CPU GPUs Graphics Reviews
Core i9-12900KF and Ryzen 9 5950X vs. GeForce RTX 3090 and Radeon RX 6900XT Review – Big impact on power consumption and efficiency!
What actually happens when you let the two fastest CPUs compete with the GeForce RTX 3090 instead of the Radeon RX 6900XT? We noticed some amazing things and therefore we measured and cross-tested several times. The result is reproducible, but that does not make it any more comprehensible. But it at least explains why the power consumption measurement in our launch articles for Alder Lake S turned out so differently, because at least two factors come together.
On the one hand, it was the different boards that led to very different power consumption values at CPU loads between 25 and 80 percent. Even an MSI MAG Z690 Carbon WiFi produced an average of 5 watts more power consumption across all games for the Core i9-12900KF in the Intel recommended setting with the PL1 at 241 watts, an Asus ROG Maximus Z690 Hero came in at 8 to 10 watts more and the Aorus Z590 Master was pretty much right in the middle. The gaming performance of all boards, however, was very similar and was de facto even within the tolerance range. However, even this maximum of 10 watts would still be less than the 20+ watt difference in places that resulted from my measurements compared to many other reviews. How come?
Besides the different motherboards, the only option left was to vary the graphics cards. Incidentally, the actual cause (and final impetus) was a cross-test with several motherboards and Xaver’s use of a GeForce RTX 3090 FE, which produced very similar FPS values to the Radeon RX 6900XT in Shadow of the Tomb Raider in 1080p, thus also allowing a comparison between the NVIDIA and AMD graphics cards. With a very astonishing result, which could be reproduced on several systems without any problems. Fortunately, the systems with both CPUs were still untouched in the office, so that a retest under really identical conditions was very easy.
Since the differences were greatest in 720p (1280 x 720 pixels), but this trend continued in the same way even if toned down in 1080p (1920 x 1080 pixels), I focused on the lowest resolution and re-measured everything with the two relevant CPUs, using the GeForce RTX 3090 FE of course. I’ll be contrasting performance in each game again in the next few pages, as well as power consumption and efficiency, because these metrics really deserve attention,
Regarding the last page I can already briefly spoil that I can certainly also plausibly explain the difference in the power consumption values in the sum of all influences. However, I have included the possible conclusions and causes on all pages, so it is really worth reading the complete article to the end. So first page and last page does not work. The truth lies, as always actually, also and above all in between. I have quickly summarized the individual components of the test system in a table as a reminder:
Test System and Equipment
Hardware:
Intel LGA 1700
Core i9-12900KF (PL1 125W, 241W), Core i7-12700K (PL1 241W), Core i5-12600K (PL1 150W)
MSI MEG Z690 Unify
2x 12 GB Corsair Dominator DDR5 5200 @ 5200 Gear 2
Intel LGA 1200
Core i9-11900K, Core i7-11700K, Core i5-11600K
MSI MEG Z590 Unify
2x 16 GB Corsair DDR4 4000 Vengeance RGB Pro @ 3733 Gear 1
AMD AM4
Ryzen 9 5950X, Ryzen 9 5900X, Ryzen 7 5800X, Ryzen 5 5600X
MSI MEG X570 Godlike
2x 16 GB Corsair DDR4 4000 Vengeance RGB Pro @ 3800 1:1
MSI Radeon RX 6900XT Gaming X OC
NVIDIA RTX 3090 FR
1x 2 TB MSI Spatium M480
1x 2 TB Corsair MP660 Pro XT
Be Quiet! Dark Power Pro 12 1200 Watt
Cooling:
Aqua Computer Cuplex Kryos Next, Custom LGA 1200/1700 Backplate (hand-made)
Custom Loop Water Cooling / Chiller
Alphacool Subzero
Case:
Raijintek Paean
Monitor: LG OLED55 G19LA
Power Consumption:
Oscilloscope-based system:
Non-contact direct current measurement on PCIe slot (riser card)
Non-contact direct current measurement at the external PCIe power supply
Direct voltage measurement at the respective connectors and at the power supply unit
2x Rohde & Schwarz HMO 3054, 500 MHz multichannel oscilloscope with memory function
4x Rohde & Schwarz HZO50, current clamp adapter (1 mA to 30 A, 100 KHz, DC)
4x Rohde & Schwarz HZ355, probe (10:1, 500 MHz)
1x Rohde & Schwarz HMC 8012, HiRes digital multimeter with memory function
MCU-based shunt measuring (own build, Powenetics software)
Up to 10 channels (max. 100 values per second)
Special riser card with shunts for the PCIe x16 Slot (PEG)
NVIDIA PCAT and FrameView 1.1
Thermal Imager:
1x Optris PI640 + 2x Xi400 Thermal Imagers
Pix Connect Software
Type K Class 1 thermal sensors (up to 4 channels)
Acoustics:
Creative X7, Smaart v.7
Own anechoic chamber, 3.5 x 1.8 x 2.2 m (LxTxH)
Axial measurements, perpendicular to the centre of the sound source(s), measuring distance 50 cm
Noise emission in dBA (slow) as RTA measurement
Frequency spectrum as graphic
OS: Windows 11 Pro (all updates/patches, current certified or press VGA drivers)
DrWandel
84 Kommentare 69 Likes
Wow, das ist wirklich interessant. Im Endeffekt frage ich mich natürlich, was das denn nun für den Anwender und Gamer bedeutet. Es ist technisch hochinteressant zu sehen, welche Faktoren Performance, Leistungsaufnahme und Effizienz beeinflussen, und Kudos an Igor und Team für solche detaillierten und differenzierten Betrachtungen und Messungen, die ja auch speziell bei 720p solche Unterschiede aufzeigen.
Für Gamer, die in WQHD oder gar UHD spielen und oft/meistens im GPU-Limit sind, sollte das dann doch aber weniger eine Rolle spielen, oder? Es ist ja auch so, dass man sich aktuell ganz gut eine brauchbare CPU leisten kann (zumindest im Bereich eines Ryzen 5600X), aber eine vernünftige GPU eher weniger. Mittelfristig würde ich da gerne noch ein paar Tests sehen, die zeigen was die CPU-Wahl bei WQHD/UHD bewirkt, bei Spielen im GPU-Limit. Theoretisch sollte das ja kaum einen Unterschied machen, aber praktisch? Mit anderen Worten, welche CPU sollte ich mir leisten um die Grafikkarte, die ich schon habe oder mir noch leisten kann, vernünftig zu komplementieren?
Zu dem Thema wird es sicher hier und an anderen Stellen noch Untersuchungen geben.
Casi030
11,923 Kommentare 2,339 Likes
Schade ist nur das die AMD nicht auch mit einem leichten -Offset getestet werden.Etwas mehr Leistung bei etwas weniger Verbrauch wäre auch noch mal interessant.
k
krelog
174 Kommentare 53 Likes
schöner Ansatz aber ohne wirklichen nutzen weil das getestet Szenario zwar theoretisch existiert aber praktisch leider nicht, wäre vergleichbar wenn man einen F1 Wagen testet wie er sich beim Stadtverkehr macht. Kann man machen aber hilft keinem weiter.
10,485 Kommentare 19,650 Likes
Im Launchartikel hatte ich bereits Test in WQHD und auch eine Einlassung zu UHD drin. Wo nichts ist, kann man auch nichts Unterschiedliches messen. Denn genau dann ist es fast schon Wumpe, was man im PC als CPU hat. Ich spiele selbst nur in UHD und merke zwischen dem 9900K und dem 12900KF objektiv überhaupt keinen Unterschied. Aber dazu schrieb ich ja schon was :)
Muss man machen, weil man mich wegen meiner Messwerte angegangen ist. Also alles eher eine Frage der Plausibilität und am Ende wohl auch der Ehre. Mit einem interessanten Nebeneffekt, der bis FHD gut messbar ist.
Q
QuFu
163 Kommentare 52 Likes
Der Vergleich hinkt. Eher der F1-Wagen auf dem Motorprüfstand. Nutzlos für die Leute, die nur das Rennen sehen wollen, aber analytisch betrachtet, unverzichtbar. Und Grafiktests im CPU-Limit gibts doch schon wie Sand am Meer. Das wäre im angesprochenen Vergleich nur was für Leute, die das Rennen gerne mehrmals schauen. ;)
Thy
1,843 Kommentare 744 Likes
Der Benchmark bei 720p ist natürlich rein akademisch, aber er verstärkt einige Stärken und Schwächen der einzelnen Konfigurationen, so dass daraus interessante Rückschlüsse gezogen werden können, wie Igor ja schön in seinem Artikel gezeigt hat. Für mich kristallisiert sich der i7-12700K mehr und mehr als die momentan ideale Gaming-CPU heraus, da sie von der Leistung, meiner Meinung nach, völlig ausreicht und andererseits das absolute Effizienzmonster zu sein scheint, welches selbst den 5600X noch schlägt.
m
m4ntic0r
12 Kommentare 5 Likes
Also die schlechte Leistung der 3090 oder auch allen anderen Nvidia Karten in niedrigen Auflösungen ist krass. Was haben die da im Treiber vermurkst.. du kannst ja keinem FULLHD Zocker der auf max. FPS aus ist eine Nvidia Karte empfehlen :D
M
Matthias80
40 Kommentare 9 Likes
Was hoffentlich mal einer Testet ;-) weil es ja offensichtlich ist, das Intel hier mit ihren echt Mega P-Cores in Spielen was reißen.
Quasi für die aktuellen Gegebenheiten eine Punktlandung.
Aber die E-Cores wohl gar nix bringen... wohl nur für synthetische Test entwickelt wurden...
Ob die E-Cores z.B. ein Streaming abdecken können??
Ob ein Spiel was die 8 P-Cores gut auslastet... durch zusätzliches Streaming, Leistung abzwacken müssen, oder ob das die E-Cores sinnvollerweise übernehmen.
Wie die Test mit deaktivierten E-Cores gezeigt haben... null komma nix in Spielen!
Also aus Spielersicht, hat man sich 2021 eine 8 Core CPU gekauft. ahhhhhhhh ok.
Klar single Core Leistung und im Paket die Effizienz mega.
Aber halt nur 8 Core!
So wenn ich mir künstlich Szenarien suchen muss, um überhaupt die Existenz außerhalb von Spielen zu belegen. mmmmmh
Die Theorieseite wurde jetzt unglaublich ausführlich beleuchtet. Wie wäre es mal mit Praxistest?
Soooo weit her geholt ist mein Streaming Bsp. ja nun ned.
mfg
BlackFireHawk
109 Kommentare 115 Likes
Kannst du beim AMD system Mal mit cppc disabled im bios benchen? Würde sich Grade anbieten solange die Test Setups noch aufgebaut sind
Gerade mit cppc disabled hab ich beim 5950x bedeutend bessere min FPS in vielen spielen.
Zer0Strat
162 Kommentare 138 Likes
@Igor Wallossek So ganz verstehe ich deinen Test nicht. Zum einen hast du Radeon Karten benutzt und dann die gleichen CPUs nochmal mit der Nvidia Karte?! Aber warum wird dann nicht beide Male der 5900X oder der 5950X genommen? Das ist ja ein gemischter Vergleich. Die vollständige Beschriftung der Labels wäre nice gewesen. So werden jetzt nur die Nv Karte + CPU X Kombis explizit aufgeführt.
Der wesentliche Punkt ist aber die Vergleichbarkeit. Muss man die FPS nicht cappen, um das überhaupt vergleichen zu können? Wenn eine CPU A schneller als CPU B ist, dann verbraucht die GPU ja auch mehr, weil diese weniger ausgebremst wird.
grimm
3,193 Kommentare 2,125 Likes
Du sagst es doch selbst: Wenn du die FPS begrenzt, begrenzt du ja mittelbar auch die CPU - außer du misst, wie schnell eine CPU die Daten bereitstellt. Das kannst du aber theoretisch den Frametime-Messungen entnehmen.
Casi030
Warum deaktivieren? Schon mal Höchstleistung Processors min/max 100%versucht? Das hilft bei vielen.
E
Ebatman
28 Kommentare 27 Likes
Mal ein Gedankenspiel:
Irgendwie könnte man vermuten dass die Sprunvorhersage von Intel in Verbindung mit der 3090 öfters daneben liegt.
Oder der Nvidia Treiber "falsche" calls ausgibt die die Sprungvohersage "korrumpieren".
Je nach Aufbau bei Intel würde sich das nur in winzigster FPS Reduktion bei aber merkbar höherem Stromverbrauch manifestieren.
Ist jetzt mal ein Schuß ins Blaue, ein paar abhängigkeiten voneinander deuten ein wenig in diese Richtung.
Allgemein scheint Nvidia nun das selbe Problem zu haben wie AMD in den älteren Serien mit der vollständigen Auslastung der Shadereinheiten (overhead).
BlackFireHawk
Weil cppc zusammen mit dem Windows sheduler die Threads wie verrückt zwischen den Kernen hin und her schmeißt.
Cppc versucht soviel wie möglich auf so wenig wie möglich Kernen auszuführen damit diese höher boosten können und andere nicht genutzte Energiesparen können
Ich denke mal, Du hast nicht aufmerksam hingeschaut. Ich habe die beiden schnellsten CPUs nun mit der RTX 3090 noch einmal gemessen und zusätzlich noch mit reingepackt und deshalb auch separat gekennzeichnet, die Werte mit der Radeon stehen ja schon drin und zudem bei jedem Chart steht auch noch RX 6900XT auch im Titel. Missverständlich ist was anderes. Zumal ich auch noch farbige Balken nutze, wo es möglich ist. Aber ich habe weder Zeit noch Ressourcen, alles noch einmal komplett neu zu beschriften.
Und was die Leistungsaufnahme betrifft:
Schau Dir die Benchmarks mal genauer an, da müsste Intel ja auch sparsamer werden. Genau das ist aber nicht der Fall. Im Gegenteil, die Effizienz sinkt sogar mit der NV-Karte, trotz niedrigerer FPS. Steht doch alles im Artikel :)
BTW: Ich habe auch mit AVX On/Off getestet, mach kaum einen Unterschied. Und wenn man die FPS generell capt, liegt man wieder bei der Grafikkarte und nicht bei der CPU. Dann kann ich ja gleich in UHD testen :D
Thy
Ein E-Core leistet so viel wie ein Skylake-Core bei einem Viertel der Größe eines P-Cores. Selbst wenn ein P-Core 3x so schnell wie ein E-Core ist, ist er auf die Fläche normiert weniger effizient.
Dann kann ich auch den Game-Mode aktivieren und ihn zum 8-Kerner machen, oder SMT deaktivieren oder... Da gibts endlos viele Optionen, die aber in diesen Artikel nicht reingehören. Ich warte erst mal, bis Windows 11 noch etwas gepatcht wurde.
M
Matthias80
ah jupp. schön copy paste...
alles bekannt!
nur sieht man da ja in Spielen gar nix von.
Thema E-Cores diabled und null Leistungsverlust.
weil kaum ein Spiel aktuell von mehr als 8 Cores profitiert.
Darum meine Frage. Für einen echten Praxistest! Was passiert wenn ich z.B. mein Spiel streame.
Wird mein Spiel unter umständen langsamer weil die P-Cores das Streaming zusätzlich Stämmen müssen.
Oder werden da die E-Cores genutzt? Sind sie nicht nur dafür da, um bei synthetischen Benchmarks mithalten zu können...
Bei AMD stellt sich die Frage ned. Wenn ich z.B. einen 12 oder 16 Kerner habe. Weil alles die gleich Leistungsfähigen Kerne am Start sind.
Geht mir nicht darum Intel schlecht zu machen!
Es wird ja immer von aktuell gesprochen. Aktuell sicherlich die beste Spiele CPU!
Aber wenn man mehr macht als nur Spielen. Nebenbei noch mehr macht... Was bei den Kindern heutzutage normal ist.
Ist in meinen Augen gar kein Spielen... aber nebenbei yt, discord ect. ect. ist normal.
So einen Praxistest vermisse ich halt. Schöne Theorie. Wäre ja nicht das erstmal das Theorie Tests perfekt gekünstelt werden...
In der Praxis sieht die Leistung dann aber anders aus!
Will jetzt nicht wieder einen Autovergleich bringen...
Follow Igor:
