Aircooling Case Reviews Watercooling
CORSAIR 2000D Airflow in review – Mini-ITX case with great airflow and a small issue
With the 2000D Airflow, Corsair rounds out the current portfolio downwards and now also presents an extremely spacious case for the smallest form factor. Up to eight 120mm fans, a 360mm AIO and a tripple-slot GPU with a length of up to 36cm can be accommodated in 24.4 liters. You can read more about the drawbacks in the review.
Short preface
I’ve been lurking around the Mini ITX format for a while now, but so far the spark just wouldn’t fly between us. Thanks to the help of ASUS, Igor and Tim I was finally able to enter the world of compact computers and to kill several birds with one stone, I’m also building my first (own) Intel system since the introduction of the Core 2 Duo almost 17 years ago.
Introduction
When it comes to mini-PCs, most people still think of Raspberry Pis, small network clients, or the midgets that Tim often has in review. However, the enthusiasm for these computers, which are as compact as possible and were once designed for multimedia applications in the living room or for light office programs on small desktops, soon aroused the interest of the gaming faction. Small ITX boards had long since been designed that could even easily accommodate high-performance processors like a Core i9 or Ryzen 9 – all that was missing was a powerful graphics card and the ideal LAN PC would be ready!
Of course, case manufacturers were quick to jump on the bandwagon, making the compact cases roomier and putting airflow in the foreground. Since Moore’s Law is hardly tenable and powerful graphics cards today unfortunately come with very high power consumption and correspondingly monstrous coolers, ITX cases also had to grow a bit over time.
And here Corsair comes around the corner with the 2000D Airflow, a compact ITX case that can accommodate 36cm long triple-slot GPUs and large 360mm AIOs for cooling a high-performance processor on a footprint of less than an A4 sheet. Because I was really looking forward to this test, there is no more time to waste.
Unboxing
The packaging is as unspectacular as packaging can get. Neutral cardboard with a logo, serial numbers and technical data on the side, and only the case inside, wrapped in styrofoam and foil, as you know it.
No decorative elements, no glass, no illumination, the front, like all other side panels, consists almost entirely of mesh.
Only the modern I/O element adorns the front.
The casing parts are framed in plastic all around. Gaps and haptics are on a high level, which is typical for Corsair.
The lid is held by magnets and can be removed easily.
Like all other openings, the lid also has a dust filter in front of the mesh:
The rear offers space for two 120mm fans, depending on the graphics card, and is also protected by a magnetic dust filter.
UNDER the case is a plastic flap, behind which is the I/O panel of the mainboard. Getting the cables in there later and having to put the whole PC on the front or side each time is really awkward, but we’ll get to that later.
The side panels are well secured. Metal lugs are hooked into the front, and thick metal balls snap into the base construction at the back.
To ensure that nothing falls off, the side panels are also screwed in place. Nice detail: The screws do not fly completely out of the thread and can therefore not fall off.
The case completely freed from all side panels with a view of the back of the motherboard tray and the opening for the power supply.
The PSU tray once again in detail. Since both sides are open, you have the choice whether the PSU sucks in the warm internal air and transports it out of the case, or is supplied with cool fresh air from the outside.
Three 120mm fans can be installed at the front, although only SLIM fans can actually be used here, otherwise you will collide with the motherboard. I’ll go into more detail in the “installation report” section.
On the right side is a removable bracket for another three 120mm (or two 140mm) fans. This is intended for the use of an AIO, which we will also install later.
Detail: The slots for the expansion cards are unusually arranged and point downwards instead of out of the back of the case.
The case comes with the usual bits and pieces, a bag of screws and a small amount of cable ties.
In addition, we find an IEC cable extension with an angled plug, which is absolutely necessary for the unusual orientation of the power supply.
Steffdeff
777 Kommentare 729 Likes
Dankeschön für den Test !!!!😃😎😃
Um das Mini-ITX habe ich bisher einen großen Bogen gemacht, was sich jetzt ändern könnte!
Gibt es eigentlich Einschränkungen bei der GPU wenn man den Scythe Mugen verbauen möchte? Den hätte ich nämlich noch auf Lager!
Beim DisplayPort könnte sowas hilfreich sein:
Derfnam
7,517 Kommentare 2,032 Likes
LAN-Parties? Hmmm...
Egal. Bilder konnte ich nicht gucken, weil ich sofort spürte, wie mir Ekelpickel auf den Augäpfeln wuchsen, aber das bin sicher wie immer nur ich. Erinnert hat mich das Ding an einen ähnlichen Wachturm von - soweit ich das richtig erinnere - SilverStone. Alles schön geschlossen, nur oben und unten war ein Lüftereinbau möglich (Kamineffekt vielleicht?). Hatte Igor mal getestet.
Dass das nicht mehr dem der jetzigen Kundschaft oktroyierten Geschmack entspricht - geschenkt. Aber mal rein hypothetisch gefragt: 140er oder gar 180er Lüfter im Boden und die harte Ware eher aus den unteren Regalen pufft oben aus - das sollte doch auch flutschen, oder?
Alexander Brose
836 Kommentare 598 Likes
Moin!
Ne, eigentlich nicht. Der Mugen ist ja genau so "breit" wie der Fera und hier kannst du sehen, dass beim Fera noch massig Platz bis zum PCIE-Slot übrig ist.
Grüße!
Lagavulin
240 Kommentare 211 Likes
Vielen Dank für den Test und den Einbaubericht!
Das I/O-Shield an der Gehäuseunterseite ist auf den ersten Blick schon merkwürdig, wäre aber für mich die perfekte Lösung, wenn man einen frei im Raum stehenden Schreibtisch hat: So hat man eine „saubere“ Rückseite ohne sichtbare Anschlüsse und Kabel.
Toll finde ich auch, dass man lange (365mm!) Tripe-Slot-Grafikkarten einbauen kann.
Was für mich leider gar nicht geht ist, dass man vorne keine 25mm dicken Lüfter einbauen kann.
r
rokzo
54 Kommentare 13 Likes
Hey,
kann man einen Dark Rock pro 4 oder Noctua NH D15 einbauen?
S
SpotNic
1,090 Kommentare 464 Likes
Eine Frage am Rande, besteht die Möglichkeit die Galleryslides so einzustellen, dass sie einmalig durchlaufen und stoppen? Das macht einen Irre, mir sind die Anzeigezeiten zu kurz und bei jeder Gallery auf Pause zu drücken nervt irgendwie.
LurkingInShadows
1,386 Kommentare 584 Likes
Wenn ne RTX 4xxx eingebaut wird kann man sich die 90° Adapter gleich mitkaufen, oder? Weil so ne Kurve wie auf dem Bild bringst ohne ja nicht zusammen....
T
TheSmart
432 Kommentare 216 Likes
Also so rein optisch gefällt mir das Gehäuse recht gut.
Nur der Preis ist Corsairtypisch ein wenig zu hoch angesetzt.
Aber dies könnte ja dann noch der Markt regen die nächsten Monate.
Wobei ich mir aber am ehesten so ein Gehäuse mal wünschen würde im Design des Fractal North. Nur halt dann kein Midi, sondern ITX.
Das wäre echt mega geil^^
Tim Kutzner
857 Kommentare 700 Likes
Hey, diese Wasserkühlung kommt mir bekannt vor!
H
Headyman
117 Kommentare 54 Likes
ITX habe ich auch schon zweimal verbaut. Ist immer wieder lustig wie fast das gesamte Board unter einem großen Luftkühler "verschwindet"...
Und wenn man dann noch ein Kabel stecken muss...
LurkingInShadows
onyman
244 Kommentare 128 Likes
Interessantes Gehäuse. Ich mag es, dass es auch immer mal wieder alternative Aufbaukonzepte gibt. Nichts ist öder als immer wieder die gleichen Gehäuse mit Facelift anzubieten.
Und der Preis wird sich aus der Stückmenge ergeben. Ich kann mir nicht vorstellen, dass davon viele produziert werden. Dazu ist die Zielgruppe zu klein.
Follow Igor:
