It wasn’t that long ago that Cooler Master introduced a new line of AiO watercoolers, and now they’re already following it up with something new. A sleek design combined with iterative improvements to its predecessor distinguishes the FLUX series, at least according to the manufacturer. To what extent this new contender can hold its own in the very crowded market for 240mm AiOs can be read in the following article:
The shipping box is in the purple-black design typical for this manufacturer and is relatively large for a 240mm AiO.
The familiar sight of a bagged water cooler, which is protected by a cardboard casing during transport, also awaits us inside for the first time.
The included accessories consist of all sorts of small parts, screws and of course mounting brackets. A small tube of “Mastergel Pro” thermal paste with quite little content and a Y-PWM cable for the fans complete the whole.
In case the own motherboard does not have ARGB ports for the lighting yet, Cooler Master includes a full-fledged controller, which can be controlled via the internal USB port. The MasterPlus+ software is also required. Those who already have a suitable connection can simply use the splitter cable, which is also included, to connect the pump and both fans.
Assembly and installation
Regardless of the base, the brackets of this AiO must first be attached to the pump block with a total of four small screws. For the AM4 socket, however, it is quite simple, because the existing backplate and plastic mounts of the motherboard are used again. In these eyelets you just hang the hooks.
![](https://www.igorslab.de/wp-content/uploads/2022/01/Installation-PL240-980x767.png)
Finally, tighten the two screws slightly without using tools to achieve the desired contact pressure. After the cables have been laid and connected, you are ready to go.
Specifications
As always, here is an overview of the technical details of these water coolers, all further information can then be found on the product page from the manufacturer.
15 Antworten
