The availability is still very good at the end of 2019, three versions are offered – as schom with the predecessor:
MasterLiquid ML120L RGB (120mm)
Cooler Master MasterLiquid ML120L RGB (MLW-D12M-A20PC-R1)
![]() | lagernd | 89,90 €*Stand: 15.07.24 23:18 |
MasterLiquid ML240L RGB (240mm)
Cooler Master MasterLiquid ML240L RGB (MLW-D24M-A20PC-R1)
MasterLiquid ML360 RGB (360mm / TR4 socket only)
Cooler Master MasterLiquid ML360 TR4 RGB (MLX-D36M-A20PC-T1)
![]() | ca. 3 Wochen | 127,49 €*Stand: 16.07.24 06:36 |
In this review I refer to the prices of November 2019, possibly different current prices are to be interpreted by myself.
Specifications ML240L
Pump: 2100 RPM – Copper Coldplate (rough)
Fan: 650 to 2000 RPM – hydraulic bearing – 4 pin connection
Radiator thickness: 27mm
Airflow per fan: up to 113 m3/h
Air pressure per fan: up to 2.34 mmH2O
Noise level: 6 – 30 dBA
Hose length: 300mm
More data on the product page
A few comments in advance:
• Thermal paste is not pre-applied
• The coldplate is quite rough compared to other AiO, complete removal of the thermal paste after removal is rather idle
• The fan holders are padded with foam rubber
• Installation with AM4 possible without an extra backplate
Packaging / Scope of delivery
Here, too, the typical AiO packaging is used: cardboard box with corresponding recesses, pump block, radiator and fan bagged. In addition to the small instructions for installation, Cooler Master also includes a 12V RGB controller with physical buttons as well as a 1-to-3 RGB splitter and a Y splitter for 4 pin fans. Thus, you can enjoy the RGB lighting even with older boards without LED headers. In-house thermal paste is of course also present (not shown here in the picture).
![](https://www.igorslab.de/wp-content/uploads/2019/12/IMG_20190927_1531502-1024x772.jpg)
![](https://www.igorslab.de/wp-content/uploads/2019/12/IMG_20190927_1541392-1015x1024.jpg)
Even if it does not affect the performance or the tightness, it can disturb one or the other quite visually:
![](https://www.igorslab.de/wp-content/uploads/2019/12/IMG_20191002_184502-1024x512.jpg)
![](https://www.igorslab.de/wp-content/uploads/2019/12/IMG_20190927_1621342-1024x967.jpg)
