CES Latest news Monitors
CES: MSI QD-OLED monitors: 49″, 34″, 32″, 27″ for every taste
In 2024, MSI is launching its new QD OLED gaming monitor family, which includes several models from the MPG & MAG series. Leaks have previously hinted at an imminent release of QD OLED gaming monitors from MSI. Now the company has decided to present its lineup before and then at CES 2024. In total, the family includes five new models, with further additions in the future.
Source: MSI
Below are the models in MSI’s QD OLED family before we get into the details of each specific variant.
  • MPG 491CQP QD-OLED, DQHD/144(5120x1440p)
  • MAG 341CQP QD-OLED, UWQHD/175 (3440x1440p)
  • MPG 321UPX QD-OLED, UHD/240 (3840x2160p)
  • MAG 321UPX QD-OLED, UHD/240 (3840x2160p)
  • MPG 271QPX QD-OLED, QHD/360 (2560x1440p)
  • MAG 271QPX QD-OLED, QHD/360 (2560x1440p)
All MSI gaming displays will use QD-OLED technology to provide the best possible picture and display quality.
  • Next-Gen QD-OLED Panel – With highest picture quality and fast response time.
  • Fastest 0.03 ms GtG response time and 144 Hz refresh rate.
  • QD Premium Color – Ensures that the color meets market standards – Delta E≤2.
  • Incredible HDR Visual – VESA DisplayHDR True Black 400.
  • Gaming Intelligence App – Perfect display settings for gaming.
  • MSI OLED Care 2.0 – Reduces the risk of OLED image retention / burn-in.
  • KVM – Control multiple devices via one set of keyboard, mouse and monitor.
  • Console Mode – Offers HDMI 2.1 with a full bandwidth of 48 Gbps.
MPG 491CQP QD-OLED
The first model is the MSI MPG 491CQP QD-OLED with a curved (1800R) 49-inch dual QHD (5120 x 1440) panel, a refresh rate of 144Hz, a brightness of 250 nits, DisplayHDR True Black 400 compliance and a USB Type-C 90W charging option. The monitor also features an internal graphene film and a customized heat sink that enables a fanless design.
MAG 341CQP QD-OLED
The MSI MAG 341CQP is a monitor with QD-OLED design and a UWQHD panel (3440 x 1440 / 1800R). It offers a refresh rate of 175Hz and the option to charge via USB Type-C with 15W. This monitor is intended as a cheaper alternative to the MSI MEG 342C, which is available for 999 US dollars. Therefore, one can expect the MPG model to be offered at a significantly lower price, while the panel specifications remain the same, apart from the premium aesthetics of the MEG segment.
Four flat panel designs will also be available in the MPG and MAG series, each in 32″ and 27″ sizes. The 32″ panels will have a UHD resolution and a refresh rate of 240Hz, while the 27″ panels will have a WQHD resolution and refresh rates of 360Hz/240Hz. Each panel will be available with either 90W or 15W Type-C functionality.
MAG 341CQP QD-OLED
MPG 321URX QD-OLED
MPG 271QRX QD-OLED
Each monitor will be equipped with a variety of AMD Freesync and NVIDIA G-Sync features and will have HDMI 2.1, DisplayPort 1.4a and a Type-C (DP old) Power Delivery output. Pricing for these QD OLED gaming monitors from MSI has not yet been announced, but we will provide an update as soon as we receive more information from the CES booth.
Source: MSI
RX480
1,887 Kommentare 879 Likes
mooore MHz ist zwar nice, aber die Pixeldichte ist so lala
btw.
lt. der Roadmap von LG gibts sooo richtig gute Sachen erst 2025
A
Andy
269 Kommentare 73 Likes
Da bin ich mal auf das neue Pixel Layout RGWB gespannt und den 39" Monitor mit 5120x2160 Auflösung. Hätte gerne einen größeren Office und Spielemonitor.
R
RazielNoir
462 Kommentare 224 Likes
Ich warte mal auf die ersten Test's vom 27er
P
Phelan
204 Kommentare 184 Likes
Leider alles QD-OLed, also im Dreieck angeordnete Pixel. Da bin ich vermutlich raus. Mal schaun wie MSI das hinbekommt.
Mir selber sind auch die immer weiter steigenden Anzeigefrequenzen egal. 60Hz reicht mir, zumal das die Grafikkarte auch schaffen muss. Mir ist es wichtiger das die ordentlich Entspiegelt sind und sie das mit dem einbrennen im Griff haben.
Aber schön zu sehen das OLED jetzt langsam über die komplette Breite auf alle Modellgrößen ausgerollt wird.
Guest
Da ist noch Luft nach oben!
bei 34 Zoll stell ich mir 16 K 666hz 20 bit vor.
Damit kann man dann live die Verbrennung eines "Gesinnungs-kätzers" angucken.
Bevor man das verboten Buch im heimlichen Eck liest.
Oscar Werner :) peace :)
Im Ernst : EINE IGORS QUALITY FATALITY APROVED HADES STUDIE ( I Q F A H S ) Zu dem zeug von Euch wäre toll.
bedeutet : WER NICHT BEI IGOR TESTEN LÄSST produziert Abfall :) wär des was?
PEACE und Danke :)
Guest
Igor hat 10.000 neue Mitarbeiter eingestellt. Auf dem Jupiter Mond IO in der neuen
Raumstation IGORS TEEST-LAAAB IQ-ONE wird die neueste Technik und der heissteste Scheiss getestet!
Du willst mehr wissen? KANN man PLASTIK essen? kann ein Traktor die Freiheitsstatue umfahren?
bleib dran :)
Samir Bashir
