It’s been quite a while since we’ve seen an air cooler from this manufacturer, and the last attempt was crowned with moderate success. Now they are trying again and want to reach the top. The following test report will tell you whether this will work.
Of course, we’ll also take a quick look at the exterior, as we’ve become accustomed to Corsair’s yellow and black design. But today, for once, we have a cube in front of us, not the usual cuboid of AIO water cooling systems from this manufacturer.
Otherwise, the front is adorned with a classic high-resolution product image, while further information and details can be read on the back.
If we remove the cardboard box, we can take a look at the transport protection. Two fairly thin sheets of foam protect the top and bottom, while the sides are made of cardboard with other parts.
I think this is the first time I’ve seen it, the usual plastic bags have been replaced with a kind of thin wax paper. Nice thing!
The accessories include the various brackets and spacers for the supported sockets, apart from that only a Y-cable for the fans is included.
Mounting and installation
If both fans are to be used on the cooler, the two retaining rails must first be attached to the front ones. The brackets that are otherwise frequently used are not available here. The entire process can also be viewed in video form:
With my AM4 socket used here, the existing backplate of the mainboard is supplemented on the front by four spacers, which have two brackets screwed onto them. The two spring-loaded threads can then be fixed to these.
Specifications
Before we get to the details, here is a list of the key technical data. More information can be found on the manufacturer’s product page.
Corsair A115 (CT-9010011-WW)
![]() | Bestellt, wird in 1 Werktagen erwartetStand: 16.07.24 06:25 | 101,39 €*Stand: 16.07.24 06:30 |
![]() | Lager Lieferant: Sofort lieferbar, 1-3 Werktage | 101,40 €*Stand: 16.07.24 06:22 |
![]() | Onlineshop: lagernd, Lieferung 2-3 WerktageHannover/Laatzen: lagernd (keine Online-Reservierung möglich)Berlin, Dortmund, Düsseldorf, Hamburg, München, Stuttgart: nicht lagerndStand: 16.07.24 06:22 | 103,95 €*Stand: 16.07.24 06:31 |
29 Antworten
