot-keycaps
Die Größe der Enter-Taste hängt vom Layout (z.B. US/DE) ab, oder was meinst du?
Grüße!
maxz
1 Kommentare 0 Likes
Sind leider ziemlich miese Keycaps, die unter anderem auch auf dem K100 genutzt werden.
Von schneller Abnutzung mag man schon fast gar nicht mehr reden. Die Oberfläche wird binnen Wochen quasi jegliche Textur verlieren.
Alkbert
958 Kommentare 742 Likes
Beim Tauschen von Z und Y bin ich schon reingefallen, als ich mir einen amerikanischen Satz mit Konkaver Neigung zur mittleren Reihe hin bestellt habe - da kippen die beiden Tasten dann "falsch herum" ab, wenn man Z und Y tauscht. Ausserdem ist die Return Taste immer ein besonderes "Leckerli" bei deutschem Layout. Umlaute sowieso.
K
KMenssen
30 Kommentare 7 Likes
Moin, natürlich gibt es die ... HyperX hat PBT Pudding Keycaps in schwarz und weiss ... habe die selber hier liegen und sind genial.
n
netterman
die kenne ich natürlich und die sind mit iso de layout und wirklich pbt nicht abs ?
meines Wissens nach sind die iso de hyper x pudding keycaps leider nur aus ABS und nicht PBT Kunststoff - das englische Layout der hyper x pudding caps ist hingegen aus pbt - in meinen Augen ein Witz und absolut unverständlich aber ist leider so
ausser deine mit DE Layout sind wirklich pbt ? dann würde ich sie mir gleich besorgen - sofern sie mal wieder lieferbar sind
K
KMenssen
Hallo, stimmt hast recht US Layout ist PBT und DE Layout ist ABS
z
zettmod
Das kommt auf das weitere Layout an. Beispielsweise haben viele Custom Keyboards - beispielsweise im beliebten 65% Format eine 1,75 Einheiten lange Shifttaste rechts. Im Corsair Set beispielsweise ist diese Größe nicht dabei und Du hast keine passende Taste für den Switch. Deshalb findest man im Custom Bereich bei den Keycaps sowohl für das PCB als auch für Keycap Sets genaue Größenangaben für die Tasten -gemessen in "Units" 1 Unit ist praktisch eine Normaltaste. Und für viele Sets im custom Lager gibt es Erweiterungen mit "Sondergrößen", die man dazu kaufen kann. Beim Corsair Set hat bspw. nur die Caps-Taste das 1,75 Unit Format- das heißt man müsste für die eine Taste das Set zwei mal kaufen und Shift rechts wäre falsch beschriftet mit "Caps". Dann ist es zudem leider auch noch so, dass je nach Profilvariante die einzelnen Reihen unterschiedlich abgeschrägt und hoch sind. So dass zum Beispiel eine Taste aus Reihe 2 eingesetzt in Reighe vier ab/überstehen kann. Die Profile und Maße je Reihe findet man per Suchmaschine "Keycap Profiles".
Fazit: immer genau Messen was man braucht, Layouts vergleichen und entsprechend einkaufen. Für Deutsche ANSI "kleine Enter Taste" User und erst recht für ISO-DE Nutzer wird es damit praktisch immer ein gutes Stück teurer Keycaps zu kaufen und die Auswahl ist sehr eingeschränkt.
Aber ein Lichtblick ist: Die custom keyboard Szene hebt grade international Wahnsinnig ab und drückt in den Massenmarkt. Wir sind hier zwar immer etwas später dran, aber meine Prognose ist, dass die Auswahl und Verfügbarkeit in der kommenden Zeit / Jahren deutlich zunehmen wird. Im Moment kommt man als DE-Layout Nutzer praktisch nur durch Groupbuys (und damit Geduld) an wirklich besondere Keycaps im Hochpreisbereich.
Hoffe der kurze Abriss hilft etwas weiter. Der Hinweis bezüglich der Shift Taste ist vielleicht auch für den ein oder anderen nützlich und spart Frust.
Triton
35 Kommentare 20 Likes
Ich habe mir den roten Satz bestellt um ein Ducky-Board (One 2 - RGB) ein wenig aufzumotzen. Bin recht zufrieden was die Qualität angeht. Haptisch fühle ich da keinen Unterschied. Die Schriftart ist abweichend vom Ducky-Original. Hat aber auch einen gewissen Reitz :)
Alexander Brose
