Cooling Reviews Watercooling
Bykski Ice Dragon Kit Review – A Budget DIY Kit for Custom Watercooling Loops
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
In the comments on reviews about high-end AiO watercooling systems you can always read that a custom loop can be built for the money. And that’s exactly what we have here today as a practical ready-to-use set to test this statement:
Packaging and accessories
Normally the set comes with its own proper packaging, but at the moment the dealer EZModding is reworking this and has therefore already manually put something together for me in advance. Apart from that, my special parcel here was also well packed and the content was padded with a lot of bubble wrap.
To make it as easy as possible to set up your own watercooling system, there are some accessories included, besides the scissors to cut the softtube, there is also a small spray bottle and – to my surprise – a liter of DP Ultra coolant from aquacomputer.
We will come to the remaining components in detail on the next page.
Assembly and installation
Depending on the system, the further procedure varies somewhat, of course, but some general statements can still be made. The CPU block in this kit here is specifically designed for AMD CPUs and simply screws into the Bykski backplate with four screws. This is optically almost identical to the backplate included with mainboards, but has slightly larger holes for the screws.
Strange that they don’t just use matching screws for the normal AM4 backplate here and save the extra backplate. In my test system, I chose the order of components as follows: pump -> CPU block -> radiator -> pump. There will be pictures later.
Tim Kutzner
855 Kommentare 700 Likes
Jetzt bin ich mal gespannt, wo sich sie Kits von anderen Herstellern einordnen. EK Waterblocks sollte als Nächstes kommen, Alphacool folgt eventuell auch bald. Noch weitere Vorschläge? :)
ipat66
1,418 Kommentare 1,433 Likes
Es ist wieder auffällig,wie schwer diese Ryzen zu kühlen sind.
Der Noctua Luftkühler macht den Job fast genauso gut,manchmal sogar besser....
Wasser ist dann doch für GPU's interessanter....
Müsste man mal testen wollen ...
Alleine für die CPU eher Mittelmaß .
Schön bunt,für diejenigen die es mögen....
Danke Tim für den Test....
skullbringer
310 Kommentare 329 Likes
Nettes Kit für den Preis! Was man im Vergleich zu einer AIO an Performance nicht bekommt, wenigstens an Flexibilität.
Ryzen CPUs mit ihrer hohen Wärmedichte sind wirklich ein sehr guter Kühler-Benchmark. Da muss direkt von der IHS an schon alles passen und wenn ein Glied der Kette schwächelt, schlägt es sofort durch. Bin gespannt ob Blöcke mit feineren Finnen dann überhaupt noch einen Vorteil haben, der Bykski sah nämlich schon relativ grob aus. 👀
Und natürlich Danke für den Test! ;)
Guest
Eine erste WaKü bestand bis auf den GPU-Block(watercool) und den Lüftern(Noctua), komplett aus Bykski. Ich kann nichts schlechtes berichten.
Die damalige DDC Pumpe hab ich nach einem Jahr gegen eine Heakiller Tube samt D5 von Watercool getauscht. Bei Optik und auch von der Lautstärke merkt man natürlich einen Unterschied. Wobei auch der Preis wichtig ist zu beachten. Bykski Pumpe 60€ vs 160€ für die neue. Als Einstiegspumpe war sie top und dank eBay tut sie jetzt anderswo noch ihren Dienst.
Den damaligen Bykski CPU Block hab ich ebenfalls gegen einen Heatkiller IV getauscht. War mit dem Bykski optisch und auch von den Temps zufrieden. Dachte, mich mit dem Heatkiller gravierend zu verbessern, aber das war nicht der Fall. Ich wollte dann nur nicht wieder alles zurückbauen. Auch hier gilt es die Preise zu vergleichen. Bykski direkt vom offiziellen Shop in China 40€ / Heatkiller ~80€.
Heute nutze ich noch die Radiatoren und sämtliche Anschlüsse von Bykski.
Sollte ich in 2 Jahren wieder einen PC mit Ryzen 6000 und RTX 4000 bauen, werde ich mir passende Bykski Kühlblöcke dazu holen. 👍
(Kommt doch eh alles aus China!)
Casi030
11,923 Kommentare 2,339 Likes
Das hab ich mich auch schon beim Kühler gefragt als ich mir diesen gekauft hatte,warum die Feingewinde genommen haben und nicht einfach das größere Gewinde , spart Kosten da ja die Backplatte weg fällt......
A
Andy
269 Kommentare 73 Likes
Danke für den Test Tim. Na da bin ich mal auf die anderen Kits gespannt. Wobei eine Wasserkühlung nur für die CPU sich eigentlich nicht lohnt. Das bei dem Preis die Kühlkanäle des Radiators unter den Schraubbefestigungen der Lüfter ungeschützt sind halte ich für mehr als unglücklich. Wer denkt denn bitteschön in einigen Monaten Jahren noch daran wenn er evtl. mal andere Lüfter verwenden will.
Gibt es für diese Einsteigersets eigentlich auch Erweiterungssets für GPUs? Wäre evtl. interessant zu sehen wie diese sich dann im Gesamtverbund schlagen.
Noch eine Anmerkung zu der Autoslide Funktion der Bilderstrecken. Hatten wir gestern schon beim Test von @skullbringer angemerkt die Autoslidefunktion evtl. zu deaktivieren. Ich finde, dass es zum einen den Lesefluss stört, wenn zwischen dem Text ständig die Bilder wechseln und zum anderen kann ich den Inhalt mancher Bilder gar nicht so schnell erfassen bzw. möchte mir manche Bilder/Grafiken gerne länger anschauen (z.B. letzte Seite Übersicht der Ergebnisse). Bei jeder Bilderstrecke erstmal prophylaktisch den Pausebutton zu drücken empfinde ich dabei als etwas umständlich).
Tim Kutzner
GPU-Blöcke gibts von Bykski auch, spricht ja nichts dagegen einfach einen mit einzubauen :D
Martin Gut
7,942 Kommentare 3,698 Likes
Ich schliesse mich der Bitte an. Wechselbilder lenken mich stark ab.
Wie jetzt?
61 Kommentare 48 Likes
Prima Test, danke dafür! Das Ergebnis des Kits überzeugt mich so überhaupt nicht, noch dazu der Preis. Wenn man jetzt hergeht und ohne bling-bling auskommt und auf das Pumpendesign pfeift (Geschmackssache, mich stört es nicht, geschlossenes Case)- die m.M.n. aktuelle Referenz für 360er AiO (Arctic Freezer II) bekommt man aktuell für ein Drittel des Preises (schlanke 82€). Selbst die RGB-Variante liegt unter 100€. Ich glaube die 250€ würde ich nicht mal dann ausgeben wenn ich für die Zukunft einen custom loop im Visier hätte.
Tim Kutzner
Sliden bei den Ergebnissen war unbeabsichtigt und habe ich eben korrigiert, danke :)
Bei den normalen Bildern ist es immer wieder vorgekommen, dass dann Sachen übersehen wurden.
Ich denke mal, da werde ich die Zeit zum Wechsel einfach mal Verdoppeln.
@Andy
Casi030
Vorschlag , einfach mal verschiedene CPU Blöcke an dem Kit Testen,ob der CPU Block für die schlechte Leistung sorgt oder der Radi,die Pumpe.......
Guest
Wäre mir zu laut. Ich habe eine "asbach-alte" Aquastream (v1.0 und 15 Jahre alt) verbaut, die ich irgendwann auf die Ultra geupdatet habe (39 Euro). Läuft mit dem Flügelradmod bei 55Hz unhörbar. Da kann ich selbst mit dem Ohr dicht rangehen (inklusive open source Version der Aquasuite - ohne Gebühr). 37-39db? Das wäre mir nichts und jede AIO schafft das genauso, sind aber deutlich preisgünstiger.
Gegen Byski gibt es nichts zu sagen, die kühlen ähnlich wie jeder andere Hersteller sind aber preisgünstig. Wäre eher eine Frage des Designs. Zu mal sie auch mal Kühler im Programm haben die gerade bei den Customs (EKWB, Watercool etc.), nicht nur zu den üblichen Verdächtigen passen.
Hatte mal den Support eines namenhaften Herstellers angeschrieben, wobei ich als Antwort erhielt das sich Kleinserein bei einigen Herstellern im Bereich Fullcover GPU nicht lohnen und sie Customdesigns daher kaum berücktsichtigen, schon komisch wenn man Referenzen gar nicht gekauft bekommt (so wie derzeit). Da wäre Byski im Bereich GPU Fullcover wohl auch eine Wahl.
Bei so einem Set muss irgendwann und irgendwo gespart werden, meist dann bei den Lüftern, Radi's oder eben der Pumpe.
l
lowrider_05
22 Kommentare 23 Likes
Also ohne Werbung machzu wollen, aber das kit gibts beim Ali mit den normalen Coupons die fast immer dabei sind für 140€ inkl. Versand + Zoll und dann ist die PL noch etwas besser.
Tim Kutzner
Schick ruhig mal einen Link rein, ich habe kein vergleichbares Kit gefunden
l
lowrider_05
OK Manchmal muss man sich korrigieren. Ein reines CPU Kit mit den exakt selben Komponenten habe ich tatsächlich auch nicht finden können. Da hat EZ-Modding schon ein sehr gutes Angebot.
einzig als 240er Kit gibt´s was interessantes, sind aber wohl auch nicht die selben Komponenten:
240er AMD KIT
und das Kit als 360er Radiator Variante inkl. GPU Kühler ist auch nicht so schlecht:
360er AMD KIT + GPU
Tim Kutzner
Dann wäre man bei 160 bzw 250 Euro inklusive Versand.
Bei Einfuhr kommt dann noch Zoll und Steuer drauf, liegt man bei 205 bzw. 320 Euro ...
Muss man dann selbst überlegen, ob sich das lohnt. Support oder Garantie aus Fernost ist ja auch immer so eine Sache
E
Emotionfan
2 Kommentare 0 Likes
Hallo Igor, mich würde mal ein Test dieser Wasserkühlung von Granzon (Bykski) z.B. an einer 3080 interessieren: https://de.aliexpress.com/item/1005003050859191.html
  • View image at the forums
Granzon GPU AIO Kühler Kit Für Nvidia RTX 3090 3080 Grafikkarte GPU Core + MOS + VRAM Alle In eine RGB Wasser Kühlung GZGPU-M240N​
Ich werde versuchen die Wasserkühlung heute in meinen Rechner einzubauen und bin mal gespannt, ob das alles gut funktioniert. Da ich die Wasserkühlung aufgrund von Pressemeldungen bzgl. der Neuerscheinung gekauft habe, wäre ein Urteil von einem Profi über diese Wasserkühlung sehr interessant.
ro///M3o
361 Kommentare 249 Likes
Ich müsste noch irgend wo eine neue AC EisBär AIO rumliegen haben. Die wollte ich in den HTPC einbauen aber werde vor 2022 nicht dazu kommen. Falls Interesse besteht, kann ich die gerne für Tests zur Verfügung stellen? Ist allerdings ein 280er wobei die ja auch quasi eine semi Custom ist und somit der Radiator gegen eine vorhandene 360 getauscht werden könnte. Einfach Bescheid geben wenn interessant. Dann suche ich die mal raus. Wäre ein AC Eisturm mit XPX Kühlblock auch interessant?
l
lowrider_05
Aliexpress führt seit Juli 2021 die Steuern ab, also da kommt kein Zoll oder Steuern mehr dazu! 161,95 € sind der Endpreis für die 240er Kit Variante.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
