Audio/Peripherals Keyboard Reviews
Corsair K70 RGB TKL Champion Keyboard Review – With 8000Hz to victory?
And again Corsair releases new peripherals, even a completely new series. Under the name “Champion Series” you can find a new mouse and keyboard, which were tested and developed together with eSportsmen. Today we’ll first look at the keyboard, the mouse will follow shortly.
The box looks like any other outer box from Corsair, except for the new Champion label. The black front and back are framed by yellow pages. The usual product picture in large format on the front may not be missing, of course, as well as the feature texts on the back. So everything as you are used to.
The keyboard inside is protected by double wrapped cardboard and a small piece of foam in the lid. Still included are instructions, a braided USB Type-C cable, replacement keycaps and matching puller.
The extra keys are for the letters WASD as well as QWERDF and have an extra rough top made of small triangles. On the plug of the USB cable on the Type-A side there is a small keyboard symbol to make it easier to identify. Unfortunately, there is no wrist rest included, which should have been there in my opinion for the called price.
Specifications
Below are the technical details from the preliminary press release, for everything else head over to the productpage.
Corsair Gaming K70 RGB TKL - Champion Series, MX SPEED RGB Silver, USB, DE (CH-9119014-DE)
Tim Kutzner
871 Kommentare 714 Likes
War interessant zu sehen, wie wenig sich seit meiner mittlerweile 7 Jahre alten Corsair K70 am generellen Design geändert hat :D
Aber wieso sollte man auch etwas ändern, was sich gut verkauft?
Jean Luc Bizarre
207 Kommentare 133 Likes
Bin seit 2 Wochen auch Besitzer einer Corsair-Tastatur (K70 MK2) und muss sagen, dass mir die Tastatur und die Verarbeitung echt gut gefällt. Hardwareseitig kann ich nur die Nachhallgeräusche der Federn kritisieren (Brown Switches). Das war bei meiner Vorgängertastatur (QPAD MK-80) nicht so, oder ist aufgrund der Klicky-Charakteristik (Blue Switches) einfach nicht aufgefallen.
Softwareseitig ist Corsair meines Erachtens aber eine Katastrophe! Diese iCue-Software ist mega laggy, verbraucht einen Gigabyte RAM und macht einfach nicht was sie soll. Ich habs ums verrecken nicht hinbekommen eine statische, einfarbige Beleuchtung einzustellen, die dann anch dem nächsten Systemstart auch wieder voreingestellt ist. Auch nicht als ich sämtliche Hardwareprofile gelöscht hatte und nur dieses eine (statisch, einfarbig) reingeladen habe. Da kam immer eine Christbaumbeleuchtung mit irgendwelchen idle-Effekten. Absolut widerlich.
Habe dann die Software deinstalliert und siehe da: das einzig verbliebene Profil (statisch, einfarbig) wird geladen. In meinem Falle also Funktionserweiterung durch Deinstallation der dazugehörigen Software.
Abgesehen davon bin ich aber wirklich zufrieden mit dem Ding.
Tim Kutzner
Kurios, welche Version der Software nutzt du denn?
Weder braucht die bei mir so viel RAM noch ist die Bedienung verzögert oder funktioniert nicht ... hat vielleicht der SoC deiner Tastatur einen weg? Im Zweifelsfall mal den Corsair-Support kontaktieren
Den Nachhall konnte ich wie im Artikel beschrieben nur absichtlich produzieren, der ist nie bei normaler Nutzung aufgetaucht.
10,649 Kommentare 20,049 Likes
iCue ist echt lahm. Immer up2date. Maus, RAM und AiO :D
Jicaraen
54 Kommentare 29 Likes
Ich nutze auch ne Maus und Tastatur von denen und bin mit der Hardware mehr als zufrieden, auch wenn beides preislich eher im Einstiegssegment ist, so gibt es gegen die Hardware nix auszusetzen. Ganz im Gegensatz die Software. Selbiges wie @Jean Luc Bizarre iCUE 4.x will einfach die Maus nicht auf statisch stellen und die DPI müssen auch bei jedem Neustart eingestellt werden. Super nervig.
Jean Luc Bizarre
@Tim Kutzner also der Installer der bei mir im DownloadOrdner liegt hat die version 4.9.338. Keine Ahnung ob der sich nach der Installation noch geupdated hat.
Ich werde auf jeden Fall nen Teufel tun und das nochmal installieren nur um das Ganze nochmal zu reproduzieren. So wie es ist, ist es gut und so lasse ich es auch. Macht jetzt ja auch alles so was es soll. Leuchten, und sonst nichts.
Wenn ich mich aber richtig erinnere, dann ging die gesamte Software für ca. 10sek in den "unresponsive"-Modus wenn ich auf den Reiter "Settings" geklickt habe. Ich habe wie gesagt irgendwann entnervt aufgegeben.
Es ist ja schön, dass viele Menschen ihre Beleuchtung und Effekte in all ihrer Kleinteiligkeit megaaufwendig und raffiniert mit dieser Software realisieren können, aber manchmal verlieren die Programmierer dann das Auge für den User der einfach nur was ganz Einfaches will und machen es diesem dann auch unnötig komplizert.
Tim Kutzner
Also schwierig ist es jetzt nicht.
Beleuchtung > Statische Farbe > Farbe auswählen
Fertig!
Jean Luc Bizarre
Das hat auch erstmal so funktioniert, aber nach einem Neustart wars wieder weg...
A
Art
54 Kommentare 10 Likes
Ich suche eher eine mit 82 Tasten und QWERTZ Layout, idealweise nicht-schwarz und low-profile - scheint mir bisher aber noch Mangelware zu sein (wenn man nicht Premium+ bezahlen will).
Bis weitere Chinesen den DE Markt entdecken, muss ich wohl bei meiner Royal Kludge RK61-DE bleiben - hat auch keine Software Probleme: gibt keine SW ;)
K
Kobichief
673 Kommentare 204 Likes
Numpad ist wohl aus der Mode bei ProGamern
Jicaraen
Sollte man meinen. Klappt allerdings nicht immer bzw bei mir gar nicht.
Auch die Beleuchtung einfach aus, zumindest beim Logo geht nicht wirklich einfach per Schalter.
Tim Kutzner
Mehr Platz für die Maus :D
Guest
Meine Erfahrung mit einer kürzlich abgegriffenen K70 war leider ein Griff in die Tonne, da die Entf- Taste jedes mal hängen blieb. Aber die sonstige Verarbeitung hat keine Wünsche übrig gelassen, da lassen sich die Leute von Corsair normal ja nicht lumpen. Sieht man eben auch am Preis, der meines Erachtens dann doch oft übertrieben hoch erscheint. Aber wenn alles funktioniert, kann man über die Hardware sicher nicht meckern. Zur Software kam ich bei meinem Exemplar ja nicht. Und kann da wohl auch ganz zufrieden mit sein, so wie man hier liest.
Aber die nach oben abstehenden Tasten, ich weiß nicht: dafür kann ich mich einfach überhaupt nicht begeistern. Genau so wenig für diese Tastaturen ohne Numpad. Und wenn sich mancher Hersteller jetzt auch noch die Handballenauflage extra bezahlen lässt, ist das eher kein Kaufargument. Bei einem Preis von 150,-€ aufwärts, meine ich, sollte sowas schon dabei sein...
Jean Luc Bizarre
@halfevil333 So Unterschiedlich kann es sein. Ich habe explizit nach einer Tastatur mit freistehenden Tasten gesucht. Ich rauche zwar nicht in meiner Wohnung, aber drehe vor allem im Winter schon die Ziggis am Schreibtisch. Und diese Tabakkrümel... Ein Krampf die bei versenkten Tasten wieder rauszubekommen. Ich finds auch gut, dass es mittlerweile mehrere Tastas ohne Ziffernblock gibt. Für mich wärs nichts, ich brauche den zwingend, aber für Menschen die "wenig mit Zahlen machen" hat es echt eine Daseinsberechtigung. Es spart halt ne Menge Platz.
Und zu guter letzt zur Software. Ich lasse zwar kein gutes Haar an der iCue-Grütze, aber sooo schlimm wars für mich ja jetzt nun auch nicht. Einmal eingestellt, danach dinstalliert, läuft. Wenn man natürlich permanent was an der Beleuchtung ändern möchte, dann siehts natürlich anders auch.
Abductee
274 Kommentare 49 Likes
Nen Numblock kann man auch extra kaufen und nur hinstellen wenn man ihn braucht.
Guest
Ja, @Jean Luc Bizarre, da kann ich dir nur recht geben. Aber zum Glück sind Geschmäcker und Vorlieben ja verschieden. Nachdem ich die K70 wieder zurück geschickt hatte, hat mir meine Frau das Cherry MX Board 5.0 mit MX Silent Red geschenkt. Zuerst dachte ich ja: was für ein Teil und vor allem, was für eine riesige Handballenauflage! Aber nach 10 Minuten wusste ich dann: das ist sie. So entspannt hab ich selten mit Tastatur gezockt, selbst nach Stunden keinerlei Ermüdungserscheinungen, wie ich es z.B. bei den Skiller Mech SKG 3 hatte. Einerseits, weil da keine Handballenauflage dabei war und dann die hochstehenden Tasten, das wurde dann manchmal schon etwas verkrampft in den Händen. Auch das Schreiben klappt tadellos, sehr angenehm.
Und da ich das Rauchen nach 30 Jahren durch Dampfen ersetzt habe, produzier ich auch weder Asche noch Krümel. Und für den üblichen Staub hab ich mir so einen kleinen, aber sehr kräftigen Akku-Sauger zugelegt. Da hatte ich auch in den 30 Jahren, in denen ich mit PC´s so viel zu tun habe, wohl auch ziemliches Glück. Denn außer wegen Ermüdungserscheinungen musste ich Tastaturen eigentlich nie austauschen. Und diese habe ich, seit ich Mecha´s benutze, nicht mehr erlebt.
Ich glaube auch, bemerkt zu haben, dass es wohl schwieriger ist, bei den abstehenden Tasten wirklich leise zu sein. Ist aber natürlich nur meine Meinung, ich mags eben gerne leise.
Den Schreibtisch hab ich vor einer Weile selbst gebaut, 1,6m x 0,8m, mit Podest für die Bildschirme, da existieren daher auch keine Platzprobleme. 2 normale Tastaturen nebst jeweils noch einer Maus gehen da ohne Weiteres. Ist auch praktisch bei 2 Rechnern. So eine Tastatur ohne Numpad wirkt auf mich immer irgendwie kastriert. Aber ich nutze den Nummernblock halt auch oft.
Tja, Geschmäcker eben...
Corro Dedd
1,832 Kommentare 692 Likes
Ich habe mir gerade erst die Strafe Mk2 gegönnt mit den Red Silent Tastern. Ich bin gerade am überlegen, ob das privat meine erste mechanische Tastatur ist oder ob ich anno dazumal schon mal eine dieser Cherry Tastaturen hatte, die damals in den 90ern einfach Standard waren. Jedenfalls muss ich mich jetzt erst mal etwas umgewöhnen von meiner G510 mit Rubberdome Tasten. Aber bisher klappt das ganz gut. Nur die Handballenablage ist viel zu flach, da muss ich mir noch etwas überlegen.
//edit
Ohne Nummernblock geht allerdings bei mir gar nicht. Und beide Windows Keys hätte ich auch gerne, das schränkt die möglichen Optionen schon stark ein.
Und warum fährt Corsair eigentlich zweigleisig bei der Software?
Jicaraen
Version 4 geht nicht bei ein paar älteren Produkten.
Atze Wellblech
112 Kommentare 21 Likes
K70 MK.2 --> immer noch zufrieden.
Die iCUE Software ist teilweise nen Graus.
Mit den Beleuchtungseffekten bin ich zwar zufrieden, alles läuft wie eingestellt.
Aber beide der Maus (Glave) fehlt mir die Brillanz beim Feintuning.
Die Software reagiert zu zögerlich. hier wäre ne integrierte eindeutig vorzuziehen.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
