Of course, the title is meant to be a bit ironic, but I just have to take the otherwise practically everything lighting manufacturer Corsair for a ride when, for once, a product with a reduced RGB flood is presented. Because the last AiO’s of this brand either had “next-gen” RGB or even a small screen installed, this turnaround was a bit unexpected. So let’s take a look at what points this AiO water cooler wants to convince with instead.
In any case, it comes in the usual box with a black and yellow design, and the front proudly presents the RGB armor of this model. A bit of illumination can be seen on the back, but there are mostly specifications to be seen here.
Inside, it’s the same as usual. During transport, the cooler is protected all around by a shell made of sturdy cardboard.
The included accessories are – sometimes due to the lack of RGB controller and cables – quite manageable and only include a small wiring harness with connections for the pump and fans besides the mounting parts.
As so often, I still miss a tube of thermal paste. If you install this compact water cooler more than once, you have to buy it yourself.
Assembly and installation
The installation is also a good keyword, because it is quite easy. For the AM4 socket, the pre-mounted Intel bracket has to be replaced first, and the plastic brackets already on the motherboard have to give way as well.
However, the backplate may remain, where four spacers are screwed in. Afterwards, the pump block can be placed on the processor and fixed in place with four ratchet screws.
Specifications
Here is a quick overview of the most important technical specifications. More information can be found on the manufacturer’s product page.
Corsair iCUE H150i RGB Elite, schwarz (CW-9060060-WW)
Bestellt, versandfertig in 3-7 Werktagen | 149,90 €*Stand: 17.09.24 10:49 | |
Zentrallager: Auf Lager | 210,39 €*Stand: 17.09.24 10:30 | |
am Lager, Lieferzeit 1-2 Tage | 214,00 €*Stand: 17.09.24 10:04 |
12 Antworten
