PC-Cooling
Corsair XTM70 Extreme Performance Thermal Grease Review – Just missed the top spot but really good and unfortunately also very expensive
The Corsair XTM70 Extreme Performance is convincing and even if the price is quite hefty even without iCUE, you still get an honest product. That’s a little spoiler in advance, even if the price really hurts me. At almost 17 euros for 3 grams, you have almost reached the gourmet temple and real caviar almost seems like an alternative bargain [...]
Can the big brother do everything better? – Corsair iCUE XC7 RGB Elite LCD water block review including teardown and test loop 2.0
After our previous water block retest, which hopefully dispelled some untruths and rumors, here is the second part with a few improvements and implemented change suggestions from the community. Corsair has also asked us to test the successor to the XC7 Pro, the XC7 Elite LCD – and we’re happy to oblige. As a reference, I would [...]
Real laboratory tests of thermal pastes on igor’sLAB – Part 2 – First comparative measurement with 2 expensive pastes
Yesterday we already had the big theoretical part, today we are doing a practical measurement with two selected pastes, whereby the paste that is nominally better on the data sheet is actually the “worse” one in the test and vice versa. Of course, the factor of potential long-term durability also plays a role, which may put the result [...]
MSI Spatium M580 Gen5 and M560: New SSDs with innovative technology
MSI is setting new standards in performance and efficiency with the launch of its next generation Spatium SSD series, the Spatium M580 Gen5 and Spatium M560 Gen5. The M580 Gen5 sets itself apart from the competition with innovative non-metallic vapor chamber cooling, while the M560 Gen5 offers a cost-effective DRAM-less option for Gen5 speed.   [...]
NZXT at Computex: Airflow cases, new fans, brand new power supplies and a tour of the trade fair with many products
First of all, I would of course like to recommend the valuable trade fair video from me, because the tour and a nice explanation naturally provide a real live impression that no film in the world can replace. If you want to see two people really sweating (me because of the heat and NZXT because of the amount of explanations), I can only warmly [...]
AI in the thermal paste? Something is wrong! Cooler Master makes a statement about its “AI” Cryofuze 5 thermal compound
Perhaps some of you have noticed. Cooler Master recently introduced its Cryofuze 5 thermal compound. All well and good at first, but what surprised some people was that the branding “AI” was included. This confused many people because it has nothing to do with artificial intelligence. There were various speculations and even euphoric [...]
Slime in the GPU water block and white crystals in the radiator – about plasticizers, corrosion and the wrong materials | Investigative
Today’s case comes from the community and a lengthy investigation was necessary because there were actually two causes of the pollution at the same time. I will describe my process, the measurements and also the conclusions in chronological order and it also shows once again how important it is to know the connections and not just speculate [...]
We’re putting the pressure on: the new fan test bench is being built
Bearing in mind the adversities at the first attempt and the possible influence of the human factor, we have (hopefully) solved it better this time with expert support. Of course, there will be a detailed and transparent report on the exact development of the idea, the first prototypes and many empirical values, but today I don’t want to [...]
Endorfy Fera 5 Black air cooler test – Old model with a new coat of paint
No, you don’t have deja vu. I already tested this budget air cooler 3 years ago, but back then it was still in silver and under the SilentiumPC brand. What exactly motivated the manufacturer, which is now known as Endorfy, to bring out the cooler again? I have no idea. But with the new black finish and attractive price, we don’t want [...]
Cool down first! Jonsbo introduces new Gen 5 SSD cooler
Nowadays, you need good cooling for Gen 5 SSD storage media so that you don’t suddenly have an SSD that causes thermal problems due to the high heat, which is exactly why Jonsbo is introducing a new Gen 5 SSD cooler that provides a remedy, as ITHome reports. SSDs are constantly evolving and the fifth generation or SSDs with PCIe 5.0 support [...]
Double test in a two-chamber case – Corsair 6500 Series Mid-Tower and the XH405i RGB Hard-Tube Custom-Loop Kit
After a long delay, today we are taking a look at the new dual-chamber case from Corsair, which generates powerful Carbide Air 540 vibes. As I also installed the XH405i RGB Hard-Tube Watercooling Kit as part of the test, you can expect plenty of pictures. So better get a large coffee to read the article today. To be precise, it was the Corsair [...]
10 CPU water blocks tested on socket LGA1700 and AM5 in a big roundup including a necessary reappraisal
in today’s article, we have tested 10 water blocks, on 2 platforms, with 2 pump settings, each with different mounting variants. Today is not about theoretical values, but about real performance figures that every reader can measure themselves at home with a little effort. The background to all this is, of course, the initial review of the [...]
